    MMM-NewsFeedTicker
    94 Posts 15 Posters 90.0k Views 14 Watching
    • Cr4z33C
      Cr4z33
      Hi @justjim1220 any news about your next update? :)
      • justjim1220J
        justjim1220 Module Developer @Cr4z33
        @cr4z33
        Nothing just yet, been a bit under the weather with the flu. Keep falling asleep or losing concentration.
        I will keep trudging through. :winking_face:
        Jim Hallock - 1995
        • justjim1220J
          If anyone is interested…
          Adding the following will scroll the image with the article, but it will stop at the left while the rest of the article finishes scrolling:
          @Keyframes marqueeImage {
          0% {left: 100%;}
          100% {left: 0;}
          .MMM-NewsFeedTicker .image {
          position: absolute;
          display: inline-block;
          vertical-align: middle;
          margin-left: 0;
          height: 100px;
          z-index: 1;
          background-color: rgb(175, 175, 175);
          animation: marqueeImage 20s linear;
          Jim Hallock - 1995
          • justjim1220J
            New Update —> please run a git pull && npm install within the NewsFeedTicker directory
            Jim Hallock - 1995
            • Cr4z33C
              Cr4z33 @justjim1220
              @justjim1220 said in MMM-NewsFeedTicker:
              @cr4z33
              Have a good recovery and thanks for the update. ;)
              • Cr4z33C
                Cr4z33 @justjim1220
                Got an error:
                ~/MagicMirror/modules/MMM-NewsFeedTicker $ git pull && npm install
                remote: Enumerating objects: 7, done.
                remote: Counting objects: 100% (7/7), done.
                remote: Compressing objects: 100% (4/4), done.
                remote: Total 4 (delta 2), reused 0 (delta 0), pack-reused 0
                Unpacking objects: 100% (4/4), done.
                Da https://github.com/justjim1220/MMM-NewsFeedTicker
                   5895a96..eed535d  master     -> origin/master
                Aggiornamento di 5895a96..eed535d
                error: Your local changes to the following files would be overwritten by merge:
                	MMM-NewsFeedTicker.css
                Please commit your changes or stash them before you merge.
                Aborting
                • Cr4z33C
                  Cr4z33 @justjim1220
                  @justjim1220 althought I know ZERO about developing, JSON, CSS & Co. I was doing a quick search on Google about scrolling text stuttering in Electron on slow devices and I found out a suggestion at Stackoverflow.com that actually improved A LOT the overall perfomance of the newsfeed scrolling!
                  Go open /home/pi/MagicMirror/modules/MMM-NewsFeedTicker/MMM-NewsFeedTicker and replace
                  .MMM-NewsFeedTicker .tickerbody {
                    position: relative;
                  with
                    position: relative;
                    transform: translateZ(0);
                    backface-visibility: hidden;
                  You should notice now an improvement. :upside-down_face:
                  • justjim1220J
                    @cr4z33
                    This error you got is just letting you know it can’t overwrite file within the module that you made any changes to
                    You have to rename the file or delete it or just remove it from the directory
                    Jim Hallock - 1995
                    • Cr4z33C
                      Cr4z33 @justjim1220
                      @justjim1220 OK I ran the update succesfully by deleting the CSS.
                      However I would like to revert to how it was looking before the update (static image on the left and smaller scrolling text). :grimacing_face:
                      How do I do that please?
                      • justjim1220J
                        @cr4z33
                        If you did not make any changes to the original files, run git pull && npm install
                        If you made changes to any of the original files that you want to keep, rename those files, then run git pull && npm install
                        if there isn’t anything you need saved, delete the MMM-NewsFeedTicker directory and run the git clone '. . .'
                        Jim Hallock - 1995
                        • Cr4z33C
                          Cr4z33 @justjim1220
                          @justjim1220 that’s what I already did, but I see you now fixed that. :)
                          Thanks.
                          • BKeyportB
                            BKeyport Module Developer
                            Looking good, other than the logo now appearing centered on final position - I have deleted all custom css…
                            • Cr4z33C
                              Cr4z33 @BKeyport
                              @bkeyport so that’s not only me?
                              I thought I messed up something in the CSS.
                              • BKeyportB
                                @Cr4z33 Nope, not just you.
                                Fixed it, actually. added the line “left: 0px;” in my custom css in the “.MMM-NewsFeedTicker .image” section… it’ll force the image to the left.
                                • Cr4z33C
                                  Cr4z33 @BKeyport
                                  @bkeyport oh great doing it now thanks.
                                  • BKeyportB
                                    BKeyport Module Developer @Cr4z33
                                    fwiw, it could have happened as adjustments made to the code for a feature I asked for… :innocent look:
                                    • KimzerK
                                      Kimzer
                                      Any way to make the logo smaller? It got huge with using the keyframes bit
                                      • BKeyportB
                                        yes, as a matter of fact. Fixes the centering too if you have that problem:
                                        custom.css in css subdirectory:
                                        position: absolute;
                                        margin-left: 0;
                                        height: 40px; /* set to your image size */
                                        z-index: 1;
                                        background-color: #FFF;
                                        bottom: 0;
                                        left: 0px;
                                        • justjim1220J
                                          This module has been updated
                                          Please do a git pull && npm i to update
                                          Thanks!
                                          Jim Hallock - 1995
                                            mrSnatz
                                            Great module, exactly what I was looking for. however, the lettering stutters. Is there a way to fix this? I use a Rasperry pi3. How do I remove the logo from the feed? Many thx
                                            my config.js
                                              	  module: "MMM-NewsFeedTicker",
                                              	  position: "middle_center",
                                              	  //classes: "day_scheduler",
                                              	    feeds: [
                                                  			title: "sportBILD",
                                                  			url: "https://sportbild.bild.de/rss/vw-fussball/vw-fussball-45036878,sort=1,view=rss2.sport.xml",
                                                  			encoding: "UTF-8",
                                                  			className: "myClass",
                                                  			//defaultLogo: ""
                                            and my custom.css
                                            .MMM-NewsFeedTicker {
                                                width: 80;
                                                height: 30px;
                                                background-color: none;
                                                position: absolute;
                                                bottom: 10px;
                                                animation: marquee 30s linear infinite;
                                                margin-left: 0;
                                                bottom: 10px;
                                                height: 30px;
                                            justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                                            • 3 / 5
