    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 24.3k Views 17 Watching
    • joela85J Offline
      joela85
      Thanks for the reply, I will try that when I get home.
        Charley Module Developer
        I also have a black screen.
        Tried both options
        dtoverlay=vc4-fkms-v3d
        and
        dtoverlay=vc4-kms-v3d
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          Mo
          I have a similar problem, after starting the MM the screen freezes, only way to unfreeze it is to close electron. Have tried both options too.
          After enabling either of the OpenGL drivers i get the followed errors:
          > magicmirror@2.4.0 start /home/pi/MagicMirror
          > sh run-start.sh
          libGL error: MESA-LOADER: failed to retrieve device information
          Starting MagicMirror: v2.4.0
          Loading config ...
          Loading module helpers ...
          No helper found for module: MMM-Cursor.
          Module helper loaded: MMM-Buttons
          Module helper loaded: MMM-DWD-WarnWeather
          Module helper loaded: MMM-DHT-Sensor
          No helper found for module: helloworld.
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: MMM-MyWeather
          No helper found for module: MMM-SimpleLogo.
          Module helper loaded: MMM-PiLights
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-Buttons
          Starting node helper for: MMM-Buttons
          Connecting socket for: MMM-DWD-WarnWeather
          MMM-DWD-WarnWeather helper started...
          Connecting socket for: MMM-DHT-Sensor
          MMM-DHT-Sensor helper started ...
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-MyWeather
          MMM-WunderGround helper started ...
          Connecting socket for: MMM-PiLights
          [2018-07-03 15:42:24] [MMM-PiLights] Starting node_helper
          Launching application.
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
          (node:1057) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
          (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
          Edit: MM works without any OpenGL Drivers, but CPU usage is pretty high and the Node errors are still there.
            [[global:former-user]]
            After 2.4.0, Asus Tinker Board cannot display MM. I think it might be related with this openGL issues. Is there any way to solve this?
            ATB has no openGL desktop driver like vc4-kms-v3d. Fake vc4-kms-v3d does not help.
            • joela85J Offline
              joela85
              I can’t access my mirror remotely anymore. Will I need to format my sd card and try again?
              • K Offline
                Kastore
                I am having the same issues and tried alot right now.
                Tried the
                dtoverlay=vc4-fkms-v3d as well as dtoverlay=vc4-kms-v3d as well as deleting that phrase
                I downgraded electron to npm install electron@1.4.15 since i found that helped in the V2.30 problems.
                I cant currently show the log from starting MagicMirror since i remotly access it and the MM just goes “all black” over the remote-access-page and I cant close it.
                I really just want to downgrad the MM to 2.3 since it worked absolutly fine with it…
                Additional software I use is MM-PIR
                  Mykle1 Project Sponsor Module Developer @Kastore
                  @kastore
                  https://github.com/MichMich/MagicMirror/releases
                  • K Offline
                    Kastore @Mykle1
                    @mykle1
                    Thanks Mykle1
                    Just how do i tell my pi to get the specific version? I am not versed in programming or coding or anything and couldnt find something online that told me how to install a specific version
                    • KimzerK Offline
                      Kimzer
                      Did anyone find a fix here? just updated and same thing here. Hopefully i can get this back working tomorrow.
                        @kastore
                        One way is to go to that link I gave you and download the version you want and install it manually.
                        • pyrosmileyP Offline
                          pyrosmiley
                          Bumping this because I’m also having issues. A lot of time on google says it’s not just a MagicMirror issue, but lots of people have problems with the OpenGL drivers. My screen is blanking after some time no matter what, but I also found the hard way that it messes with tvservice (like the Remote Control module uses) – turning my HDMI off straight up insta-shut down my pi! Gonna have to keep researching for sure.
                          • joela85J Offline
                            joela85
                            I just updated and this is shown at the end of the install.
                            MagicMirror installation successful!
                            > magicmirror@2.4.1 install-fonts /home/pi/MagicMirror
                            > cd fonts && npm install
                            npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed.
