    • cowboysdudeC Offline
      Still working on openweather api as time permits…it’s a complete train wreck LOL
      Something has changed…but I am working to fix it.
        PILuke @cowboysdude
        @cowboysdude many many thanks for your help and your time.
        Now the module is working.
        I can see current conditions and forecast (without reload the page) but … they are not correct. :-)
        I make some test, with my zip code the aw system identify a city in Mexico not in Italy!
        I think it’s necessary to identify a single locationKey with aw API.
        I found three way:
        by lat and lon:
        https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/geoposition/search
        or by zip code:
        https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/postalcodes/search
        or by name:
        https://developer.accuweather.com/accuweather-locations-api/apis/get/locations/v1/cities/search
        but i don’t know how to use it in javascript…
        Infact if I put (in config.js) the right locationKey for my city instead zipcode the module work perfectly.
          cowboysdude Module Developer @PILuke
          @piluke Okay so use your location key LOL
          • G Offline
            gh057
            @cowboysdude thank you for your module, the ability to use the module with various providers is really something that makes a difference!
            Would you consider adding a wind direction (icon or text) in a future update ?
              PILuke @cowboysdude
              @cowboysdude yes, of course :-)
              It’s better to modify the README.md for not to use a zip code but a Locationkey from accuweather in the config file.
              Many thanks
                @piluke You could always do a pull request to modify the readme on github ;)
                  Just updated OpenWeather and the main js…had issues with the forecast NOT loading…it’s all working now. :)
                  In a terminal window go to:
                  MagicMirror/modules/MMM-NOAA3
                  type ‘git pull’ to update!
                    Johans @cowboysdude
                    @cowboysdude
                    As always, great job!
                    Didn’t noticed and I don’t know if it has to do with the upgrade or not.
                    saw this message in the terminal window, but all seems to work fine for me.
                    Just wanted to let you know.
                    TypeError: Cannot read property 'pollution' of undefined
                        at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:179:35)
                        at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:171:28)
                        at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                        at emitTwo (events.js:126:13)
                        at Request.emit (events.js:214:7)
                        at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                        at emitOne (events.js:116:13)
                        at Request.emit (events.js:211:7)
                        at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                        at Object.onceWrapper (events.js:313:30)
                      cowboysdude Module Developer @Johans
                      @johans said in MMM-NOAA - Another Weather Module:
                      @cowboysdude
                      Thank you sir!! Yes that happens at times with the air quality part…it usually fixes itself :)
                        Johans @cowboysdude
                        @cowboysdude
                        OK, than I don’t need to worry.
                          rob2791
                          Hey guys, I got this up and running tonight, Great work on this!
                          I’m only having one problem, the 4 day forecast doesn’t seem to load every time I start mm. It seems to only show the forecast once every four or so times i restart mm without any config changes, just a simple pm2 restart mm. Anyone else seen this?
                          • H Offline
                            Hubschra01
                            Hi
                            I do the Gitpull to Update this modul but in the CLI indows i got this…
                            TypeError: Cannot read property 'length' of undefined
                                at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:179:42)
                                at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:51:17)
                            { coord: { lon: 10.36, lat: 53.42 },
                              weather:
                               [ { id: 701, main: 'Mist', description: 'Trüb', icon: '50n' },
                                 { id: 300,
                                   main: 'Drizzle',
                                   description: 'Leichtes Nieseln',
                                   icon: '09n' } ],
                              base: 'stations',
                              main: { temp: 9, pressure: 1017, humidity: 87, temp_min: 9, temp_max: 9 },
                              visibility: 7000,
                              wind: { speed: 3.6, deg: 110 },
                              clouds: { all: 75 },
                              dt: 1541352000,
                              sys:
                               { type: 1,
                                 message: 0.004,
                                 country: 'DE',
                                 sunrise: 1541312654,
                                 sunset: 1541345954 },
                              cod: 200 }
                                at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:264:35)
                                at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:111:27)
                            Shutting down server...
                            I do not find the icon: '50n' and icon: '09n' in the images folder !?!
                              cowboysdude Module Developer @rob2791
                              @rob2791 it is a glitch that happens with certain providers…not sure why.
                                cowboysdude Module Developer @Hubschra01
                                @hubschra01 And you won’t find those icons…it runs off an icon array in the main js file.
                                From time to time depending on which service is being requested it can return an undefined. There are so many things at play in this module. Just reload it and it should work. :)
                                • eniacE Offline
                                  eniac
                                  Great Module that makes me change from Wonderground to NOAA3, but I have found an issue that my wife don’t like :-)
                                  Since i activated NOAA3 the align from calender und Wounderlist is centered. if i deactivate the Module the caldender entries are aligned left as they schould do.
                                  Any ideas ?
                                    cowboysdude Module Developer @eniac
                                    @eniac Could possibly be this line in the css file:
                                    .MMM-NOAA3 .table th, tr, td{ text-align:center; table-layout:fixed; }
                                    I would say take that out of the NOAA3 css and retry.
                                    I don’t use either module but just for the fun of it I put the calendar module up and here’s a picture of the result:
                                    B eniacE 2 Replies Last reply Reply Quote 0
                                    • richland007R Offline
                                      richland007
                                      @cowboysdude Ok so right now i have MMM-NOAA.
                                      My question is: Do i have to delete that and than git clone MMM-NOAA3 so i can use MMM-WeatherBackground???.. or can i upgrade the MMM-NOAA some how to get to 3 than change the config.js accordingly for NOAA3 to work with the other providers other than WeatherUnderground that NOAA currently uses??
                                      This brings me to the other question; Which of the API providers i should use that allows for most ease of access and most free calls and obviously expected quality of information?? what do you advise or your experiences are??
                                      Thank you
                                      Denis
                                        redink
                                        I am really liking the new module, thanks! But, I have some images that aren’t loading. Specifically, nt_overcast and overcast don’t appear to exist in the image directory.
                                          Mykle1 Project Sponsor Module Developer @redink
                                          @redink
                                          What you could do is this:
                                          Make a copy of nt_mostlycloudy.png and rename that to nt_overcast.png. Make a copy of mostlycloudy.png and rename that to overcast.png. Problem solved for you. Then send a PR to NOAA3 repo, adding the new files. Problem solved for the author and future users. You get a star on your homework.
                                            bhaules @cowboysdude
                                            @cowboysdude said in MMM-NOAA - Another Weather Module:
                                            I am having the same issue as @eniac. Tried commenting out that line in the .css file but the issue is still there. Any other ideas? It doesn’t even make sense to me how a setting in one module can influence the behavior of another
                                            Edit: I am so dumb. I realised after posting this message that I was editing the wrong .css file :(.
                                            Thanks for your help
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 34
                                            • 35
                                            • 28 / 35
