    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 21.7k Views 17 Watching
    • yawnsY Offline
      yawns Moderator
      According to another similar thread please set this instead:
      dtoverlay=vc4-fkms-v3d (with an additional f )
      • joela85J Offline
        joela85
        Thanks for the reply, I will try that when I get home.
          Charley Module Developer
          I also have a black screen.
          Tried both options
          and
          dtoverlay=vc4-kms-v3d
          MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
            Mo
            I have a similar problem, after starting the MM the screen freezes, only way to unfreeze it is to close electron. Have tried both options too.
            After enabling either of the OpenGL drivers i get the followed errors:
            > magicmirror@2.4.0 start /home/pi/MagicMirror
            > sh run-start.sh
            libGL error: MESA-LOADER: failed to retrieve device information
            Starting MagicMirror: v2.4.0
            Loading config ...
            Loading module helpers ...
            No helper found for module: MMM-Cursor.
            Module helper loaded: MMM-Buttons
            Module helper loaded: MMM-DWD-WarnWeather
            Module helper loaded: MMM-DHT-Sensor
            No helper found for module: helloworld.
            Module helper loaded: MMM-Remote-Control
            Module helper loaded: MMM-MyWeather
            No helper found for module: MMM-SimpleLogo.
            Module helper loaded: MMM-PiLights
            All module helpers loaded.
            Server started ...
            Connecting socket for: MMM-Buttons
            Starting node helper for: MMM-Buttons
            Connecting socket for: MMM-DWD-WarnWeather
            MMM-DWD-WarnWeather helper started...
            Connecting socket for: MMM-DHT-Sensor
            MMM-DHT-Sensor helper started ...
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
            Connecting socket for: MMM-MyWeather
            MMM-WunderGround helper started ...
            Connecting socket for: MMM-PiLights
            [2018-07-03 15:42:24] [MMM-PiLights] Starting node_helper
            Launching application.
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
            (node:1057) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
            (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
            Edit: MM works without any OpenGL Drivers, but CPU usage is pretty high and the Node errors are still there.
              A Former User
              After 2.4.0, Asus Tinker Board cannot display MM. I think it might be related with this openGL issues. Is there any way to solve this?
              ATB has no openGL desktop driver like vc4-kms-v3d. Fake vc4-kms-v3d does not help.
              • joela85J Offline
                joela85
                I can’t access my mirror remotely anymore. Will I need to format my sd card and try again?
                • K Offline
                  Kastore
                  I am having the same issues and tried alot right now.
                  Tried the
                  dtoverlay=vc4-fkms-v3d as well as dtoverlay=vc4-kms-v3d as well as deleting that phrase
                  I downgraded electron to npm install electron@1.4.15 since i found that helped in the V2.30 problems.
                  I cant currently show the log from starting MagicMirror since i remotly access it and the MM just goes “all black” over the remote-access-page and I cant close it.
                  I really just want to downgrad the MM to 2.3 since it worked absolutly fine with it…
                  Additional software I use is MM-PIR
                    Mykle1 Project Sponsor Module Developer @Kastore
                    @kastore
                    https://github.com/MichMich/MagicMirror/releases
                    • K Offline
                      Kastore @Mykle1
                      @mykle1
                      Thanks Mykle1
                      Just how do i tell my pi to get the specific version? I am not versed in programming or coding or anything and couldnt find something online that told me how to install a specific version
                      • KimzerK Offline
                        Kimzer
                        Did anyone find a fix here? just updated and same thing here. Hopefully i can get this back working tomorrow.
                        • 1 / 4
