    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 156.1k Views 25 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @zam
      @zam start with npm start dev and report if there is an error or in the terminal
      Z 1 Reply Last reply
      • Z
        zam @strawberry 3.141
        @strawberry-3.141
        Loading config ...
        Loading module helpers ...
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
        App threw an error during load
            at Error (native)
            at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
            at Object.Module._extensions..node (module.js:568:18)
            at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
            at Module.load (module.js:458:32)
            at tryModuleLoad (module.js:417:12)
            at Function.Module._load (module.js:409:3)
            at Module.require (module.js:468:17)
            at require (internal/module.js:20:19)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/lib/exports.js:1:97)
            at Error (native)
        Launching application.
        • strawberry 3.141S
          @zam https://github.com/paviro/MMM-PIR-Sensor/issues/9 looks like it’s a problem with the library
          Edit: https://github.com/paviro/MMM-PIR-Sensor/issues/2
            Bangee Module Developer
            which version is the latest running with this PIR sensor?
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Bangee
              @Bangee doesn’t matter anymore paviro exchanged the wiring-pi library to onoff
                so what will I have to do? I’ve removed the MMM-PIR-Module and reinstalled it, but i’ve got still these error… :-(
                • strawberry 3.141S
                  @Bangee so after the change of the library you still get Error: Module version mismatch. Expected 49, got 48.?
                    Yes… so I’m quiet pissed off… I think I need to reinstall my MM…
                    mm-0 Loading config ...
                    mm-0 Loading module helpers ...
                    mm-0 No helper found for module: alert.
                    mm-0 WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 49, got 48.
                    mm-0 App threw an error during load
                    mm-0 Error: Module version mismatch. Expected 49, got 48.
                    mm-0     at Error (native)
                    mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
                    mm-0     at Object.Module._extensions..node (module.js:568:18)
                    mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
                    mm-0     at Module.load (module.js:458:32)
                    mm-0     at tryModuleLoad (module.js:417:12)
                    mm-0     at Function.Module._load (module.js:409:3)
                    mm-0     at Module.require (module.js:468:17)
                    mm-0     at require (internal/module.js:20:19)
                    mm-0     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                    mm-0 Whoops! There was an uncaught exception...
                    mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    mm-0 Launching application.
                    • strawberry 3.141S
                      @Bangee did you change your node version at some point?
                        yes, but this was befor the reinstallation
                        so now I try npm rebuild
                          atm I am using node 5.12.0
                          Which node are u using?
                          EDIT
                          I’ was wrong… I’ve forgot to activate the module in my configuration…
                          strawberry 3.141S P 2 Replies Last reply
                          • strawberry 3.141S
                            @Bangee I’m using 6.4.0 but I got no pir sensor
                              paviro @Bangee
                              @Bangee so doesn’t the new version work now?
                              – The Doctor
                                Unfortunatly no… :-(
                                I’ve tried many differet versions of of node…
                                  McSorley
                                  Still a no go for me.
                                    James
                                    The same issue with me, even after a totally re-installation.
                                    @paviro Could you do us a favor to compatible with and get the module work?
                                    Thank you.
                                    P 1 Reply Last reply
                                    Reply Quote -1
                                      paviro @James
                                      @James please dont be that demanding! You can always fix it yourself if you need it now. I don’t currently have a mirror so I can’t run it on a real Pi and therefore test it but I will see what I can do on the weekend.
                                      – The Doctor
                                      • K
                                        KirAsh4 Moderator
                                        Folks, please keep in mind that all of us have jobs, some of us are still in school, all of us have a life, all of us have other things to do that is not MagicMirror. I know that @paviro has moved recently and is still settling down into a new place. MagicMirror is probably far lower on the list of things to do at the moment for him. I’ve had a bad life event happen recently and have been absent from everything this past month or so and am just now starting to catch up on things. I’m not ready to jump into anything right away. Some days I’m perfectly fine, other days I’m doubled over crying somewhere, unable to do anything, and this is no joke. And @MichMich, I can’t even imagine all the things he does that we don’t know (and I’m not even talking about his harem.)
                                        Point is, there are several aspects of the code that we are aware of that will need some debugging, fixing, or perhaps simply light on fire and start over. I know that, and I’m sure the other guys know that too. Free time isn’t something that we have in abundance. It comes when it comes, and I try to make use of it when I have it. I can’t speak for the others.
                                        A little patience will go along way. I am certain @paviro will get to coding again when he’s available to do that. And eventually, I too will do the same. For now though, just try to keep the boat floating and stick your fingers into any leak you see springing up …
                                        Reply Quote 5
                                          McSorley
                                          I made an attempt at fixing it but I struggled to find many JavaScript/Node.js tutorials out there. I have however managed to compile a straight forward script in Python that I have set up to run with pm2. A workaround for those who are in high demand for the motion sensor to work and to give paviro some breathing space.
                                          Sorry but I don’t know how to add this as code snippets. If a mod could help me out that that would be great.
                                          Open Python 3. File > New. Paste this code in.
                                          from gpiozero import MotionSensor
                                          import os
                                          pir = MotionSensor(4) #4 is the Pin?
                                          while True:
                                              if pir.wait_for_motion(timeout=10*60): #10 * 60 Seconds
                                                  os.system("/opt/vc/bin/tvservice -p")
                                              else:
                                                  os.system("/opt/vc/bin/tvservice -o")
                                          You can if you want edit
                                          to
                                          print("Motion Detected")
                                          to test if your PIR Sensor is working ok. After changing it, save it and press Ctrl + F5 to run the code. It will then spam up with motion detect or undetected depending on what you’ve changed.
                                          Moderator’s note: You can use backticks (`) to highlight code. Check out the help at http://commonmark.org/help/ - scroll down to see the various options for using backticks.
                                            paviro
                                            Hi there,
                                            I think I fixed the problems now, feel free to give it a try :)
                                            Cheers,
                                            Paul
                                            – The Doctor
                                            J 1 Reply Last reply
                                            • 1 / 5
