    • cowboysdudeC
      cowboysdude Module Developer @Hubschra01
      @hubschra01 And you won’t find those icons…it runs off an icon array in the main js file.
      From time to time depending on which service is being requested it can return an undefined. There are so many things at play in this module. Just reload it and it should work. :)
      • eniacE
        eniac
        Great Module that makes me change from Wonderground to NOAA3, but I have found an issue that my wife don’t like :-)
        Since i activated NOAA3 the align from calender und Wounderlist is centered. if i deactivate the Module the caldender entries are aligned left as they schould do.
        Any ideas ?
        • cowboysdudeC
          cowboysdude Module Developer @eniac
          @eniac Could possibly be this line in the css file:
          .MMM-NOAA3 .table th, tr, td{ text-align:center; table-layout:fixed; }
          I would say take that out of the NOAA3 css and retry.
          I don’t use either module but just for the fun of it I put the calendar module up and here’s a picture of the result:
          B eniacE 2 Replies Last reply
          • richland007R
            richland007
            @cowboysdude Ok so right now i have MMM-NOAA.
            My question is: Do i have to delete that and than git clone MMM-NOAA3 so i can use MMM-WeatherBackground???.. or can i upgrade the MMM-NOAA some how to get to 3 than change the config.js accordingly for NOAA3 to work with the other providers other than WeatherUnderground that NOAA currently uses??
            This brings me to the other question; Which of the API providers i should use that allows for most ease of access and most free calls and obviously expected quality of information?? what do you advise or your experiences are??
            Thank you
            Denis
              redink
              I am really liking the new module, thanks! But, I have some images that aren’t loading. Specifically, nt_overcast and overcast don’t appear to exist in the image directory.
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @redink
                @redink
                What you could do is this:
                Make a copy of nt_mostlycloudy.png and rename that to nt_overcast.png. Make a copy of mostlycloudy.png and rename that to overcast.png. Problem solved for you. Then send a PR to NOAA3 repo, adding the new files. Problem solved for the author and future users. You get a star on your homework.
                  bhaules @cowboysdude
                  @cowboysdude said in MMM-NOAA - Another Weather Module:
                  I am having the same issue as @eniac. Tried commenting out that line in the .css file but the issue is still there. Any other ideas? It doesn’t even make sense to me how a setting in one module can influence the behavior of another
                  Edit: I am so dumb. I realised after posting this message that I was editing the wrong .css file :(.
                  Thanks for your help
                    Serg
                    Great module. But I think it shows the weather in the wrong place where I live. And another question: is there a translation into Russian in this module?
                    • eniacE
                      eniac @cowboysdude
                      @cowboysdude
                      Works for me. (sorry for my late reply)
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Serg
                        @serg
                        You can help by doing the translation. Edit the right side of this file with the Russian translation.
                        Have you entered your latitude and longitude into the config.js entry?
                        "Rise":"Rise",
                        "Set":"Set",
                        "4 Day Forecast":"4 Day Forecast",
                        "Monday": "Monday",
                        "Tuesday": "Tuesday",
                        "Wednesday": "Wednesday",
                        "Thursday": "Thursday",
                        "Friday": "Friday",
                        "Saturday": "Saturday",
                        "Sunday": "Sunday",
                        "Hours of Light":"Daylight",
                        "Last Updated": "Last Updated",
                        "Today":"Today",
                        "Night":"Night",
                        "Mon":"Mon",
                        "Tue":"Tue",
                        "Wed":"Wed",
                        "Thu":"Thu",
                        "Fri":"Fri",
                        "Sat":"Sat",
                        "Sun":"Sun",
                        "No Wind": "No Wind",
                        "Humidity": "Humidity",
                        "Visibility":"Visibility",
                        "Pressure":"Pressure",
                        "Excellent":"Excellent",
                        "Good":"Good",
                        "Lightly Polluted":"Lightly Polluted",
                        "Moderately Polluted":"Moderately Polluted",
                        "Heavily Polluted":"Heavily Polluted",
                        "Forecast":"Forecast"
                        S A 2 Replies Last reply
                        • eniacE
                          eniac
                          Hey Guys
                          Having some Trouble Updateing the Weather Data. Don’t know the timeframe, but every morning the Module stuck with data from the last day.
