has someone tested the NOAA3 module with accuweather provider?
I think something is wrong to identify the city with lan and long.
With this config I don’t see any weather information from the module, only air quality:{ disabled: false, module: 'MMM-NOAA3', position: 'top_right', config: { provider: "accuweather", apiKey: "xxxxxxxxxxxx", airKey: "yyyyyyyyy", css: "NOAA3", // THIS MUST CONTAIN A CSS STYLE NAME userlat: "45.483219", //MUST HAVE BOTH userlon: "9.203567" //MUST HAVE BOTH } },In the aw.js file I find this request:
url = "http://dataservice.accuweather.com/currentconditions/v1/"+zip+"?apikey="+this.config.apiKey+"&details=true";I think this request doesn’t pass the correct “location key” (the zip value).
Infact if I manually force a “location key” the “current conditions” start to work:url = "http://dataservice.accuweather.com/currentconditions/v1/214046?apikey="+this.config.apiKey+"&language="+config.language+"-it&details=true";This instead doesn’t work for the forecast, if I force the “location key” the module doesn’t show the “four day forecast”
url: "http://dataservice.accuweather.com/forecasts/v1/daily/5day/214046?apikey="+this.config.apiKey+"&language="+config.language+ "-us&details=true&metric=false",I found also another problem with the language because in the request is passed the right language but not the right region, it remains “us”, so the module doesn’t show any value :
&language="+config.language+"-us&details=true&metric=false"Can someone resolve the problem?
I’m not so able with js :-)
Thanks -
@piluke I will look into it. However the one problem AW provider does have is at times when you’re just starting the module you have to reload it to get the 4 day forecast…why, I’m not really sure it’s just how it’s been working.
I’ve made some changes but a few more need to be made here’s an example of the update:
@piluke the updated aw.js is uploaded to git hub.
Do a git pull and the config has changed to include your zip…
REMEMBER YOU MAY HAVE TO RELOAD IT TO GET THE BOTTOM FORECAST…tis an accuweather issue…{ disabled: false, module: 'MMM-NOAA3', position: 'top_right', config: { provider: "accuweather", apiKey: "xxxxxxxxxxxx", airKey: "yyyyyyyyy", css: "NOAA3", userlat: "45.483219", userlon: "9.203567" zip: "11111" //YOUR ZIPCODE } },
Still working on openweather api as time permits…it’s a complete train wreck LOL
Something has changed…but I am working to fix it.
@cowboysdude many many thanks for your help and your time.
Now the module is working.
I can see current conditions and forecast (without reload the page) but … they are not correct. :-)
I make some test, with my zip code the aw system identify a city in Mexico not in Italy!I think it’s necessary to identify a single locationKey with aw API.
I found three way:
by lat and lon:
https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/geoposition/searchor by zip code:
https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/postalcodes/searchor by name:
https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/searchbut i don’t know how to use it in javascript…
Infact if I put (in config.js) the right locationKey for my city instead zipcode the module work perfectly.
@piluke Okay so use your location key LOL
@cowboysdude thank you for your module, the ability to use the module with various providers is really something that makes a difference!
Would you consider adding a wind direction (icon or text) in a future update ?
@cowboysdude yes, of course :-)
It’s better to modify the README.md for not to use a zip code but a Locationkey from accuweather in the config file.
Many thanks -
@piluke You could always do a pull request to modify the readme on github ;)
Just updated OpenWeather and the main js…had issues with the forecast NOT loading…it’s all working now. :)
In a terminal window go to:
MagicMirror/modules/MMM-NOAA3
type ‘git pull’ to update!
