    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 21.1k Views 17 Watching
      Mo
      I have a similar problem, after starting the MM the screen freezes, only way to unfreeze it is to close electron. Have tried both options too.
      After enabling either of the OpenGL drivers i get the followed errors:
      > magicmirror@2.4.0 start /home/pi/MagicMirror
      > sh run-start.sh
      libGL error: MESA-LOADER: failed to retrieve device information
      Starting MagicMirror: v2.4.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-Cursor.
      Module helper loaded: MMM-Buttons
      Module helper loaded: MMM-DWD-WarnWeather
      Module helper loaded: MMM-DHT-Sensor
      No helper found for module: helloworld.
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-MyWeather
      No helper found for module: MMM-SimpleLogo.
      Module helper loaded: MMM-PiLights
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-Buttons
      Starting node helper for: MMM-Buttons
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started...
      Connecting socket for: MMM-DHT-Sensor
      MMM-DHT-Sensor helper started ...
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-MyWeather
      MMM-WunderGround helper started ...
      Connecting socket for: MMM-PiLights
      [2018-07-03 15:42:24] [MMM-PiLights] Starting node_helper
      Launching application.
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
      (node:1057) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
      (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
      Edit: MM works without any OpenGL Drivers, but CPU usage is pretty high and the Node errors are still there.
        A Former User
        After 2.4.0, Asus Tinker Board cannot display MM. I think it might be related with this openGL issues. Is there any way to solve this?
        ATB has no openGL desktop driver like vc4-kms-v3d. Fake vc4-kms-v3d does not help.
        • joela85J Offline
          joela85
          I can’t access my mirror remotely anymore. Will I need to format my sd card and try again?
          • K Offline
            Kastore
            I am having the same issues and tried alot right now.
            Tried the
            dtoverlay=vc4-fkms-v3d as well as dtoverlay=vc4-kms-v3d as well as deleting that phrase
            I downgraded electron to npm install electron@1.4.15 since i found that helped in the V2.30 problems.
            I cant currently show the log from starting MagicMirror since i remotly access it and the MM just goes “all black” over the remote-access-page and I cant close it.
            I really just want to downgrad the MM to 2.3 since it worked absolutly fine with it…
            Additional software I use is MM-PIR
              Mykle1 Project Sponsor Module Developer @Kastore
              @kastore
              https://github.com/MichMich/MagicMirror/releases
              • K Offline
                Kastore @Mykle1
                @mykle1
                Thanks Mykle1
                Just how do i tell my pi to get the specific version? I am not versed in programming or coding or anything and couldnt find something online that told me how to install a specific version
                • KimzerK Offline
                  Kimzer
                  Did anyone find a fix here? just updated and same thing here. Hopefully i can get this back working tomorrow.
                    @kastore
                    One way is to go to that link I gave you and download the version you want and install it manually.
                    • pyrosmileyP Offline
                      pyrosmiley
                      Bumping this because I’m also having issues. A lot of time on google says it’s not just a MagicMirror issue, but lots of people have problems with the OpenGL drivers. My screen is blanking after some time no matter what, but I also found the hard way that it messes with tvservice (like the Remote Control module uses) – turning my HDMI off straight up insta-shut down my pi! Gonna have to keep researching for sure.
                      • joela85J Offline
                        joela85
                        I just updated and this is shown at the end of the install.
                        MagicMirror installation successful!
                        > magicmirror@2.4.1 install-fonts /home/pi/MagicMirror
                        > cd fonts && npm install
                        npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed.
                        npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed.
                        npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed.
                        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                        pi@raspberrypi:~/MagicMirror $
                        I applied
                        to the config.txt ( also tried with fkms)
                        Reboot and I get a black screen.
                        When I remove dtoverlay=vc4-kms-v3d then the mirror boots up.
                        Any suggestions?
                        • 1 / 4
