    MMM-NewsFeedTicker
    94 Posts 15 Posters 86.3k Views 14 Watching
    • E Offline
      electros Project Sponsor
      Thank you very much for the help, but still I do not understand how you moved that red line down. I would be curious, can not get any position you want on the vertical for this module?
      • justjim1220J Offline
        justjim1220 Module Developer @electros
        @electros
        you should be able to place it in any of the regions,
        it works best in the top_bar, middle_center, and bottom_bar for the 100% width
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • Cr4z33C Offline
          Cr4z33
          • Cr4z33C Offline
            Cr4z33
            @justjim1220 can you please help me setting a custom logo into
            defaultLogo : ""
            I’ve tried so far with several image formats and I’ve used both HTTP and HTTPS, but it still doesn’t load the logo… :thinking_face:
              justjim1220 Module Developer @Cr4z33
              @cr4z33
              what news site is it?
              Jim Hallock - 1995
              • Cr4z33C Offline
                Cr4z33 @justjim1220
                @justjim1220 said in MMM-NewsFeedTicker:
                @cr4z33
                It’s
                http://feeds.feedburner.com/SkyitTg24
                and I would like to load
                https://tg24.sky.it/static/images/lv/skytg24_logo_header.png
                as default icon (also because I notice that ALL the news feeds I set don’t show the icon in the scrolling bar).
                Last but not least is it normal that it uses almost 50% of the CPU load? :frowning_face_with_open_mouth:
                I’ve got a Raspberry Pi 3 B+ and a Samsung EVO Plus 32GB micro SD card.
                Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                  Mykle1 Project Sponsor Module Developer @Cr4z33
                  @cr4z33 said in MMM-NewsFeedTicker:
                  It sure is. The Pi struggles with that type of animation. I’m surprised it’s only 50%. You should monitor your CPU temp, as well.
                  • Cr4z33C Offline
                    Cr4z33 @Mykle1
                    @mykle1 said in MMM-NewsFeedTicker:
                    So it’s not a matter of not so fast SD card then right?
                    I am using a heatsink on it therefore the average temperature so far is between 50° Celsius and 60° Celsius.
                      Well, it could be, but that’s unlikely. The CPU load issue has been around for some time and animations, especially marquee animations(scrolling) are the #1 culprit, or I miss my mark. Of course, if you used something more robust than a Pi that has a GPU you’d see a world of difference in the way MM performs.
                        @cr4z33
                        Apologies, I am working on the issue of using a custom logo if one doesn’t get pulled from the site.
                        Please stand by… :smiling_face_with_sunglasses:
                        Jim Hallock - 1995
                        mumblebajM 1 Reply Last reply Reply Quote 1
                          some found sports news that work for those interested…
                          http://www.espn.com/espn/news/story?page=rssinfo for all sports
                          http://www.espn.com/espn/rss/nfl/news for NFL
                          https://www.foxsports.com/rss-feeds for list of all sports
                          https://api.foxsports.com/v1/rss?partnerKey=zBaFxRyGKCfxBagJG9b8pqLyndmvo7UU&tag=nfl for NFL
                          https://www.cbssports.com/xml/rss for all sports
                          https://www.cbssports.com/rss/headlines/nfl/ for NFL
                          https://www.rotowire.com/rss/ for all sports
                          https://www.rotowire.com/rss/news.htm?sport=nfl for NFL
                          I also wanted to add that if you place the newsfeeds in the config, it also works better to place them in the js file as well. Not sure why, but I noticed that it does.
                          So, wanted to pass that on.
                          I am still working on getting a custom logo to show if one does not get pulled from the rss site.
                          Jim Hallock - 1995
                          • Cr4z33C Offline
                            Cr4z33 @justjim1220
                            @Mykle1 thanks for clearing things out.
                            Take your time don’t worry. ;)
                            In the meantime I am going to try too to put everything into the NewsFeeds js and see how things work.
                            Update
                            I saw no improvements by inserting the feeds straight into the JS. :disappointed_face:
                            • Cr4z33C Offline
                              Cr4z33
                              Sorry @justjim1220 I noticed only now that you removed the newsfeed ticker background in your latest screenshots.
                              I would like to try that out and see if performance improves. :)
                              How do you do that?
                                @cr4z33
                                In the css file, just change background-color: maroon; to background: none;
                                can be done with the image as well, but that could make the image difficult to see.
                                Jim Hallock - 1995
                                • Cr4z33C Offline
                                  Cr4z33 @justjim1220
                                  @justjim1220
                                  OK, thanks.
                                  Update:
                                  When not using a background then overall performance improves! :thumbs_up_medium-light_skin_tone:
                                  • Cr4z33C Offline
                                    Cr4z33
                                    Although I am using the UTF-8 encoding for ALL of my newsfeeds accented letters (i.e é, à, etc.) and currency symbols (i.e €) are not displayed properly.
                                    Any idea why?
                                    			module: "MMM-NewsFeedTicker",
                                    			position: "bottom_bar",
                                    			disabled: false,
                                    			//classes: "day_scheduler"
                                    			    feeds: [
                                    						title: "Hardware Upgrade",
                                    						url: "https://feeds.hwupgrade.it/rss_hwup.xml",
                                    						encoding: "UTF-8", //ISO-8859-1
                                    						className: "myClass",
                                    						defaultLogo : ""
                                      you might have better luck using encoding: "ISO-8859-15" or encoding: "ISO-8859-9"
                                      The latter one is supposed to work best with European characters
                                      Jim Hallock - 1995
                                      Cr4z33C 2 Replies Last reply Reply Quote 0
                                      • Cr4z33C Offline
                                        Cr4z33 @justjim1220
                                        @justjim1220
                                        That did the trick thanks. :thumbs_up_medium-light_skin_tone:
                                          @cr4z33
                                          Yep! Always lad to help! :smiling_face_with_sunglasses:
                                          Jim Hallock - 1995
                                            cyberphox
                                            So is there a way to use this without the scrolling function to ease up on CPU usage?
                                            • 2 / 5
