    MMM-MyCalendar
    109 Posts 40 Posters 163.6k Views 38 Watching
    • F Offline
      fabbr @ninjabreadman
      @ninjabreadman Thank, that didn’t work however, I found the file MMM-MyCalendar.css and there I changed this and got my problem solved, thank you !!!
      .MMM-MyCalendar {
        max-width: 250px;  //original was 500
        j.e.f.f Project Sponsor Module Developer @fabbr
        @fabbr you’re better off putting this change in custom.css. If you update the module down the road, the change you made will be overwritten.
        A better solution here is to revert your change and set a width for the container, like as follows:
        region.left,
        region.left .module-content {
          width: 250px;
          max-width: 250px;
          min-width: 250px;
        This will size the entire left column to 250px, including anything you put in top_left, bottom_left, etc. If you want to limit it to just top_left replace region.left with region.top.left.
        F 1 Reply Last reply Reply Quote 2
        • F Offline
          fabbr @j.e.f.f
          @j.e.f.f I agree with you, however for some reason I can’t make that work. Did those changes worked on your custom.css? if yes, would you mind sharing your code with me? I might be doing something wrong.
            @fabbr Try also setting a maximum width for MMM-MyCalendar in your custom.css file as well. Here is exactly what I have in my custom.css file:
            .region.left,
            .region.left .module-content {
              width: 555px;
              max-width: 555px;
              min-width: 555px;
            .MMM-MyCalendar {
              max-width: 555px;
            Adjust 555px to whatever you like.
            • F Offline
              fabbr @j.e.f.f
              @j.e.f.f Very strange mine is completely ignoring the CSS. No change is made on the screen. Here’s my CSS:
               body {
                		 .region.left,
               			  width: 555px;
              			  max-width: 555px;
              			  min-width: 555px;
              		.MMM-MyCalendar {
              			  max-width: 555px;
              N F 2 Replies Last reply Reply Quote 0
              • N Offline
                ninjabreadman @fabbr
                @fabbr You can’t nest the braces in CSS. Just take out the body { and last } entirely.
                • F Offline
                  fabbr @fabbr
                  @fabbr LoL
                  Body {
                  Was there, no I was under the impression all the changed were going to be inside the brackets. Sorry it was always my fault. Thank you so much for the help. It now works perfectly!
                    Mike7400
                    Is it possible to change the color of title and date for each calendar?
                    • H Offline
                      himanshulotia
                      Just newbie over here. I have used MMM-Mycalendar module to show two different calendar on two separate area of the mirror (bottom_left & bottom_right)
                      I want heading on each calendar to have different color and if possible icon as well.
                      Is this possible?
                      • twosquirrelsT Offline
                        twosquirrels
                        This module just won’t display a 2-column layout for me despite it being enabled in the config:
                                module: "MMM-MyCalendar",
                                header: "Family Calendar",
                                position: "top_left",    // This can be any of the regions. Best results in left or right regions.
                        colored: true,
                        maximumEntries: 6,
                        columns: true,
                        showLocation: false,
                        maxTitleLength: 200,
                        fetchInterval: 120000,
                        fade: false,
                        • N Offline
                          ninjabreadman @twosquirrels
                          @twosquirrels Does MMM-MyCalendar support a column layout? I can’t find any reference to a columns property for its config: https://github.com/jclarke0000/MMM-MyCalendar/blob/master/README.md
                          twosquirrelsT 1 Reply Last reply Reply Quote 0
                            twosquirrels @ninjabreadman
                            @ninjabreadman Page 1 contains an update where it mentions support for 2 columns:
                            https://forum.magicmirror.builders/topic/2559/mmm-mycalendar?page=1
                            alt text
                            • N Offline
                              ninjabreadman @himanshulotia
                              @himanshulotia Yes.
                              First, you can set colored: true in the config, then add color: "#d9b4b2” and color: "#a0cfe2" per the docs.
                              Second, have a look at the FontAwesome 4 docs. You could likely insert them into your headings. For how to insert images, you could probably use CSS if you can find the right selectors.
                              • N Offline
                                @twosquirrels It looks like you need to use the using_nunjucks branch. The default branch is still (it seems to me, on my phone) 1.0 – it doesn’t contain an .njk template file.
                                  @ninjabreadman
                                  Ahh, I see. Silly question - how do I pull from that branch instead of from the master? I googled the differences but it’s not making sense to me.
                                  AHH! I figured it out:
                                  pi@magicmirror:~/MagicMirror/modules $ git clone -b using_nunjucks https://github.com/jclarke0000/MMM-MyCalendar.git
                                  Cloning into 'MMM-MyCalendar'...
                                  remote: Counting objects: 84, done.
                                  remote: Total 84 (delta 0), reused 0 (delta 0), pack-reused 84
                                  Unpacking objects: 100% (84/84), done.
                                  @ninjabreadman thank you for pointing this out!
                                    smreid
                                    Hi
                                    Just wondering if there is anyway I can use custom symbols for calendar entries in place of the ‘day of the month’ logos? Similar to the default calendar module?
                                    Stephen
                                      cola0927
                                      Hi, it’s really a nice module, but got a small issue here. I’m wondering how to make the event contents left-aligned. I tried to modify some parameters in MMM-MyCalendar.css, but didn’t work.
                                      Thanks!
                                      • justjim1220J Offline
                                        justjim1220 Module Developer @cola0927
                                        @cola0927
                                        change the text-align under title in the css
                                        .MMM-MyCalendar .title {
                                          color: #ff0;
                                          font-size: 55px;
                                          line-height: 115%;
                                          font-weight: 600;
                                          text-align: left;
                                          padding-left: 0;
                                          margin-bottom: 2px;
                                          white-space: nowrap;
                                          text-overflow: ellipsis;
                                          border-radius: 15px;
                                          overflow: hidden;
                                          display: block;
                                          margin-top: 4px;
                                        Jim Hallock - 1995
                                          cola0927 @justjim1220
                                          @justjim1220 Cool! Thank you so much!
                                          • H Offline
                                            hoveeman
                                            This module is great! Thank you!
                                            Is it possible to add a header/title for the day of the week with the items below it? Essentially you would see Monday and the corresponding items below it. Then Tuesday and it’s items, and so forth.
                                            Any thoughts?
                                            • 4 / 6