                            npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed.
                            npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed.
                            npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                            pi@raspberrypi:~/MagicMirror $
                            I applied
                            to the config.txt ( also tried with fkms)
                            Reboot and I get a black screen.
                            When I remove dtoverlay=vc4-kms-v3d then the mirror boots up.
                            Any suggestions?
                            • K Offline
                              Kastore @Mykle1
                              @mykle1
                              Just found your guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                              Going at it now and see if it works - thanks for the patience and writing that guide!
                                @kastore said in Black screen after MM v2.4.0 update.:
                                You’re welcome, sir. :-)
                                • KimzerK Offline
                                  Kimzer
                                  Got my mirror working again. Had to go over the opengl drivers again and using the fake kms driver did the trick. However one problem remains, i had to also disable the MMM-Pir-Sensor module because that was messing with the system. But also my custom.css is not being used atm, and i cant figure out why its not grabbing it.
                                  • KimzerK Offline
                                    Kimzer
                                    Anyone else struggling with using MMM-Pir-Sensor after the new update?
                                    • T Offline
                                      thenameiwantedwastaken @Kimzer
                                      Yes, I am having the same black screen. I have to disable PIR to be able to use MM at all. I also noted that after I installed PIR I could no longer SSH into the Pi from my desktop computer, whereas I could from my mobile phone. Anyway, the black screen is the main concern right now. I’ll post if I discover anything helpful.
                                      • G Offline
                                        grantc66
                                        Not sure if I’m having the same issue, stupidly updated electron as npm was claiming 1.7.13 had a critical vulnerability (after installing MMM-voice) Then got the backscreen issue. rolled back electron to 1.7.13 & the issue persists.
                                        Node v9.11.1
                                        npm 6.1.0
                                        Thought I’d uploaded the log file but not sure if others can see it. That snippet below is the first error after ALL_MODULES_STARTED
                                        13:01:19.440 main.js:40 Uncaught TypeError: Cannot read property ‘appendChild’ of undefined
                                        at main.js:40
                                        at Array.forEach ()
                                        at createDomObjects (main.js:24)
                                        at Object.modulesStarted (main.js:471)
                                        at startModules (loader.js:59)
                                        at loader.js:40
                                        at HTMLLinkElement.stylesheet.onload (loader.js:203)
                                        (anonymous) @ main.js:40
                                        createDomObjects @ main.js:24
                                        modulesStarted @ main.js:471
                                        startModules @ loader.js:59
                                        (anonymous) @ loader.js:40
                                        stylesheet.onload @ loader.js:203
                                        13:01:20.056 TypeError: Cannot read property ‘getElementsByClassName’ of null
                                        at moduleNeedsUpdate (main.js:176)
                                        at main.js:144
                                        at Promise ()
                                        at updateDomWithContent (main.js:137)
                                        at main.js:119
                                        at
                                        Promise rejected (async)
                                        (anonymous) @ main.js:121
                                        Promise resolved (async)
                                        (anonymous) @ main.js:118
                                        updateDom @ main.js:109
                                        updateDom @ main.js:514
                                        updateDom @ module.js:358
                                        Any pointers as to how to get it working again? It was working perfectly before MMM-voice & buggering around with electron.
                                        Tried a fresh install with the same result :(
                                          shane1234
                                          I’m also having the black screen of death. I tried both overlay options, and I tried commenting it out alltogether. I also ran the 2.4.1 update, but still getting black screen. Runs normally with the new update though when I comment out the PIR module in the config.js file.
                                            sdetweil @shane1234
                                            @shane1234 if u have the PIR module loaded, and do ctrl-shift-i (lower case letter i), it will open the debug env, and then select the console tab… do you see any errors?
                                            also, if u start from a terminal window, alt-spacebar, n will minimze the mirror screen so you can see the terminal window node_helper outputs… anything there?
                                            usually a module.js error kills with MM screen…
