    690 Posts 77 Posters 3.3m Views 70 Watching
    • justjim1220J
      justjim1220 Module Developer @cowboysdude
      @cowboysdude
      Jim Hallock - 1995
      • G
        Galm @cowboysdude
        @cowboysdude : thanks a lot ;) Football first
        • justjim1220J
          justjim1220 Module Developer @Vauxdvihl
          @vauxdvihl
          I made it bigger by changing the font and image values in the css file I use. WHich, I use the CSS4 option.
          Jim Hallock - 1995
            PILuke
            has someone tested the NOAA3 module with accuweather provider?
            I think something is wrong to identify the city with lan and long.
            With this config I don’t see any weather information from the module, only air quality:
            			disabled: false,
            			module: 'MMM-NOAA3',
            		 	position: 'top_right',
            				provider: "accuweather",
            				apiKey: "xxxxxxxxxxxx",
            				airKey: "yyyyyyyyy",
            				css: "NOAA3",                  // THIS MUST CONTAIN A CSS STYLE NAME
            				userlat: "45.483219", //MUST HAVE BOTH
            				userlon: "9.203567"  //MUST HAVE BOTH
            In the aw.js file I find this request:
            url =  "http://dataservice.accuweather.com/currentconditions/v1/"+zip+"?apikey="+this.config.apiKey+"&details=true";
            I think this request doesn’t pass the correct “location key” (the zip value).
            Infact if I manually force a “location key” the “current conditions” start to work:
            url =  "http://dataservice.accuweather.com/currentconditions/v1/214046?apikey="+this.config.apiKey+"&language="+config.language+"-it&details=true";
            This instead doesn’t work for the forecast, if I force the “location key” the module doesn’t show the “four day forecast”
            url: "http://dataservice.accuweather.com/forecasts/v1/daily/5day/214046?apikey="+this.config.apiKey+"&language="+config.language+
            "-us&details=true&metric=false",
            I found also another problem with the language because in the request is passed the right language but not the right region, it remains “us”, so the module doesn’t show any value :
            &language="+config.language+"-us&details=true&metric=false"
            Can someone resolve the problem?
            I’m not so able with js :-)
            cowboysdudeC 2 Replies Last reply
            • cowboysdudeC
              cowboysdude Module Developer @PILuke
              @piluke I will look into it. However the one problem AW provider does have is at times when you’re just starting the module you have to reload it to get the 4 day forecast…why, I’m not really sure it’s just how it’s been working.
              I’ve made some changes but a few more need to be made here’s an example of the update:
              P 1 Reply Last reply
              • cowboysdudeC
                @piluke the updated aw.js is uploaded to git hub.
                Do a git pull and the config has changed to include your zip…
                REMEMBER YOU MAY HAVE TO RELOAD IT TO GET THE BOTTOM FORECAST…tis an accuweather issue…
                			disabled: false,
                				css: "NOAA3",
                				userlon: "9.203567"
                			        zip: "11111" //YOUR ZIPCODE
                • cowboysdudeC
                  Still working on openweather api as time permits…it’s a complete train wreck LOL
                  Something has changed…but I am working to fix it.
                    PILuke @cowboysdude
                    @cowboysdude many many thanks for your help and your time.
                    Now the module is working.
                    I can see current conditions and forecast (without reload the page) but … they are not correct. :-)
                    I make some test, with my zip code the aw system identify a city in Mexico not in Italy!
                    I think it’s necessary to identify a single locationKey with aw API.
                    I found three way:
                    by lat and lon:
                    https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/geoposition/search
                    or by zip code:
                    https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/postalcodes/search
                    or by name:
                    https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/search
                    but i don’t know how to use it in javascript…
                    Infact if I put (in config.js) the right locationKey for my city instead zipcode the module work perfectly.
                    • cowboysdudeC
                      @piluke Okay so use your location key LOL
                      • G
                        gh057
                        @cowboysdude thank you for your module, the ability to use the module with various providers is really something that makes a difference!
                        Would you consider adding a wind direction (icon or text) in a future update ?
                          PILuke @cowboysdude
                          @cowboysdude yes, of course :-)
                          It’s better to modify the README.md for not to use a zip code but a Locationkey from accuweather in the config file.
                          Many thanks
                          • cowboysdudeC
                            @piluke You could always do a pull request to modify the readme on github ;)
                            • cowboysdudeC
                              Just updated OpenWeather and the main js…had issues with the forecast NOT loading…it’s all working now. :)
                              In a terminal window go to:
                              MagicMirror/modules/MMM-NOAA3
                              type ‘git pull’ to update!
                              J 1 Reply Last reply
                                Johans @cowboysdude
                                @cowboysdude
                                As always, great job!
                                Didn’t noticed and I don’t know if it has to do with the upgrade or not.
                                saw this message in the terminal window, but all seems to work fine for me.
                                Just wanted to let you know.
                                TypeError: Cannot read property 'pollution' of undefined
                                    at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:179:35)
                                    at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:171:28)
                                    at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                                    at emitTwo (events.js:126:13)
                                    at Request.emit (events.js:214:7)
                                    at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                                    at emitOne (events.js:116:13)
                                    at Request.emit (events.js:211:7)
                                    at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                                    at Object.onceWrapper (events.js:313:30)
                                • cowboysdudeC
                                  cowboysdude Module Developer @Johans
                                  @johans said in MMM-NOAA - Another Weather Module:
                                  @cowboysdude
                                  Thank you sir!! Yes that happens at times with the air quality part…it usually fixes itself :)
                                    Johans @cowboysdude
                                    @cowboysdude
                                    OK, than I don’t need to worry.
                                      rob2791
                                      Hey guys, I got this up and running tonight, Great work on this!
                                      I’m only having one problem, the 4 day forecast doesn’t seem to load every time I start mm. It seems to only show the forecast once every four or so times i restart mm without any config changes, just a simple pm2 restart mm. Anyone else seen this?
                                      • H
                                        Hubschra01
                                        Hi
                                        I do the Gitpull to Update this modul but in the CLI indows i got this…
                                        TypeError: Cannot read property 'length' of undefined
                                            at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:179:42)
                                            at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:51:17)
                                        { coord: { lon: 10.36, lat: 53.42 },
                                          weather:
                                           [ { id: 701, main: 'Mist', description: 'Trüb', icon: '50n' },
                                             { id: 300,
                                               main: 'Drizzle',
                                               description: 'Leichtes Nieseln',
                                               icon: '09n' } ],
                                          base: 'stations',
                                          main: { temp: 9, pressure: 1017, humidity: 87, temp_min: 9, temp_max: 9 },
                                          visibility: 7000,
                                          wind: { speed: 3.6, deg: 110 },
                                          clouds: { all: 75 },
                                          dt: 1541352000,
                                          sys:
                                           { type: 1,
                                             message: 0.004,
                                             country: 'DE',
                                             sunrise: 1541312654,
                                             sunset: 1541345954 },
                                          cod: 200 }
                                            at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:264:35)
                                            at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:111:27)
                                        Shutting down server...
                                        I do not find the icon: '50n' and icon: '09n' in the images folder !?!
                                        • cowboysdudeC
                                          cowboysdude Module Developer @rob2791
                                          @rob2791 it is a glitch that happens with certain providers…not sure why.
                                          • cowboysdudeC
                                            cowboysdude Module Developer @Hubschra01
                                            @hubschra01 And you won’t find those icons…it runs off an icon array in the main js file.
                                            From time to time depending on which service is being requested it can return an undefined. There are so many things at play in this module. Just reload it and it should work. :)
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 34
                                            • 35
                                            • 28 / 35
