    mmm-moon-phases don't work for me
    36 Posts 4 Posters 20.1k Views 4 Watching
    • Y Offline
      Ybbet
      @Mykle1 : Yeah, I saw that (in another topic too). However, from what I see in your code, there is no identification of the current location. Which would allow to have information maybe more precise.
      In addition, the various texts displayed do not interest me on my installation. And there is no possibility to disable line by line (CSS or javascript) these texts. :-)
        Mykle1 Project Sponsor Module Developer @Ybbet
        @ybbet said in mmm-moon-phases don’t work for me:
        Uhh, as far as I know, the phases of the moon are the same no matter where you live, or I am drastically mistaken. :-/
        You certainly can disable each and every line by css. I updated the css file to make it as easy as possible.
        • justjim1220J Offline
          justjim1220 Module Developer
          there’s like 3 different moon or lunar modules.
          I’ve tried all of them and none are working for me.
          i get the header and the loading message. that’s it.
          at first I had one working.
          but after the reload it didn’t work anymore.
          I had thought that maybe it only shows when the moon is visible to my area when I can physically see it.
          but none of them worked last bight when the moon was showing.
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
          • Y Offline
            Ybbet
            @Mykle1 Ah! I found what was bothering me. The image of the moon does not change … Indeed, the image seems more decorative than informative. As a result, this does not show the current moon phase at all.
            It was rather in this sense that I had to understand my previous comment.
            The moon-phases module did its job very well. Until the cache problem appears.
              Have you read the README file? Or looked at the example config entry? You might have seen this:
              image: "animation", // animation, current, DayNight or static
              If you choose current instead of animation you will absolutely see the current moon phase, delivered by the US Navy. Like so.
              http://api.usno.navy.mil/imagery/moon.png?date=today&time=now
                Mykle1 Project Sponsor Module Developer @justjim1220
                @justjim1220
                Assuming one of those three was mine . . .
                It should show the current moon phase (If that is the option you chose in the config). If you want me to help you with that, I will.
                Let’s start with your config entry. May I see it. Copy and paste it here in a code block please.
                  justjim1220 Module Developer @Mykle1
                  @mykle1
                  It is working now. I just haven’t been back on here to let it be known.
                  Last night none of them would work, wouldn’t show anything but the header and the loading message.
                  Like on yours, it just stayed in the lower corner of the region I have it set to, Showing the header and that message… “When the moon hits your eyes…”.
                  Thanks though, not sure when it started working, left it like that when I went to bed, and it was working this morning. :smiling_face_with_sunglasses:
                  Jim Hallock - 1995
                    @justjim1220
                    You likely lost internet OR the api was down
                      @mykle1
                      kind of what I was thinking…
                      I haven’t tried the other 2 I tried last night, but that is just fine, yours is the the one I wanted,
                      It’s a great module!!!
                      Jim Hallock - 1995
                        Jim Hallock - 1995
                        • 1 / 4
