    Electron CPU usage
    247 Posts 46 Posters 668.3k Views 42 Watching
      martinkooij @mattn
      @mattn thanks! I love my modules, so difficult to lose one ;).
      It however seems you have a slow leak too, growing memory usage of ca 200Mbyte in 6 days. Much less than me, but still more than it should be, I guess. Just let us know how you fare! Thanks for sharing.
        martinkooij
        @mattn and others.
        I have a stable situation with the following:
        • electron 1.4.15 (withELECTRON_FORCE_WINDOW_MENU_BAR=1).
          higher elektron version gives black screen, the environment variable lowers the cpu-usage by elektron considerably).
        • Magic Mirror 2.3.1 (actually I was quick to install MM2.3.0 but manually downgraded electron, but I am quite sure that amounts to the same as installing MM 2.3.1).
        • nodejs version v9.11.1. (I used to have a 1.6.x nodejs, but that one caused memory leaks. )
        Is now running in this configuration almost 7 days without interrupt. And no signs of stopping soon. Thanks you all in this forum for the help.
        (Rasberry pi 3, Jessie, CPU Hardware: BCM2835, Revision: a02082)
          cdelaorden
          Hi guys
          Im new to the forum and this project but I have some small experience with the Pis and having the same issue
          I think that its related to the video driver, using ‘sudo raspi-config’ and changing the video driver to one of the GL drivers resulted in a much lower cpu load in my case.
          Doesn’t matter if you choose full KMS or fake KMS as long as you dont use the legacy non-GL driver.
          It took my 4 CPU from full 100% to idle bellow 35%
          Im sure someone else with this problem can confirm this
          E MichMichM 2 Replies Last reply
          • E
            E3V3A @cdelaorden
            @cdelaorden
            • How can we check the video driver without using rapsi-conf?
              in dmesg? in systemd journal?
            • How/where do you set the: ELECTRON_FORCE_WINDOW_MENU_BAR=1.
            • What would be the easiest way for users to check electron version from command line?
            “Everything I do (here) is for free – altruism is the way!”
            C 1 Reply Last reply
              cdelaorden @E3V3A
              @e3v3a
              You can check it in the config.txt
              or just do a “tail /boot/config.txt | grep dtoverlay” to check what version is enabled
              all the rest of my configuration is the default one after a fresh install from the current version of MM and Raspbian, I havent touched anything from electron
                Juju
                Omg, yes finally! :D
                First I followed this installation guide: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/3
                I had the electron CPU issue. So I downgraded to electron version 1.4.15. The CPU usage went down from 90% to 70%. It was still laggy as hell.
                I then formatted the microSD card and followed that youtube guide: https://www.youtube.com/watch?v=0Q04SKvibik
                Downgraded to 1.4.15 again and now it’s running great with a CPU usage of like 5% with spikes to 50%, when there is an animation on the screen.
                But I have one question.
                After I finished the youtube tutorial I have the “MagicMirror” and the “mm”. Both autostart when I boot the raspberry pi.
                Which use has the “mm”?
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Juju
                  @juju
                  pm2 stop mm
                  pm2 delete mm
                  pm2 save
                  rm ~/mm.sh
                  Reply Quote 2
                  • MichMichM
                    MichMich @cdelaorden
                    @cdelaorden I think you’ve found the issue! Awesome work!
                    For others please note that when you start raspi-config and go to “Advanced Options” > “GL Driver”, the top one will always be selected, no matter which one is active. After selecting one of the two top drivers (GL), it might solve the hi CPU load issue …
                    It solved it on a clean installed Pi 3 for me.
                    • MichMichM
                      MichMich
                      I added some info about the Open GL driver to the Wiki:
                      https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
                      Hein-JanH 1 Reply Last reply
                      Reply Quote 3
                      • Hein-JanH
                        Hein-Jan @MichMich
                        @michmich
                        I seem to be running into some kind if trouble. My SD card failed, so I had to do a clean install. I decided to immediately go for the full KMS driver.
                        “$ tail /boot/config.txt | grep dtoverlay” results in “dtoverlay=vc4-kms-v3d”.
                        The CPU usage is alright, but “/home/pi/.pm2/logs/mm-error-o.log” states:
                        libGL error: MESA-LOADER: failed to retrieve device information
                        I am having trouble with the monitor. I am using MMM-Remote-Control.
                        “MONITOROFF” results in “/home/pi/.pm2/logs/mm-error-o.log”:
                        Powering off HDMI
                        “MONITORON” results in “/home/pi/.pm2/logs/mm-error-o.log”:
                        Powering on HDMI with preferred settings
                        [E] Failed to power on HDMI with preferred settings
                        { Error: Command failed: tvservice --preferred && sudo chvt 6 && sudo chvt 7
                            at ChildProcess.exithandler (child_process.js:217:12)
                            at emitTwo (events.js:106:13)
                            at ChildProcess.emit (events.js:194:7)
                            at maybeClose (internal/child_process.js:899:16)
                            at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                          killed: true,
                          code: null,
                          signal: 'SIGTERM',
                          cmd: 'tvservice --preferred && sudo chvt 6 && sudo chvt 7' }
                        Powering off HDMI
                        I may be wrong but I feel this is related to the Full KMS driver.
                        Can anyone confirm? Does anyone have a solution?
                        I am way out of my depth here…
                          Dom1n1c
                          @Hein-Jan I got the same issue.
                          A few minutes, the monitor could be controlled, but then “tvservice -p” fails to power on the monitor.
