    • cowboysdudeC Offline
      Just updated OpenWeather and the main js…had issues with the forecast NOT loading…it’s all working now. :)
      In a terminal window go to:
      MagicMirror/modules/MMM-NOAA3
      type ‘git pull’ to update!
        Johans @cowboysdude
        @cowboysdude
        As always, great job!
        Didn’t noticed and I don’t know if it has to do with the upgrade or not.
        saw this message in the terminal window, but all seems to work fine for me.
        Just wanted to let you know.
        TypeError: Cannot read property 'pollution' of undefined
            at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:179:35)
            at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:171:28)
            at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
            at emitTwo (events.js:126:13)
            at Request.emit (events.js:214:7)
            at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
            at emitOne (events.js:116:13)
            at Request.emit (events.js:211:7)
            at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
            at Object.onceWrapper (events.js:313:30)
          cowboysdude Module Developer @Johans
          @johans said in MMM-NOAA - Another Weather Module:
          @cowboysdude
          Thank you sir!! Yes that happens at times with the air quality part…it usually fixes itself :)
            Johans @cowboysdude
            @cowboysdude
            OK, than I don’t need to worry.
              rob2791
              Hey guys, I got this up and running tonight, Great work on this!
              I’m only having one problem, the 4 day forecast doesn’t seem to load every time I start mm. It seems to only show the forecast once every four or so times i restart mm without any config changes, just a simple pm2 restart mm. Anyone else seen this?
              • H Offline
                Hubschra01
                Hi
                I do the Gitpull to Update this modul but in the CLI indows i got this…
                TypeError: Cannot read property 'length' of undefined
                    at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:179:42)
                    at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:51:17)
                { coord: { lon: 10.36, lat: 53.42 },
                  weather:
                   [ { id: 701, main: 'Mist', description: 'Trüb', icon: '50n' },
                     { id: 300,
                       main: 'Drizzle',
                       description: 'Leichtes Nieseln',
                       icon: '09n' } ],
                  base: 'stations',
                  main: { temp: 9, pressure: 1017, humidity: 87, temp_min: 9, temp_max: 9 },
                  visibility: 7000,
                  wind: { speed: 3.6, deg: 110 },
                  clouds: { all: 75 },
                  dt: 1541352000,
                  sys:
                   { type: 1,
                     message: 0.004,
                     country: 'DE',
                     sunrise: 1541312654,
                     sunset: 1541345954 },
                  cod: 200 }
                    at Object.parseAIR (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:264:35)
                    at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:111:27)
                Shutting down server...
                I do not find the icon: '50n' and icon: '09n' in the images folder !?!
                  cowboysdude Module Developer @rob2791
                  @rob2791 it is a glitch that happens with certain providers…not sure why.
                    cowboysdude Module Developer @Hubschra01
                    @hubschra01 And you won’t find those icons…it runs off an icon array in the main js file.
                    From time to time depending on which service is being requested it can return an undefined. There are so many things at play in this module. Just reload it and it should work. :)
                    • eniacE Offline
                      eniac
                      Great Module that makes me change from Wonderground to NOAA3, but I have found an issue that my wife don’t like :-)
                      Since i activated NOAA3 the align from calender und Wounderlist is centered. if i deactivate the Module the caldender entries are aligned left as they schould do.
                      Any ideas ?
                        cowboysdude Module Developer @eniac
                        @eniac Could possibly be this line in the css file:
                        .MMM-NOAA3 .table th, tr, td{ text-align:center; table-layout:fixed; }
                        I would say take that out of the NOAA3 css and retry.
                        I don’t use either module but just for the fun of it I put the calendar module up and here’s a picture of the result:
                        B eniacE 2 Replies Last reply Reply Quote 0
                        • richland007R Offline
                          richland007
                          @cowboysdude Ok so right now i have MMM-NOAA.
                          My question is: Do i have to delete that and than git clone MMM-NOAA3 so i can use MMM-WeatherBackground???.. or can i upgrade the MMM-NOAA some how to get to 3 than change the config.js accordingly for NOAA3 to work with the other providers other than WeatherUnderground that NOAA currently uses??
                          This brings me to the other question; Which of the API providers i should use that allows for most ease of access and most free calls and obviously expected quality of information?? what do you advise or your experiences are??
                          Thank you
                          Denis
                            redink
                            I am really liking the new module, thanks! But, I have some images that aren’t loading. Specifically, nt_overcast and overcast don’t appear to exist in the image directory.
                              Mykle1 Project Sponsor Module Developer @redink
                              @redink
                              What you could do is this:
                              Make a copy of nt_mostlycloudy.png and rename that to nt_overcast.png. Make a copy of mostlycloudy.png and rename that to overcast.png. Problem solved for you. Then send a PR to NOAA3 repo, adding the new files. Problem solved for the author and future users. You get a star on your homework.