                          But not all Data is stuck. At the forecast you can see that the Days are changing. Moves the last day bevor the actual day. (Fr = yesterday , heute = today)
                          “Heiter” and the sunny Icon was also yesterday. Today it is raining. After a pm2 restart the values are Ok for a wile, but in a few hours the module is stuck again.
                          That is my code :
                          			module: "MMM-NOAA3",
                                 					provider: "darksky",
                          						apiKey: "xxxxxxxxxxxxxxxx",
                          						//useAir: "False",
                          						airKey: "xxxxxxxxxxxxxxxx",
                                 					css: "NOAA3",
                                 					updateInterval: 30 * 60 * 1000,
                          						userlat: "50.xxxxx",
                                 					userlon: "7.xxxx"
                          Any ideas ?
                            Serg @Mykle1
                            @mykle1
                            I apologize for the late reply. New Year’s holiday and so on. .
                            “Rise”:“Восход”,
                            “Set”:“Закат”,
                            “4 Day Forecast”:“Прогноз на 4 дня”,
                            “Monday”: “Понедельник”,
                            “Tuesday”: “Вторник”,
                            “Wednesday”: “Среда”,
                            “Thursday”: “Четверг”,
                            “Friday”: “Пятница”,
                            “Saturday”: “Суббота”,
                            “Sunday”: “Воскресенье”,
                            “Hours of Light”:“Длительность дня”,
                            “Last Updated”: “Последнее обновление”,
                            “Today”:“Сегодня”,
                            “Night”:“Ночь”,
                            “Mon”:“Пн”,
                            “Tue”:“Вт”,
                            “Wed”:“Ср”,
                            “Thu”:“Чт”,
                            “Fri”:“Пт”,
                            “Sat”:“Сб”,
                            “Sun”:“Вс”,
                            “No Wind”: “Штиль”,
                            “Humidity”: “Влажность”,
                            “Visibility”:“Видимость”,
                            “Pressure”:“Давление”,
                            “Excellent”:“Отлично”,
                            “Good”:“Хорошо”,
                            “Lightly Polluted”:“Легкие загрязнения”,
                            “Moderately Polluted”:“Умеренные загрязнения”,
                            “Heavily Polluted”:“Сильные загрязнения”,
                            “Forecast”:“Прогноз”
                              costascontis
                              hello,trying to make MMM-NOAA3 work but no luck.I use openweathermap provider ,my api is ok,but module dont show weather icons,night/day icons and no 4 day forecast at all.
                              edit: managed to make it work by using another provider,darksky.All are ok except the night icon…
                              • cowboysdudeC
                                cowboysdude Module Developer @costascontis
                                @costascontis Well that just won’t do :) I haven’t checked the providers in a while possible openweathermap may have changed some things I will check it out :)
                                • cowboysdudeC
                                  @costascontis You are right…I had the image for the correct moon just didn’t put in the array to display :) Thank you for catching that!! As for using open weather I just ran it and it seems to be working for me… here’s a picture. BUT I do use darksky as my provider also :)
                                  Yes that F weather and YES it’s cold here LOL
                                  • Mykle1M
                                    @cowboysdude
                                    10°F ? Oh hell no!
                                      costascontis
                                      thnx just updated and seems ok.AQI is not working for me or my location i guess?I can find my location at AQI site and added my api at config.js but module always shows “severe poluted” .
                                      @cowboysdude oh man ,we have nearly the same temp at celsius in Greece and we thing that is a very cold weather :)
                                        costascontis
                                        my api seems to have some calls but maybe Aqi not sending the right data?
                                        A 1 Reply Last reply
                                        • A
                                          Anthony Project Sponsor @costascontis
                                          @costascontis Hello. I saw that you live in
                                          greece like me. Can you help me out with this module because I have a couple of problems. First the icons are not always visible. second the day forecast never show up. And third it always shows wrong temperature. I have correctly put my api key from open weather. Any ideas?
                                            costascontis
                                            openweather is your problems ,ditch that api and create a free new one at darksky provider.Dont forget to Put your Lat and Long at config.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
