    MMM-WeatherBackground
    54 Posts 14 Posters 36.4k Views 14 Watching
      A Former User
      MagicMirror Module - for Weather image background from Unsplash. This is a plugin of other weather modules.
      Screenshot
      Screenshot
      Details
      [card:eouia/MMM-WeatherBackground]
      1 Reply Last reply Reply Quote 4
        jeffreyking
        very good I have it in stalled, how can I get it to work with MMM-NOAA3 ?
        ? Mykle1M 2 Replies Last reply Reply Quote 0
          A Former User @jeffreyking
          @jeffreyking
          Tell @cowboysdude to support “CURRENTWEATHER” notification.
            Mykle1 Project Sponsor Module Developer @jeffreyking
            @jeffreyking
            Tell = request :-)
            ? 1 Reply Last reply Reply Quote 1
              A Former User @Mykle1
              @mykle1
              Sorry. I’m not native Eng user, so many times Making mistakes. :)
                Mykle1 Project Sponsor Module Developer @Guest
                @sean
                No worries, sean. You’re still the king! :-)
                • cowboysdudeC Offline
                  Well hello all…no NOAA wasn’t made to support ‘currentweather’ notifications in MM.
                  It’s a stand alone module and I am SUPER busy so as of right now I have no plan to do anything with it. I do this for a hobby…I must pay attention to my real job as I’ve grown accustomed to things like food and shelter… ;) Perhaps in the next few weeks I could look at it but that is if I have time.
                  • T Offline
                    texdetex
                    @sean in trying to install module but im ask for User/Password
                      A Former User @texdetex
                      @texdetex ??? It will not ask any kind of user or password. ???
                      • V Offline
                        Vauxdvihl
                        @Sean
                        I am using NOAA3 and i simply add the the following lines the my config:
                          module: "MMM-WeatherBackground",
                          // don't assign position.
                          config: {}
                        Unfortunately the background is still black.
                        Is ther something else to consider?
                        Thanks a lot
                        Regards
                          A Former User @Vauxdvihl
                          @vauxdvihl NOAA isn’t supported.
                          • V Offline
                            Vauxdvihl @Guest
                            @sean
                            r u sure.
                            https://forum.magicmirror.builders/topic/4585/mmm-noaa-another-weather-module/520?page=52
                            Greetz
                              @vauxdvihl ah, he made it.
                                @vauxdvihl
                                I think his version https://github.com/cowboysdude/MMM-WeatherBackground will be work. I don’t know it is completed or not, but you can try it.
                                  This a fork of @Sean great work but remade to work with NOAA3.
                                  [card:cowboysdude/MMM-WeatherBackground]
                                  • V Offline
                                    Vauxdvihl
                                    @cowboysdude
                                    Does not work
                                    Mirror stays black
                                    Here is the error message
                                    /home/pi/.pm2/logs/start-error.log last 15 lines:
                                    0|start    |     at Module.load (module.js:561:32)
                                    0|start    | { Error: Cannot find module 'dayjs'
                                    0|start    |     at Module._resolveFilename (module.js:543:15)
                                    0|start    |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                    0|start    |     at Function.Module._load (module.js:473:25)
                                    0|start    |     at Module.require (module.js:586:17)
                                    0|start    |     at require (internal/module.js:11:18)
                                    0|start    |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-WeatherBackground/node_helper.js:7:15)
                                    0|start    |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-WeatherBackground/node_helper.js:49:3)
                                    0|start    |     at Module._compile (module.js:642:30)
                                    0|start    |     at Object.Module._extensions..js (module.js:653:10)
                                    0|start    |     at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
                                    0|start    | libGL error: MESA-LOADER: failed to retrieve device information
                                    0|start    | MESA-LOADER: failed to retrieve device information
                                    Any Idea?
                                    Thanks a lot
                                      @vauxdvihl
                                      I think it wasn’t installed properly. (@cowboysdude might have forgotten npm install in his description.)
                                      cd ~/MagicMirror/modules/MMM-WeatherBackground
                                      npm install
                                      try again.
                                      V cowboysdudeC 2 Replies Last reply Reply Quote 1
                                      • V Offline
                                        Vauxdvihl @Guest
                                        @sean
                                        That was it
                                        Works
                                        Thanks a lot
                                          cowboysdude Module Developer @Guest
                                          @sean said in MMM-WeatherBackground:
                                          @vauxdvihl
                                          npm install
                                          try again.
                                          Thank you @Sean that’s exactly what I did LOL the Readme is corrected, Thank you!!
                                            buzzman
                                            @cowboysdude
                                            i get this error when i do npm install
                                            i@Magicmirror:~/MagicMirror/modules/MMM-WeatherBackground $ npm install
                                            npm WARN mmm-weatherbackground@3.0.1 No repository field.
                                            audited 63 packages in 3.748s
                                            found 0 vulnerabilities
                                            i get this error also
                                            No helper found for module: MMM-WeatherBackground
                                            i am using NOAA3 also
                                            B Mykle1M 2 Replies Last reply Reply Quote 0
