    MMM-NewsFeedTicker
    94 Posts 15 Posters 84.8k Views 14 Watching
    • justjim1220J Offline
      justjim1220 Module Developer
      If anyone is interested…
      Adding the following will scroll the image with the article, but it will stop at the left while the rest of the article finishes scrolling:
      @Keyframes marqueeImage {
      0% {left: 100%;}
      100% {left: 0;}
      .MMM-NewsFeedTicker .image {
      position: absolute;
      display: inline-block;
      vertical-align: middle;
      margin-left: 0;
      height: 100px;
      z-index: 1;
      background-color: rgb(175, 175, 175);
      animation: marqueeImage 20s linear;
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        New Update —> please run a git pull && npm install within the NewsFeedTicker directory
        Jim Hallock - 1995
        • Cr4z33C Offline
          Cr4z33 @justjim1220
          @justjim1220 said in MMM-NewsFeedTicker:
          @cr4z33
          Nothing just yet, been a bit under the weather with the flu. Keep falling asleep or losing concentration.
          I will keep trudging through. :winking_face:
          Have a good recovery and thanks for the update. ;)
          • Cr4z33C Offline
            Cr4z33 @justjim1220
            Got an error:
            ~/MagicMirror/modules/MMM-NewsFeedTicker $ git pull && npm install
            remote: Enumerating objects: 7, done.
            remote: Counting objects: 100% (7/7), done.
            remote: Compressing objects: 100% (4/4), done.
            remote: Total 4 (delta 2), reused 0 (delta 0), pack-reused 0
            Unpacking objects: 100% (4/4), done.
            Da https://github.com/justjim1220/MMM-NewsFeedTicker
               5895a96..eed535d  master     -> origin/master
            Aggiornamento di 5895a96..eed535d
            error: Your local changes to the following files would be overwritten by merge:
            	MMM-NewsFeedTicker.css
            Please commit your changes or stash them before you merge.
            Aborting
            • Cr4z33C Offline
              Cr4z33 @justjim1220
              @justjim1220 althought I know ZERO about developing, JSON, CSS & Co. I was doing a quick search on Google about scrolling text stuttering in Electron on slow devices and I found out a suggestion at Stackoverflow.com that actually improved A LOT the overall perfomance of the newsfeed scrolling!
              Go open /home/pi/MagicMirror/modules/MMM-NewsFeedTicker/MMM-NewsFeedTicker and replace
              .MMM-NewsFeedTicker .tickerbody {
                position: relative;
              with
                position: relative;
                transform: translateZ(0);
                backface-visibility: hidden;
              You should notice now an improvement. :upside-down_face:
                justjim1220 Module Developer @Cr4z33
                @cr4z33
                This error you got is just letting you know it can’t overwrite file within the module that you made any changes to
                You have to rename the file or delete it or just remove it from the directory
                Jim Hallock - 1995
                • Cr4z33C Offline
                  Cr4z33 @justjim1220
                  @justjim1220 OK I ran the update succesfully by deleting the CSS.
                  However I would like to revert to how it was looking before the update (static image on the left and smaller scrolling text). :grimacing_face:
                  How do I do that please?
                    @cr4z33
                    If you did not make any changes to the original files, run git pull && npm install
                    If you made changes to any of the original files that you want to keep, rename those files, then run git pull && npm install
                    if there isn’t anything you need saved, delete the MMM-NewsFeedTicker directory and run the git clone '. . .'
                    Jim Hallock - 1995
                    • Cr4z33C Offline
                      Cr4z33 @justjim1220
                      @justjim1220 that’s what I already did, but I see you now fixed that. :)
                      Thanks.
                      • BKeyportB Offline
                        BKeyport Module Developer
                        Looking good, other than the logo now appearing centered on final position - I have deleted all custom css…
                        • Cr4z33C Offline
                          Cr4z33 @BKeyport
                          @bkeyport so that’s not only me?
                          I thought I messed up something in the CSS.
                          • BKeyportB Offline
                            @Cr4z33 Nope, not just you.
                            Fixed it, actually. added the line “left: 0px;” in my custom css in the “.MMM-NewsFeedTicker .image” section… it’ll force the image to the left.
                            • Cr4z33C Offline
                              Cr4z33 @BKeyport
                              @bkeyport oh great doing it now thanks.
                              • BKeyportB Offline
                                BKeyport Module Developer @Cr4z33
                                fwiw, it could have happened as adjustments made to the code for a feature I asked for… :innocent look:
                                • KimzerK Offline
                                  Kimzer
                                  Any way to make the logo smaller? It got huge with using the keyframes bit
                                  • BKeyportB Offline
                                    yes, as a matter of fact. Fixes the centering too if you have that problem:
                                    custom.css in css subdirectory:
                                    position: absolute;
                                    margin-left: 0;
                                    height: 40px; /* set to your image size */
                                    z-index: 1;
                                    background-color: #FFF;
                                    bottom: 0;
                                    left: 0px;
                                      This module has been updated
                                      Please do a git pull && npm i to update
                                      Thanks!
                                      Jim Hallock - 1995
                                        mrSnatz
                                        Great module, exactly what I was looking for. however, the lettering stutters. Is there a way to fix this? I use a Rasperry pi3. How do I remove the logo from the feed? Many thx
                                        my config.js
                                          	  module: "MMM-NewsFeedTicker",
                                          	  position: "middle_center",
                                          	  //classes: "day_scheduler",
                                          	    feeds: [
                                              			title: "sportBILD",
                                              			url: "https://sportbild.bild.de/rss/vw-fussball/vw-fussball-45036878,sort=1,view=rss2.sport.xml",
                                              			encoding: "UTF-8",
                                              			className: "myClass",
                                              			//defaultLogo: ""
                                        and my custom.css
                                        .MMM-NewsFeedTicker {
                                            width: 80;
                                            height: 30px;
                                            background-color: none;
                                            position: absolute;
                                            bottom: 10px;
                                            animation: marquee 30s linear infinite;
                                            margin-left: 0;
                                            bottom: 10px;
                                            height: 30px;
                                        justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                                          justjim1220 Module Developer @mrSnatz
                                          @mrSnatz said in MMM-NewsFeedTicker:
                                          In this section,
                                          margin-left: 0;
                                          bottom: 10px;
                                          height: 30px;
                                          add display: none;
                                          as far as the stuttering, I was told that animation will do that with Pi
                                          Jim Hallock - 1995
                                            Mykle1 Project Sponsor Module Developer @mrSnatz
                                            Yep, the Pi struggles with some animations. Scrolling happens to be one of them. If they are important to you then you might consider something more robust than the Pi. There are alternatives from other single board computers, all the way up to mini ITX motherboards. Still others run MM (server) on a full blown desktop machine and use the Pi to remote in to view MM
                                            • 3 / 5
