    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 147.5k Views 25 Watching
    • H Offline
      HanSolo
      Hi Guys,
      first kudos to all of you. The Magic Mirror is great. However, I have a problem with the module of the PIR sensor. I installed the mirror with the standard modules and it worked right away.
      Now I have integrated the PIR sensor module according to the instructions. When I start the mirror,I see only a completely white screen.
      What am I doing wrong or what can be wrong.
      If I do not write the module in the config.js, the mirror works again without problems.
      Thanks and best regards
      HanSolo
      • RedNaxR Offline
        RedNax Module Developer
        On my tv simply issuing
        tvservice -p
        wouldn’t work as it does on my monitor/mirror resulting in a white screen. Adding
        fbset -depth 8
        fbset -g 1920 1080 1920 1080  16
        solved it for me…
        • yawnsY Offline
          yawns Moderator
          If you start the magic mirror with “npm start” in the console, do you see any error messages?
          zamZ 1 Reply Last reply Reply Quote 0
          • zamZ Offline
            zam
            Same issue with me … Any solutions guys ???
            Zam
            • zamZ Offline
              zam @yawns
              @yawns Evan npm start same white screen … Any idea ??
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @zam
                @zam start with npm start dev and report if there is an error or in the terminal
                • zamZ Offline
                  zam @strawberry 3.141
                  @strawberry-3.141
                  Loading config ...
                  Loading module helpers ...
                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
                  App threw an error during load
                      at Error (native)
                      at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                      at Object.Module._extensions..node (module.js:568:18)
                      at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                      at Module.load (module.js:458:32)
                      at tryModuleLoad (module.js:417:12)
                      at Function.Module._load (module.js:409:3)
                      at Module.require (module.js:468:17)
                      at require (internal/module.js:20:19)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/lib/exports.js:1:97)
                      at Error (native)
                  Launching application.
                    @zam https://github.com/paviro/MMM-PIR-Sensor/issues/9 looks like it’s a problem with the library
                    Edit: https://github.com/paviro/MMM-PIR-Sensor/issues/2
                    • BangeeB Offline
                      Bangee Module Developer
                      which version is the latest running with this PIR sensor?
                        strawberry 3.141 Project Sponsor Module Developer @Bangee
                        @Bangee doesn’t matter anymore paviro exchanged the wiring-pi library to onoff
                        • BangeeB Offline
                          so what will I have to do? I’ve removed the MMM-PIR-Module and reinstalled it, but i’ve got still these error… :-(
                            @Bangee so after the change of the library you still get Error: Module version mismatch. Expected 49, got 48.?
                            • BangeeB Offline
                              Yes… so I’m quiet pissed off… I think I need to reinstall my MM…
                              mm-0 Loading config ...
                              mm-0 Loading module helpers ...
                              mm-0 No helper found for module: alert.
                              mm-0 WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
                              mm-0 App threw an error during load
                              mm-0 Error: Module version mismatch. Expected 49, got 48.
                              mm-0     at Error (native)
                              mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                              mm-0     at Object.Module._extensions..node (module.js:568:18)
                              mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                              mm-0     at Module.load (module.js:458:32)
                              mm-0     at tryModuleLoad (module.js:417:12)
                              mm-0     at Function.Module._load (module.js:409:3)
                              mm-0     at Module.require (module.js:468:17)
                              mm-0     at require (internal/module.js:20:19)
                              mm-0     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                              mm-0 Whoops! There was an uncaught exception...
                              mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              mm-0 Launching application.
                                @Bangee did you change your node version at some point?
                                • BangeeB Offline
                                  yes, but this was befor the reinstallation
                                  so now I try npm rebuild
                                  • BangeeB Offline
                                    atm I am using node 5.12.0
                                    Which node are u using?
                                    EDIT
                                    I’ was wrong… I’ve forgot to activate the module in my configuration…
                                    strawberry 3.141S paviroP 2 Replies Last reply Reply Quote 0
                                      @Bangee I’m using 6.4.0 but I got no pir sensor
                                      • paviroP Offline
                                        paviro @Bangee
                                        @Bangee so doesn’t the new version work now?
                                        – The Doctor
                                        • BangeeB Offline
                                          Unfortunatly no… :-(
                                          I’ve tried many differet versions of of node…
                                            McSorley
                                            Still a no go for me.
                                            • 1 / 5
