    690 Posts 77 Posters 3.0m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @PILuke
      @piluke Okay so use your location key LOL
      • G Offline
        gh057
        @cowboysdude thank you for your module, the ability to use the module with various providers is really something that makes a difference!
        Would you consider adding a wind direction (icon or text) in a future update ?
          PILuke @cowboysdude
          @cowboysdude yes, of course :-)
          It’s better to modify the README.md for not to use a zip code but a Locationkey from accuweather in the config file.
          Many thanks
            @piluke You could always do a pull request to modify the readme on github ;)
              Just updated OpenWeather and the main js…had issues with the forecast NOT loading…it’s all working now. :)
              In a terminal window go to:
              MagicMirror/modules/MMM-NOAA3
              type ‘git pull’ to update!
                Johans @cowboysdude
                @cowboysdude
                As always, great job!
                Didn’t noticed and I don’t know if it has to do with the upgrade or not.
                saw this message in the terminal window, but all seems to work fine for me.
                Just wanted to let you know.
                TypeError: Cannot read property 'pollution' of undefined
                    at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:179:35)
                    at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:171:28)
                    at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                    at emitTwo (events.js:126:13)
                    at Request.emit (events.js:214:7)
                    at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                    at emitOne (events.js:116:13)
                    at Request.emit (events.js:211:7)
                    at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                    at Object.onceWrapper (events.js:313:30)
                  cowboysdude Module Developer @Johans
                  @johans said in MMM-NOAA - Another Weather Module:
                  @cowboysdude
                  Thank you sir!! Yes that happens at times with the air quality part…it usually fixes itself :)
                    Johans @cowboysdude
                    @cowboysdude
                    OK, than I don’t need to worry.
                      rob2791
                      Hey guys, I got this up and running tonight, Great work on this!
                      I’m only having one problem, the 4 day forecast doesn’t seem to load every time I start mm. It seems to only show the forecast once every four or so times i restart mm without any config changes, just a simple pm2 restart mm. Anyone else seen this?
                      • H Offline
                        Hubschra01
                        Hi
                        I do the Gitpull to Update this modul but in the CLI indows i got this…
                        TypeError: Cannot read property 'length' of undefined
                            at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:179:42)
                            at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:51:17)
                        { coord: { lon: 10.36, lat: 53.42 },
                          weather:
                           [ { id: 701, main: 'Mist', description: 'Trüb', icon: '50n' },
                             { id: 300,
                               main: 'Drizzle',
                               description: 'Leichtes Nieseln',
                               icon: '09n' } ],
                          base: 'stations',
                          main: { temp: 9, pressure: 1017, humidity: 87, temp_min: 9, temp_max: 9 },
                          visibility: 7000,
                          wind: { speed: 3.6, deg: 110 },
                          clouds: { all: 75 },
                          dt: 1541352000,
                          sys:
                           { type: 1,
                             message: 0.004,
                             country: 'DE',
                             sunrise: 1541312654,
                             sunset: 1541345954 },
                          cod: 200 }
                            at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:264:35)
                            at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:111:27)
                        Shutting down server...
                        I do not find the icon: '50n' and icon: '09n' in the images folder !?!
                          cowboysdude Module Developer @rob2791
                          @rob2791 it is a glitch that happens with certain providers…not sure why.
                            cowboysdude Module Developer @Hubschra01
                            @hubschra01 And you won’t find those icons…it runs off an icon array in the main js file.
                            From time to time depending on which service is being requested it can return an undefined. There are so many things at play in this module. Just reload it and it should work. :)
                            • eniacE Offline
                              eniac
                              Great Module that makes me change from Wonderground to NOAA3, but I have found an issue that my wife don’t like :-)
                              Since i activated NOAA3 the align from calender und Wounderlist is centered. if i deactivate the Module the caldender entries are aligned left as they schould do.
                              Any ideas ?
                                cowboysdude Module Developer @eniac
                                @eniac Could possibly be this line in the css file:
                                .MMM-NOAA3 .table th, tr, td{ text-align:center; table-layout:fixed; }
                                I would say take that out of the NOAA3 css and retry.
                                I don’t use either module but just for the fun of it I put the calendar module up and here’s a picture of the result:
                                B eniacE 2 Replies Last reply Reply Quote 0
                                • richland007R Offline
                                  richland007
                                  @cowboysdude Ok so right now i have MMM-NOAA.
                                  My question is: Do i have to delete that and than git clone MMM-NOAA3 so i can use MMM-WeatherBackground???.. or can i upgrade the MMM-NOAA some how to get to 3 than change the config.js accordingly for NOAA3 to work with the other providers other than WeatherUnderground that NOAA currently uses??
                                  This brings me to the other question; Which of the API providers i should use that allows for most ease of access and most free calls and obviously expected quality of information?? what do you advise or your experiences are??
                                  Thank you
                                  Denis
                                    redink
                                    I am really liking the new module, thanks! But, I have some images that aren’t loading. Specifically, nt_overcast and overcast don’t appear to exist in the image directory.
                                      Mykle1 Project Sponsor Module Developer @redink
                                      @redink
                                      What you could do is this:
                                      Make a copy of nt_mostlycloudy.png and rename that to nt_overcast.png. Make a copy of mostlycloudy.png and rename that to overcast.png. Problem solved for you. Then send a PR to NOAA3 repo, adding the new files. Problem solved for the author and future users. You get a star on your homework.
                                        bhaules @cowboysdude
                                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                                        I am having the same issue as @eniac. Tried commenting out that line in the .css file but the issue is still there. Any other ideas? It doesn’t even make sense to me how a setting in one module can influence the behavior of another
                                        Edit: I am so dumb. I realised after posting this message that I was editing the wrong .css file :(.
                                        Thanks for your help
                                          Serg
                                          Great module. But I think it shows the weather in the wrong place where I live. And another question: is there a translation into Russian in this module?
                                          • eniacE Offline
                                            eniac @cowboysdude
                                            @cowboysdude
                                            Works for me. (sorry for my late reply)
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 34
                                            • 35
                                            • 28 / 35
