    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.1k Views 27 Watching
      maxbachmann
      @Mykle1 still have a windows 10 development board with 4gb ram and a Intel Atom x5-Z8350. Hope I have the time to try MM with that this we :)
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @maxbachmann
        @maxbachmann
        That’ll do. For me, I don’t like having to run Windows for a MagicMirror, especially if the resources of the board I am using are limited (Ex. 2GB RAM). Also, at some point, you may run into a problem installing dependencies under a Windows system (Ex MMM-voice). Running Ubuntu and MM eliminates both of these drawbacks.
          maxbachmann
          @Mykle1 hm I will see drivers on there work better with windows. However if it sucks with windows I can still put Ubuntu on it ;)
          Don’t need mmm-voice since I use a voice recognition on a different raspberry pie
          justjim1220J 1 Reply Last reply
          • justjim1220J
            justjim1220 Module Developer @maxbachmann
            @maxbachmann
            You will have better luck with the Windows Developer than Windows 10.
            But, you may have problems with the Atom CPU.
            Which is from my experiences…
            I have not tried it on Ubuntu or any other OS besides Windows. I did try Widows Developer, But the computer I was using just wasn’t strong enough to run it.
            I have tried Windows 7 and windows 10 on several different types of laptops and desktops. And it really does make a difference making sure you always have the latest updates, and you will need a beefy CPU and more than 4gb RAM. I have an older SFF Lenovo desktop and it’s maxed out on the CPU and RAN it can have, and the more I work on it, the more I have to reboot to clear memory as it locks up. But, if I have MM running, and absolutely nothing else, it runs pretty smooth. Same experiences with a couple laptops, with So-So cpu’s and 4 gb max RAM. I also attempted to run MM on a Surface RT, it doesn’t allow any applications other than what it came with, so, as expected, wouldn’t work. I do know of a person running MM on a Surface Pro 15.6" Tablet PC, don’t know the specs, but he says he doesn’t have any problems with it. I also know of a person trying it on an Ubuntu Laptop, but he is having problems getting it to run at all. I would help him, but he knows more about Ubuntu and the Linux-Based OS’s than I do.
            I also had MM on an HP All-In-One, with maxed out CPU and 16gb RAM, and an Asus laptop with the latest Core-i7 CPU and 16gb RAM, and they run very smooth, even if I’m running other applications, surfing the web, making changes to MM and restarting it several times, I had no problems with it. I also had no issues using it on a Lenovo 14" 360 laptop with a core-i3 CPU and 8gb RAM.
            I had it going on a Nexxus 10.1" tablet running Windows 10, but it was extremely slow… I had nothing on this 32gb tablet with a 32gb micro SD except a stripped down version of Win 10 and the Mirror. and it was just too slow. if I remember right, it only had 2gb RAM.
            And yes, Mykle is very correct about the voice issue. I’m am still researching on what may be available for running voice and facial recognition with Windows. but as of right now, I have tried several different types of modules and applications. have yet to find anything that works, YET!!!
            When you get it installed on your Atom device, I would definitely like to know your outcome!
            Jim Hallock - 1995
            Mykle1M 2 Replies Last reply
              maxbachmann
              @Mykle1
              Just tried my Monitor out. Thats a sick black. I can’t see any difference between black and Monitor off.
              And there is no message when unplugging or plugging in the HDMI cable :grinning_face:
              Hope I get the walnutwood for my frame next week
                maxbachmann
                @Mykle1 Probably going to keep the pi: The only problem I have right now is the gif.
                So I checked why this actually is a problem: GIF’s and the Pi just really hate each other, because unlike a video it gets processed in the cpu. However showing the gif as a video in a loop should work a lot better ;)
                Will try this and let you know how it worked out
                Reply Quote 2
                • justjim1220J
                  @maxbachmann
                  You need to put a Chevy Bowtie around that!
                  Is that an image, or what?
                  Jim Hallock - 1995
                    maxbachmann
                    @justjim1220 was just the first mainly black picture I had laying around lol
                      maxbachmann
                      I hope someone has a clue about this problem. Magic Mirror ect has a black background. However when I show it on my monitor it appears a bit gray. I would usually say thats because of the monitor. However when I plug in my windows laptop and show black it’s a lot darker. Whats the reason that my debian has no real black?
                        maxbachmann
                        1. Found the problem the raspberry used limited RGBinstead of full RGB now it’s real black ;)
                        2. the video runs without lagg however it’s really at the limit lol
                          need a cooler otherwise the raspberry keeps overheating
                        Reply Quote 3
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @justjim1220
                          @justjim1220 said in Hello-Lucy:
                          The point I was really trying to make is that ubuntu uses the least amount of resources and turns a useless/worthless laptop into an excellent MM board that outperforms any Pi.
                          Reply Quote 2
                          • Mykle1M
                            @maxbachmann
                            I would recommend a fan for any Pi running MM. I learned that quickly enough. :-)
                              maxbachmann
                              @Mykle1 since I need some more raspi anyways I might just give it a 3b+ so I have a bit more power (I am at stable 83% cpu usage so the 17% should help a bit) and a already included cooler
                              • Mykle1M
                                I have ubuntu, MM, and Hello Lucy running on a POS EeePC. The thing was ready for the trash. Amazing how well it runs now. Oh yeah, it’s an Atom processor.
                                • justjim1220J
                                  justjim1220 Module Developer @Mykle1
                                  @mykle1
                                  Yeah, I’m just really stubborn im this old age I getting to… Still bound and determined to get it to run on Windows somehow!!!
                                  I may be 75 or 90 by the time I figure it out, But, I ain’t giving up!!! :smiling_face_with_horns:
                                  Jim Hallock - 1995
                                    maxbachmann
                                    @Mykle1 without cooler I am at stable 77-78 degree I would say that sucks lol
                                    @justjim1220 Lol just use windows for the stuff it"s made for (I guess like the name already implies it"s for throwing it out of the window) :smiling_face_with_horns:
                                    • Mykle1M
                                      @justjim1220
                                      Well, I wish you luck. I tried (half-heartedly) to get MM-voice and Hello Lucy to run under Windows. Once I got comfortable with ubuntu I realized the benefits where MM is concerned
                                      • Mykle1M
                                        @maxbachmann said in Hello-Lucy:
                                        With a simple fan my Pi mirror runs at a constant 43C
                                          maxbachmann
                                          @Mykle1 In general the only reason I still use Windows is because Autodesk still does not have linux versions for the CAD software lol
                                            maxbachmann
                                            @Mykle1 just took a cooler from a old PCB I had laying around and some thermal compound. saved me 25 degree
                                            • 14
                                            • 15
                                            • 6 / 15
