    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 25.4k Views 17 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Kastore
      @kastore
      https://github.com/MichMich/MagicMirror/releases
      K 1 Reply Last reply
      • K
        Kastore @Mykle1
        @mykle1
        Thanks Mykle1
        Just how do i tell my pi to get the specific version? I am not versed in programming or coding or anything and couldnt find something online that told me how to install a specific version
        Mykle1M 1 Reply Last reply
        • KimzerK
          Kimzer
          Did anyone find a fix here? just updated and same thing here. Hopefully i can get this back working tomorrow.
          • Mykle1M
            @kastore
            One way is to go to that link I gave you and download the version you want and install it manually.
            • pyrosmileyP
              pyrosmiley
              Bumping this because I’m also having issues. A lot of time on google says it’s not just a MagicMirror issue, but lots of people have problems with the OpenGL drivers. My screen is blanking after some time no matter what, but I also found the hard way that it messes with tvservice (like the Remote Control module uses) – turning my HDMI off straight up insta-shut down my pi! Gonna have to keep researching for sure.
              • joela85J
                joela85
                I just updated and this is shown at the end of the install.
                MagicMirror installation successful!
                > magicmirror@2.4.1 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed.
                npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed.
                npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed.
                npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                pi@raspberrypi:~/MagicMirror $
                I applied
                dtoverlay=vc4-kms-v3d
                to the config.txt ( also tried with fkms)
                Reboot and I get a black screen.
                When I remove dtoverlay=vc4-kms-v3d then the mirror boots up.
                Any suggestions?
                • K
                  Kastore @Mykle1
                  @mykle1
                  Just found your guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                  Going at it now and see if it works - thanks for the patience and writing that guide!
                  • Mykle1M
                    @kastore said in Black screen after MM v2.4.0 update.:
                    You’re welcome, sir. :-)
                    • KimzerK
                      Kimzer
                      Got my mirror working again. Had to go over the opengl drivers again and using the fake kms driver did the trick. However one problem remains, i had to also disable the MMM-Pir-Sensor module because that was messing with the system. But also my custom.css is not being used atm, and i cant figure out why its not grabbing it.
                      • KimzerK
                        Kimzer
                        Anyone else struggling with using MMM-Pir-Sensor after the new update?
                        T 1 Reply Last reply
                        • T
                          thenameiwantedwastaken @Kimzer
                          Yes, I am having the same black screen. I have to disable PIR to be able to use MM at all. I also noted that after I installed PIR I could no longer SSH into the Pi from my desktop computer, whereas I could from my mobile phone. Anyway, the black screen is the main concern right now. I’ll post if I discover anything helpful.
                          • G
                            grantc66
                            Not sure if I’m having the same issue, stupidly updated electron as npm was claiming 1.7.13 had a critical vulnerability (after installing MMM-voice) Then got the backscreen issue. rolled back electron to 1.7.13 & the issue persists.
                            Node v9.11.1
                            npm 6.1.0
                            Thought I’d uploaded the log file but not sure if others can see it. That snippet below is the first error after ALL_MODULES_STARTED
                            13:01:19.440 main.js:40 Uncaught TypeError: Cannot read property ‘appendChild’ of undefined
                            at main.js:40
                            at Array.forEach ()
                            at createDomObjects (main.js:24)
                            at Object.modulesStarted (main.js:471)
                            at startModules (loader.js:59)
                            at loader.js:40
                            at HTMLLinkElement.stylesheet.onload (loader.js:203)
                            (anonymous) @ main.js:40
                            createDomObjects @ main.js:24
                            modulesStarted @ main.js:471
                            startModules @ loader.js:59
                            (anonymous) @ loader.js:40
                            stylesheet.onload @ loader.js:203
                            13:01:20.056 TypeError: Cannot read property ‘getElementsByClassName’ of null
                            at moduleNeedsUpdate (main.js:176)
                            at main.js:144
                            at Promise ()
                            at updateDomWithContent (main.js:137)
                            at main.js:119
                            at
                            Promise rejected (async)
                            (anonymous) @ main.js:121
                            Promise resolved (async)
                            (anonymous) @ main.js:118
                            updateDom @ main.js:109
                            updateDom @ main.js:514
                            updateDom @ module.js:358
                            Any pointers as to how to get it working again? It was working perfectly before MMM-voice & buggering around with electron.
                            Tried a fresh install with the same result :(
                              shane1234
                              I’m also having the black screen of death. I tried both overlay options, and I tried commenting it out alltogether. I also ran the 2.4.1 update, but still getting black screen. Runs normally with the new update though when I comment out the PIR module in the config.js file.
                                sdetweil @shane1234
                                @shane1234 if u have the PIR module loaded, and do ctrl-shift-i (lower case letter i), it will open the debug env, and then select the console tab… do you see any errors?
                                also, if u start from a terminal window, alt-spacebar, n will minimze the mirror screen so you can see the terminal window node_helper outputs… anything there?
                                usually a module.js error kills with MM screen…
                                  Sun
                                  Mine after upgrade it’s freezing when trying to run magicmirror. Also try both kms driver and fake kms driver.
                                    Dom1n1c
                                    mine is also freezing after the update.
                                    No difference if i connect via vnc or using the monitor.
                                    The only thing that does work, is opening the mirror in another browser (http://magicmirror:8080)
                                    • KimzerK
                                      Kimzer
                                      Is there a different way to turn the screen on/off with the fake kms driver maybe? :s
                                      KimzerK 1 Reply Last reply
                                      • KimzerK
                                        Kimzer @Kimzer
                                        @kimzer replying to myself. I just had to chmod the new pir script i made to make it work duhhh. :p
                                          bwente @joela85
                                          @joela85
                                          Are you using MMM-PIR-Sensor?
                                          https://github.com/paviro/MMM-PIR-Sensor/issues/49
                                          I needed to delete the node_modules directory first. Then I ran npm install and the issue was gone.
                                          joela85J 1 Reply Last reply
                                          • joela85J
                                            joela85 @bwente
                                            @bwente
                                            I’m not currently using MMM-PIR-Sensor.
                                            My problem was Enabling the Open GL driver. Using “dtoverlay=vc4-kms-v3d” or “dtoverlay=vc4-fkms-v3d” did not work. Remove the line and it was fine. (Temps seem reasonable 62deg)
                                            "Enable the Open GL driver to decrease Electron’s CPU usage.
                                            The latest versions of electron use an extreme amount of CPU power when no Open GL driver is loaded. This will result in an overheating Raspberry Pi. To solve this issue, use the experimental desktop Open GL driver by adding the following line to /boot/config.txt:
                                            sudo nano /boot/config.txt
                                            Add the following line:
                                            ℹ️ Activating the Open GL drive can also be accomplished by using the raspi-config tool by running sudo raspi-config. Go to the Advanced Options menu and select A7 GL Driver. Next, select the G1 GL (Full KMS) OpenGL desktop driver with full KMS. Note that this option will be selected in the menu even when the GL drive is not yet configured."
                                            Not sure what the issue is. But at least it works.