                            cdelaorden @Hein-Jan
                            @hein-jan @Dom1n1c
                            Please use the fake kms driver instead “dtoverlay=vc4-fkms-v3d”
                            it its known that the full kms driver isnt compatible with tvservice plus other restrictions
                            EDIT:
                            Also with the fake KMS you can rotate the display from /boot/config.txt so I suggest @michmich using it as the preferred method in the wiki
                            Reply Quote 2
                              schmo90
                              @cdelaorden said in Electron CPU usage:
                              hy now i use the fake kms driver, everything is working fine and realy fast.
                              but i have the problem that the mirror will go to a black screen after some hours.
                              only a pm2 restart mm helps in this case -.-
                                cdelaorden @schmo90
                                @schmo90 mmm havent had that problem, everything its working fine
                                Have you deactivated the screensaver as its shown in the wiki?
                                Also, are you using a module like MMM-Remote-Control to turn off the screen?
                                If you see a black screen and the mouse but nothing else you are probably missing “sudo chvt 6 && sudo chvt 7” in your statement after turning hdmi back on. You can test it in ssh after forcing the issue.
                                Also if you are concatenating commands like Hein-Jan did with “tvservice --preferred && sudo chvt 6 && sudo chvt 7” have in mind that commands after && are only executed if no errors are found. So maybe “tvservice -p” its working correctly but its giving some feedback and things after && aren’t executed.
                                You could force it by using ; as a separator instead of && so it doesn’t look for an answear
                                  schmo90
                                  hy i didnot turn off the hdmi,
                                  i will turn off the lcd with the gpio’s
                                  screen is turning on normal but electron browser is showing a black screen (mous appears at moving)
                                  • binderthB
                                    binderth
                                    adding another flavour:
                                    As my Foscam FI9900P got an ONVIF-Update lately and is now capable of RTSP-streaming I installed MMM-RTSPStream.
                                    • activated fake (or full) OpenGL Desktop driver:
                                      omxplayer crashes
                                    • activated non-GL desktop driver:
                                      omxplayer runs
                                    So, as I see it, the omxplayer problem doesn’t concern MagicMirror - is there another way to reduce Electron CPU usage - except using an Open-GL dekstop driver?
                                    PS: activating fake KMS reduced CPU usage as recommended in this thread - but I’d like to have the video-stream of my cam on the MM (unfortunately it doesn’t provide MJPEG)
                                      cdelaorden @binderth
                                      hi @binderth
                                      the fake-kms was created for keeping omxplayer compatibility but you need to add the “–no-osd” flag to the omxplayer command line
                                      you might want to try it
                                      dont bet on it, but changing line 101 of node_helper.js to
                                      var args = ["--no-osd", "--live", "--video_queue", "4", "--fps", "30",
                                      might do the trick
                                      • V
                                        vinp Module Developer
                                        MM 2.4.1 - if anyone is trying to look for it while searching for forums. Apologies if it has already been stated
                                        So i’ve done it both ways:
                                        I noticed that my CPU temp is well into the 60-70 degree Celsius with CPU loads mostly in the 1.x, 2.x, and sometimes 3.x ranges
                                        When i try the other way :
                                        CPU is much lower in temp under 50 degrees Celsius and CPU load rarely goes above 1.x
                                        and i am able to use the tvservice -o and tvservice -p to schedule my monitor to go on and off at certain times
                                        Hopefully this helps anyone searching for this issue on new installs like myself
                                        Reply Quote 4
                                          jaffons
                                          So i ran into this issue as well. I started MM stuff 2-3 weeks ago.
                                          When everything was working my logs show:
                                          • I had the previous mm version ( probably 2.3.1)
                                          • Enable the Open GL driver, fake KMS (via raspi-config)
                                          • Disabling the screensaver https://www.raspberrypi.org/forums/viewtopic.php?t=57552
                                          • Autohiding the Mouse Pointer
                                          • rotate screen 270deg(CW), display_rotate=3 at /boot/config.txt
                                          • I also had the dtoverlay=vc4-fkms-v3d line there
                                          • I was getting this error though (thrunpm start ):
                                          Anyway I messed something on my modules and had to reinstall the Raspbian. Same as before, Stretch 7/-18
                                          • Rotate screen at /boot/config.txt
                                          • installed the MM 2.4.1 and tried it straight away default config and modules. It was working alright
                                          • I think I added the dtoverlay=vc4-fkms-v3d line…
                                            • and boom animations started lagging (+high CPU)
                                            • also npm start dev didnt work. It launched but no mirror was shown and if i had mm running it would stop refreshing.
                                          Any way I figured out that taking that commenting out that # dtoverlay=vc4-fkms-v3d everything works flawlessy. I dont get the “libGL”-error
                                          and I also updated npm 5.6.0 → 6.2.0 sudo npm i -g npm and npm start dev started working (dev or no dev).
                                          My Rpi temperature is under 50C when mm is running (no heatsink).
                                          Hope this helps out someone!
                                          A 1 Reply Last reply
                                          Reply Quote 4
                                          • A
                                            adamlove86 @jaffons
                                            @vinp and @jaffons WOW! Thank you for your comments… Made a huge difference.
                                            After some months I needed to reinstall from scratch (now also hosting octoprint and a remote desktop simultaneously). I thought MM animations were just generally slow, but this made a huge difference compared to the more orthodox setup.
                                            I don’t see why this configuration shouldn’t be preferred over the normal Pi configuration, and the OpenGL driver was also much trickier to get working.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
