    NFL Score Module
    95 Posts 20 Posters 137.4k Views 25 Watching
    • justjim1220J
      justjim1220 Module Developer
      BTW…
      I’ve tried to place 3 iFrames on one page, one to show each schedule in a live updated format. But I cannot figure out how to get it to work. Is it even possible to use the same module coded in 3 different ways to show on the same page??? :thinking_face: :thinking_face: :thinking_face:
      Jim Hallock - 1995
      • Mykle1M
        @cowboysdude
        You poor bastid. HAHAH
        • cowboysdudeC
          cowboysdude Module Developer @Achilles
          @achilles said in NFL Score Module:
          Thanks cowboysdude!
          If it isnt set up for Preseason, than that would make sense. Regular season, here I come!
          You’re welcome! Trust me it’s a great module!!!
          • cowboysdudeC
            cowboysdude Module Developer @justjim1220
            @justjim1220 It’s not setup to show any preseason games…on the Github page it shows config options and this is one of them:
            `focus_on	 Display only matches with teams of this array e.g. ['NYG', 'DAL', 'NE'].`
            This is how it’s used:
                     module: 'MMM-NFL',
                     position: 'top_right',
                     focus_on:  ['NYG', 'DAL', 'NE']  //JUST an example to show ONLY those 3 teams
            justjim1220J 1 Reply Last reply
            • justjim1220J
              justjim1220 Module Developer @cowboysdude
              @cowboysdude
              Ok, here’s a screen shot of what it looks like…
              As you can see… It says ‘NFL Pre-Season 2017’ in the header.
              the actual list of games are from the final regular season week of 2017.
              It doesn’t show, in the Readme regarding any modes to use in the config.
              added the ‘focus_on’ in the config, nothing changed…
              which by the way, is also not explained or covered in the Readme,
              I’ve had this module for quite a while now, have never been informed of any changes.
              But, I decided to trash it and restart it with a fresh install of the module…
              I noticed several differences in the first one I had and the current one…
              the files of the one I’ve had for a while…
              the files of the one I downloaded and installed a little while ago…
              this is the difference of the MMM-NFL.js files…
              the latest one shows modes for Pre-Season, Regular-Season, & Post-Season…
              If I use the modes, Pre & Post, I get a blank mirror, and this error in my terminal…
              here’s what it looks like with the 'Regular-Season" mode and the ‘focus_on’ added in the config…
              I also get a blank screen with the same error in my terminal when leaving out the mode and the focus_on.
              So, now you can see why I have had so many problems with it!
              Jim Hallock - 1995
              • justjim1220J
                After further research, I found that the dependencies needed to be manually installed.
                this fixed the blank pages problem.
                Jim Hallock - 1995
                • cowboysdudeC
                  focus_on has been there for over a year…so not sure what readme you’re looking at but on Github it is clearly in the readme and has been…
                  `   Config Options
                      Option	Default	Description
                      colored	false	Remove black/white filter of logos/helmets.
                      helmets	false	Show helmets instead of logo.
                      focus_on	false	Display only matches with teams of this array e.g. ['NYG', 'DAL'].
                      format	'ddd h:mm'	In which format the date should be displayed. All Options
                      reloadInterval	1800000 (30 mins)	How often should the data be fetched
                  As for pre season scores…it’s impossible. It uses one of two urls for the data and neither show pre season…they show reg or post season…
                  So A. Either you’ve changed something or B. you’re not using this module…
                  I know this module like it was my own… it doesn’t do Pre Season football. I’m looking at the raw data…the regular and post season scores are from 2017…
                  • justjim1220J
                    @cowboysdude
                    I think I figured it out…
                    I’ve been getting it from your repository list and not from the 3rd party list. Look at them and you’ll see the same differences I have been experiencing
                    Jim Hallock - 1995
                    • Mykle1M
                      Dimensional shift in progress.
                      • cowboysdudeC
                        @justjim1220 said in NFL Score Module:
                        @cowboysdude
                        ALWAYS go to the source just in case there have been changes…
                        D 1 Reply Last reply
                          darbos @cowboysdude
                          @cowboysdude Hey again, I believe Im reading this right, so the 2017 is normal for now (module doesnt track preseason) and when the regular season starts we will start seeing the 2018 games/scores? No need to update any links or anything? Thanks!
                          • cowboysdudeC
                            cowboysdude Module Developer @darbos
                            @darbos said in NFL Score Module:
                            Yes sir that’s exactly what will happen :)
                            Reply Quote 2
                              darbos @cowboysdude
                              @cowboysdude Good stuff! Thank you sir!
                              • A
                                Achilles
                                Anyone else’s module not update today? I still have NFL 2017 Regular Season showing…
                                  sgault @Achilles
                                  @achilles
                                  Same here. I was hoping it would update but no go. I look at the url that it goes out to check and it appears that NFL.com isn’t updating it. I’m wondering if developer of this module may need to do some tweeking or instructions so we as users can.
                                  • strawberry 3.141S
                                    There are several options (good and bad ones), but I’m busy. Therefore I will wait at least until this weekend, before I take an action here. Getting a new api most of the times also means rewriting most of the module which is time intensive. Maybe there are also volunteers.
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                      @strawberry-3-141 said in NFL Score Module:
                                      :thumbsup:
                                      • G
                                        gama
                                        According to Stackoverflow the xml service is discontinued and is now using JSON for the 2018 season. Here’s the JSON file http://www.nfl.com/liveupdate/scores/scores.json
                                        G 1 Reply Last reply
                                        • G
                                          gama @gama
                                          @gama said in NFL Score Module:
                                          Just noticed that someone replied with an AJAX version that appeared to have the same output as the XML file. I plugged it in to the node_helper.js file and it works!
                                          Here’s the AJAX version http://www.nfl.com/ajax/scorestrip?season=2018&seasonType=REG&week=1
                                          justjim1220J strawberry 3.141S 2 Replies Last reply
                                          • justjim1220J
                                            justjim1220 Module Developer @gama
                                            @gama
                                            Could you explain how you 'plugged it into the node_helper.js file?
                                            I would greatly appreciate it!
                                            TIA!!!
                                            Jim Hallock - 1995
                                            • 4 / 5
