Unsolved Black screen after MM v2.4.0 update.
Bumping this because I’m also having issues. A lot of time on google says it’s not just a MagicMirror issue, but lots of people have problems with the OpenGL drivers. My screen is blanking after some time no matter what, but I also found the hard way that it messes with
tvservice
(like the Remote Control module uses) – turning my HDMI off straight up insta-shut down my pi! Gonna have to keep researching for sure. -
I just updated and this is shown at the end of the install.
MagicMirror installation successful! > magicmirror@2.4.1 install-fonts /home/pi/MagicMirror > cd fonts && npm install npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed. npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed. npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed. npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed. pi@raspberrypi:~/MagicMirror $
I applied
dtoverlay=vc4-kms-v3d
to the config.txt ( also tried with fkms)
Reboot and I get a black screen.
When I remove dtoverlay=vc4-kms-v3d then the mirror boots up.
Any suggestions? -
@mykle1
Just found your guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginnersGoing at it now and see if it works - thanks for the patience and writing that guide!
@kastore said in Black screen after MM v2.4.0 update.:
You’re welcome, sir. :-)
Got my mirror working again. Had to go over the opengl drivers again and using the fake kms driver did the trick. However one problem remains, i had to also disable the MMM-Pir-Sensor module because that was messing with the system. But also my custom.css is not being used atm, and i cant figure out why its not grabbing it.
Anyone else struggling with using MMM-Pir-Sensor after the new update?
Yes, I am having the same black screen. I have to disable PIR to be able to use MM at all. I also noted that after I installed PIR I could no longer SSH into the Pi from my desktop computer, whereas I could from my mobile phone. Anyway, the black screen is the main concern right now. I’ll post if I discover anything helpful.
Not sure if I’m having the same issue, stupidly updated electron as npm was claiming 1.7.13 had a critical vulnerability (after installing MMM-voice) Then got the backscreen issue. rolled back electron to 1.7.13 & the issue persists.
Node v9.11.1
npm 6.1.0Thought I’d uploaded the log file but not sure if others can see it. That snippet below is the first error after ALL_MODULES_STARTED
13:01:19.440 main.js:40 Uncaught TypeError: Cannot read property ‘appendChild’ of undefined
at main.js:40
at Array.forEach ()
at createDomObjects (main.js:24)
at Object.modulesStarted (main.js:471)
at startModules (loader.js:59)
at loader.js:40
at HTMLLinkElement.stylesheet.onload (loader.js:203)
(anonymous) @ main.js:40
createDomObjects @ main.js:24
modulesStarted @ main.js:471
startModules @ loader.js:59
(anonymous) @ loader.js:40
stylesheet.onload @ loader.js:20313:01:20.056 TypeError: Cannot read property ‘getElementsByClassName’ of null
at moduleNeedsUpdate (main.js:176)
at main.js:144
at Promise ()
at updateDomWithContent (main.js:137)
at main.js:119
at
Promise rejected (async)
(anonymous) @ main.js:121
Promise resolved (async)
(anonymous) @ main.js:118
updateDom @ main.js:109
updateDom @ main.js:514
updateDom @ module.js:358Any pointers as to how to get it working again? It was working perfectly before MMM-voice & buggering around with electron.
Tried a fresh install with the same result :( -
I’m also having the black screen of death. I tried both overlay options, and I tried commenting it out alltogether. I also ran the 2.4.1 update, but still getting black screen. Runs normally with the new update though when I comment out the PIR module in the config.js file.
@shane1234 if u have the PIR module loaded, and do ctrl-shift-i (lower case letter i), it will open the debug env, and then select the console tab… do you see any errors?
also, if u start from a terminal window, alt-spacebar, n will minimze the mirror screen so you can see the terminal window node_helper outputs… anything there?
usually a module.js error kills with MM screen…