                                bhaules @cowboysdude
                                @cowboysdude said in MMM-NOAA - Another Weather Module:
                                I am having the same issue as @eniac. Tried commenting out that line in the .css file but the issue is still there. Any other ideas? It doesn’t even make sense to me how a setting in one module can influence the behavior of another
                                Edit: I am so dumb. I realised after posting this message that I was editing the wrong .css file :(.
                                Thanks for your help
                                  Serg
                                  Great module. But I think it shows the weather in the wrong place where I live. And another question: is there a translation into Russian in this module?
                                  • eniacE Offline
                                    eniac @cowboysdude
                                    @cowboysdude
                                    Works for me. (sorry for my late reply)
                                      Mykle1 Project Sponsor Module Developer @Serg
                                      @serg
                                      You can help by doing the translation. Edit the right side of this file with the Russian translation.
                                      Have you entered your latitude and longitude into the config.js entry?
                                      "Rise":"Rise",
                                      "Set":"Set",
                                      "4 Day Forecast":"4 Day Forecast",
                                      "Monday": "Monday",
                                      "Tuesday": "Tuesday",
                                      "Wednesday": "Wednesday",
                                      "Thursday": "Thursday",
                                      "Friday": "Friday",
                                      "Saturday": "Saturday",
                                      "Sunday": "Sunday",
                                      "Hours of Light":"Daylight",
                                      "Last Updated": "Last Updated",
                                      "Today":"Today",
                                      "Night":"Night",
                                      "Mon":"Mon",
                                      "Tue":"Tue",
                                      "Wed":"Wed",
                                      "Thu":"Thu",
                                      "Fri":"Fri",
                                      "Sat":"Sat",
                                      "Sun":"Sun",
                                      "No Wind": "No Wind",
                                      "Humidity": "Humidity",
                                      "Visibility":"Visibility",
                                      "Pressure":"Pressure",
                                      "Excellent":"Excellent",
                                      "Good":"Good",
                                      "Lightly Polluted":"Lightly Polluted",
                                      "Moderately Polluted":"Moderately Polluted",
                                      "Heavily Polluted":"Heavily Polluted",
                                      "Forecast":"Forecast"
                                      S A 2 Replies Last reply Reply Quote 0
                                      • eniacE Offline
                                        eniac
                                        Hey Guys
                                        Having some Trouble Updateing the Weather Data. Don’t know the timeframe, but every morning the Module stuck with data from the last day.
                                        But not all Data is stuck. At the forecast you can see that the Days are changing. Moves the last day bevor the actual day. (Fr = yesterday , heute = today)
                                        “Heiter” and the sunny Icon was also yesterday. Today it is raining. After a pm2 restart the values are Ok for a wile, but in a few hours the module is stuck again.
                                        That is my code :
                                        			module: "MMM-NOAA3",
                                               					provider: "darksky",
                                        						apiKey: "xxxxxxxxxxxxxxxx",
                                        						//useAir: "False",
                                        						airKey: "xxxxxxxxxxxxxxxx",
                                               					css: "NOAA3",
                                               					updateInterval: 30 * 60 * 1000,
                                        						userlat: "50.xxxxx",
                                               					userlon: "7.xxxx"
                                        Any ideas ?
                                          Serg @Mykle1
                                          @mykle1
                                          I apologize for the late reply. New Year’s holiday and so on. .
                                          “Rise”:“Восход”,
                                          “Set”:“Закат”,
                                          “4 Day Forecast”:“Прогноз на 4 дня”,
                                          “Monday”: “Понедельник”,
                                          “Tuesday”: “Вторник”,
                                          “Wednesday”: “Среда”,
                                          “Thursday”: “Четверг”,
                                          “Friday”: “Пятница”,
                                          “Saturday”: “Суббота”,
                                          “Sunday”: “Воскресенье”,
                                          “Hours of Light”:“Длительность дня”,
                                          “Last Updated”: “Последнее обновление”,
                                          “Today”:“Сегодня”,
                                          “Night”:“Ночь”,
                                          “Mon”:“Пн”,
                                          “Tue”:“Вт”,
                                          “Wed”:“Ср”,
                                          “Thu”:“Чт”,
                                          “Fri”:“Пт”,
                                          “Sat”:“Сб”,
                                          “Sun”:“Вс”,
                                          “No Wind”: “Штиль”,
                                          “Humidity”: “Влажность”,
                                          “Visibility”:“Видимость”,
                                          “Pressure”:“Давление”,
                                          “Excellent”:“Отлично”,
                                          “Good”:“Хорошо”,
                                          “Lightly Polluted”:“Легкие загрязнения”,
                                          “Moderately Polluted”:“Умеренные загрязнения”,
                                          “Heavily Polluted”:“Сильные загрязнения”,
                                          “Forecast”:“Прогноз”
                                            costascontis
                                            hello,trying to make MMM-NOAA3 work but no luck.I use openweathermap provider ,my api is ok,but module dont show weather icons,night/day icons and no 4 day forecast at all.
                                            edit: managed to make it work by using another provider,darksky.All are ok except the night icon…
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
