    Weather module not getting shown
    15 Posts 6 Posters 9.2k Views 6 Watching
      MadScientist
      (Ich mach das hier mal auf englisch, damit du deine Chancen erhöhst, dein Problem zu lösen.)
      It’s probably best to share your config with us. Just remember to remove anything you don’t want to share (e.g. API keys, maybe location etc.).
        MichaelS
        hier ist meine config Datei
        var config = {
        	port: 8080,
        	language: "de",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_right"
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "****",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "****"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "***",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "****"
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "aktuelle Nachrichten",
        						url: "https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html"
        				showSourceTitle: true,
        				showPublishDate: true
          MadScientist
          I don’t really see anything wrong with your config. All other default modules are displayed? Did you rename the config.js.sample to config.js?
          • idoodlerI Offline
            idoodler Module Developer
            You may take a look at the log. If you use pm2 you can just type pm2 restart MagicMirror && pm2 log MagicMirror, this will restart your MacigMirror and then echo out the log. You then can look for any error or warning messages.
              MichaelS @MadScientist
              Warum umbenennen?
              Das habe ich nicht gemacht
                MadScientist @MichaelS
                @MichaelS The config.js.sample is only a sample file. You have to rename it by removing the sample part in the end. But you most likely did already, otherwise the mirror would ask you to create a config file.
                Are the other modules showing?
                  sek_is_back
                  @MichaelS said in Wetter wird nicht angezigt:
                  Warum umbenennen?
                  because the Mainprogram looks for a file named config.js without this file it dontn know what to display
                    MichaelS @sek_is_back
                    Uhrzeit, News und Sprüche werden angezeigt.
                    Wetter nach wie vor nicht.
                      sek_is_back
                      module: “currentweather”,
                      heißt das Modul currentweather? oder MMM-Wounderground?
                      unter Modul muss der Name des Moduls stehen der gleich mit dem Name des Ordners ist
                        MadScientist @sek_is_back
                        @sek_is_back said in Wetter wird nicht angezigt:
                        Das default Modul heisst currentweather. Soweit ist alles richtig.
                        MicharlS: hast du mal gemacht, was idoodler gesagt hat? Logs könnten weiterhelfen.
