    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 752.8k Views 27 Watching
      maxbachmann
      @Mykle1
      Just tried my Monitor out. Thats a sick black. I can’t see any difference between black and Monitor off.
      And there is no message when unplugging or plugging in the HDMI cable :grinning_face:
      Hope I get the walnutwood for my frame next week
        maxbachmann
        @Mykle1 Probably going to keep the pi: The only problem I have right now is the gif.
        So I checked why this actually is a problem: GIF’s and the Pi just really hate each other, because unlike a video it gets processed in the cpu. However showing the gif as a video in a loop should work a lot better ;)
        Will try this and let you know how it worked out
        • justjim1220J
          justjim1220 Module Developer @maxbachmann
          @maxbachmann
          You need to put a Chevy Bowtie around that!
          Is that an image, or what?
          Jim Hallock - 1995
            maxbachmann
            @justjim1220 was just the first mainly black picture I had laying around lol
              maxbachmann
              I hope someone has a clue about this problem. Magic Mirror ect has a black background. However when I show it on my monitor it appears a bit gray. I would usually say thats because of the monitor. However when I plug in my windows laptop and show black it’s a lot darker. Whats the reason that my debian has no real black?
                maxbachmann
                1. Found the problem the raspberry used limited RGBinstead of full RGB now it’s real black ;)
                2. the video runs without lagg however it’s really at the limit lol
                  need a cooler otherwise the raspberry keeps overheating
                Mykle1M 1 Reply Last reply Reply Quote 3
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @justjim1220
                  @justjim1220 said in Hello-Lucy:
                  And yes, Mykle is very correct about the voice issue.
                  The point I was really trying to make is that ubuntu uses the least amount of resources and turns a useless/worthless laptop into an excellent MM board that outperforms any Pi.
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @maxbachmann
                    @maxbachmann
                    I would recommend a fan for any Pi running MM. I learned that quickly enough. :-)
                      maxbachmann
                      @Mykle1 since I need some more raspi anyways I might just give it a 3b+ so I have a bit more power (I am at stable 83% cpu usage so the 17% should help a bit) and a already included cooler
                      • Mykle1M
                        When you get it installed on your Atom device, I would definitely like to know your outcome!
                        I have ubuntu, MM, and Hello Lucy running on a POS EeePC. The thing was ready for the trash. Amazing how well it runs now. Oh yeah, it’s an Atom processor.
                        justjim1220J 1 Reply Last reply Reply Quote 1
                        • justjim1220J
                          justjim1220 Module Developer @Mykle1
                          @mykle1
                          Yeah, I’m just really stubborn im this old age I getting to… Still bound and determined to get it to run on Windows somehow!!!
                          I may be 75 or 90 by the time I figure it out, But, I ain’t giving up!!! :smiling_face_with_horns:
                          Jim Hallock - 1995
                            maxbachmann
                            @Mykle1 without cooler I am at stable 77-78 degree I would say that sucks lol
                            @justjim1220 Lol just use windows for the stuff it"s made for (I guess like the name already implies it"s for throwing it out of the window) :smiling_face_with_horns:
                            • Mykle1M
                              @justjim1220
                              Well, I wish you luck. I tried (half-heartedly) to get MM-voice and Hello Lucy to run under Windows. Once I got comfortable with ubuntu I realized the benefits where MM is concerned
                              • Mykle1M
                                @maxbachmann said in Hello-Lucy:
                                With a simple fan my Pi mirror runs at a constant 43C
                                  maxbachmann
                                  @Mykle1 In general the only reason I still use Windows is because Autodesk still does not have linux versions for the CAD software lol
                                    maxbachmann
                                    @Mykle1 just took a cooler from a old PCB I had laying around and some thermal compound. saved me 25 degree
                                      maxbachmann
                                      Lucy.mp4 auf dem Raspberry Pi
                                      • Mykle1M
                                        @maxbachmann
                                        I’m not suggesting that you abandon Windows. I still have my Windows machine, too. I mean where MM is concerned. Do you need to have Autodesk and the CAD software running with MM?
                                        • Mykle1M
                                          Excellent!
                                            maxbachmann @Mykle1
                                            @mykle1 ah no I mean in general. I wanted to drop windows already for months ;) But since I need the CAD software I can’t lol maybe I will go over to linux and put windows into a VM just for CAD Software
                                            • 14
                                            • 15
                                            • 6 / 15
