    MMM-NewsFeedTicker
    94 Posts 15 Posters 92.5k Views 14 Watching
    • justjim1220J
      justjim1220 Module Developer @Cr4z33
      @cr4z33
      If you did not make any changes to the original files, run git pull && npm install
      If you made changes to any of the original files that you want to keep, rename those files, then run git pull && npm install
      if there isn’t anything you need saved, delete the MMM-NewsFeedTicker directory and run the git clone '. . .'
      Jim Hallock - 1995
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @justjim1220
        @justjim1220 that’s what I already did, but I see you now fixed that. :)
        Thanks.
        • BKeyportB
          BKeyport Module Developer
          Looking good, other than the logo now appearing centered on final position - I have deleted all custom css…
          • Cr4z33C
            Cr4z33 @BKeyport
            @bkeyport so that’s not only me?
            I thought I messed up something in the CSS.
            • BKeyportB
              @Cr4z33 Nope, not just you.
              Fixed it, actually. added the line “left: 0px;” in my custom css in the “.MMM-NewsFeedTicker .image” section… it’ll force the image to the left.
              • Cr4z33C
                Cr4z33 @BKeyport
                @bkeyport oh great doing it now thanks.
                BKeyportB 1 Reply Last reply
                • BKeyportB
                  BKeyport Module Developer @Cr4z33
                  fwiw, it could have happened as adjustments made to the code for a feature I asked for… :innocent look:
                  • KimzerK
                    Kimzer
                    Any way to make the logo smaller? It got huge with using the keyframes bit
                    • BKeyportB
                      yes, as a matter of fact. Fixes the centering too if you have that problem:
                      custom.css in css subdirectory:
                      .MMM-NewsFeedTicker .image {
                      position: absolute;
                      display: inline-block;
                      vertical-align: middle;
                      margin-left: 0;
                      height: 40px; /* set to your image size */
                      z-index: 1;
                      background-color: #FFF;
                      bottom: 0;
                      left: 0px;
                      • justjim1220J
                        This module has been updated
                        Please do a git pull && npm i to update
                        Thanks!
                        Jim Hallock - 1995
                          mrSnatz
                          Great module, exactly what I was looking for. however, the lettering stutters. Is there a way to fix this? I use a Rasperry pi3. How do I remove the logo from the feed? Many thx
                          my config.js
                            	  module: "MMM-NewsFeedTicker",
                            	  position: "middle_center",
                            	  //classes: "day_scheduler",
                            	    feeds: [
                                			title: "sportBILD",
                                			url: "https://sportbild.bild.de/rss/vw-fussball/vw-fussball-45036878,sort=1,view=rss2.sport.xml",
                                			encoding: "UTF-8",
                                			className: "myClass",
                                			//defaultLogo: ""
                          and my custom.css
                          .MMM-NewsFeedTicker {
                              width: 80;
                              height: 30px;
                              background-color: none;
                          .MMM-NewsFeedTicker .tickerbody {
                              position: absolute;
                              bottom: 10px;
                              transform: translateZ(0);
                              backface-visibility: hidden;
                              animation: marquee 30s linear infinite;
                              margin-left: 0;
                              bottom: 10px;
                              height: 30px;
                          justjim1220J Mykle1M 2 Replies Last reply
                          • justjim1220J
                            justjim1220 Module Developer @mrSnatz
                            @mrSnatz said in MMM-NewsFeedTicker:
                            In this section,
                            margin-left: 0;
                            bottom: 10px;
                            height: 30px;
                            add display: none;
                            as far as the stuttering, I was told that animation will do that with Pi
                            Jim Hallock - 1995
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @mrSnatz
                              Yep, the Pi struggles with some animations. Scrolling happens to be one of them. If they are important to you then you might consider something more robust than the Pi. There are alternatives from other single board computers, all the way up to mini ITX motherboards. Still others run MM (server) on a full blown desktop machine and use the Pi to remote in to view MM
                                mrSnatz
                                @justjim1220 said in MMM-NewsFeedTicker:
                                display: none;
                                Many thanks for the answer. Yes, I also thought about buying a stronger computer. What is your opinion on the Asus Tinkerboard? would he fix the problem?
                                Mykle1M justjim1220J ? 3 Replies Last reply
                                • Mykle1M
                                  I don’t have an opinion on the Tinkerboard. I’ve never used one, but there are several people on the forum that have. Perhaps then will chime in with their opinions. Good luck.
                                  • mumblebajM
                                    mumblebaj Module Developer @justjim1220
                                    @justjim1220 Have you ever managed to get this resolved? I a not getting the image from my 1 local news feed pulled in and not sure what else I can do to see if I can get it to come through.
                                    The news feed is from: http://feeds.news24.com/articles/news24/SouthAfrica/rss
                                    and the image is supposed to come from: https://scripts.24.co.za/img/sites/news24.png
                                    justjim1220J 1 Reply Last reply
                                    • justjim1220J
                                      @mrSnatz
                                      I have never used a Tinkerboard, so no thoughts regarding the use of one. Apologies!
                                      Jim Hallock - 1995
                                        A Former User @mrSnatz
                                        @mrSnatz
                                        I didn’t test this module on ATB, but ATB is definitely stronger than RPI.
                                        However apart from this module, you have more option nowadays. I think you can consider RK3399 or S922X. I especially recommend Jetson Nano at this moment for powerful GPU. RockPi 4 or NanoPi M4 is also good for overall performance.
                                        D 1 Reply Last reply
                                        • justjim1220J
                                          justjim1220 Module Developer @mumblebaj
                                          @mumblebaj
                                          Please update your MMM-NewsFeedTicker and run it to see if it is working the way you are wanting.
                                          git pull
                                          Thanks!
                                          Jim Hallock - 1995
                                            dirkie @Guest
                                            I run MM on a dedicated Intel NUC and I still occure this stuttering you are talking about. I noticed that the suttering appears when “MMM-ImagesPhotos” loads new pictures in slideshow mode. I was able to reduce this stuttering by reducing the size of the images…
                                            What I try to say “the power” does not help. I think the code is sometimes “sloppy”. Not that I could do anything better in terms of coding but just my 2cent…
                                            • 4 / 5
