    MMM-NewsFeedTicker
    94 Posts 15 Posters 90.0k Views 14 Watching
    • Cr4z33C
      Cr4z33 @justjim1220
      @justjim1220 that’s what I already did, but I see you now fixed that. :)
      Thanks.
      • BKeyportB
        BKeyport Module Developer
        Looking good, other than the logo now appearing centered on final position - I have deleted all custom css…
        • Cr4z33C
          Cr4z33 @BKeyport
          @bkeyport so that’s not only me?
          I thought I messed up something in the CSS.
          • BKeyportB
            @Cr4z33 Nope, not just you.
            Fixed it, actually. added the line “left: 0px;” in my custom css in the “.MMM-NewsFeedTicker .image” section… it’ll force the image to the left.
            • Cr4z33C
              Cr4z33 @BKeyport
              @bkeyport oh great doing it now thanks.
              • BKeyportB
                BKeyport Module Developer @Cr4z33
                fwiw, it could have happened as adjustments made to the code for a feature I asked for… :innocent look:
                • KimzerK
                  Kimzer
                  Any way to make the logo smaller? It got huge with using the keyframes bit
                  • BKeyportB
                    yes, as a matter of fact. Fixes the centering too if you have that problem:
                    custom.css in css subdirectory:
                    .MMM-NewsFeedTicker .image {
                    position: absolute;
                    display: inline-block;
                    vertical-align: middle;
                    margin-left: 0;
                    height: 40px; /* set to your image size */
                    z-index: 1;
                    background-color: #FFF;
                    bottom: 0;
                    left: 0px;
                    • justjim1220J
                      justjim1220 Module Developer
                      This module has been updated
                      Please do a git pull && npm i to update
                      Thanks!
                      Jim Hallock - 1995
                        mrSnatz
                        Great module, exactly what I was looking for. however, the lettering stutters. Is there a way to fix this? I use a Rasperry pi3. How do I remove the logo from the feed? Many thx
                        my config.js
                          	  module: "MMM-NewsFeedTicker",
                          	  position: "middle_center",
                          	  //classes: "day_scheduler",
                          	    feeds: [
                              			title: "sportBILD",
                              			url: "https://sportbild.bild.de/rss/vw-fussball/vw-fussball-45036878,sort=1,view=rss2.sport.xml",
                              			encoding: "UTF-8",
                              			className: "myClass",
                              			//defaultLogo: ""
                        and my custom.css
                        .MMM-NewsFeedTicker {
                            width: 80;
                            height: 30px;
                            background-color: none;
                        .MMM-NewsFeedTicker .tickerbody {
                            position: absolute;
                            bottom: 10px;
                            transform: translateZ(0);
                            backface-visibility: hidden;
                            animation: marquee 30s linear infinite;
                            margin-left: 0;
                            bottom: 10px;
                            height: 30px;
                        justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                        • justjim1220J
                          justjim1220 Module Developer @mrSnatz
                          @mrSnatz said in MMM-NewsFeedTicker:
                          In this section,
                          margin-left: 0;
                          bottom: 10px;
                          height: 30px;
                          add display: none;
                          as far as the stuttering, I was told that animation will do that with Pi
                          Jim Hallock - 1995
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @mrSnatz
                            Yep, the Pi struggles with some animations. Scrolling happens to be one of them. If they are important to you then you might consider something more robust than the Pi. There are alternatives from other single board computers, all the way up to mini ITX motherboards. Still others run MM (server) on a full blown desktop machine and use the Pi to remote in to view MM
                              mrSnatz
                              @justjim1220 said in MMM-NewsFeedTicker:
                              display: none;
                              Many thanks for the answer. Yes, I also thought about buying a stronger computer. What is your opinion on the Asus Tinkerboard? would he fix the problem?
                              Mykle1M justjim1220J ? 3 Replies Last reply Reply Quote 0
                              • Mykle1M
                                I don’t have an opinion on the Tinkerboard. I’ve never used one, but there are several people on the forum that have. Perhaps then will chime in with their opinions. Good luck.
                                • mumblebajM
                                  mumblebaj Module Developer @justjim1220
                                  @justjim1220 Have you ever managed to get this resolved? I a not getting the image from my 1 local news feed pulled in and not sure what else I can do to see if I can get it to come through.
                                  The news feed is from: http://feeds.news24.com/articles/news24/SouthAfrica/rss
                                  and the image is supposed to come from: https://scripts.24.co.za/img/sites/news24.png
                                  • justjim1220J
                                    @mrSnatz
                                    I have never used a Tinkerboard, so no thoughts regarding the use of one. Apologies!
                                    Jim Hallock - 1995
                                      A Former User @mrSnatz
                                      @mrSnatz
                                      I didn’t test this module on ATB, but ATB is definitely stronger than RPI.
                                      However apart from this module, you have more option nowadays. I think you can consider RK3399 or S922X. I especially recommend Jetson Nano at this moment for powerful GPU. RockPi 4 or NanoPi M4 is also good for overall performance.
                                      • justjim1220J
                                        justjim1220 Module Developer @mumblebaj
                                        @mumblebaj
                                        Please update your MMM-NewsFeedTicker and run it to see if it is working the way you are wanting.
                                        git pull
                                        Thanks!
                                        Jim Hallock - 1995
                                          dirkie @Guest
                                          I run MM on a dedicated Intel NUC and I still occure this stuttering you are talking about. I noticed that the suttering appears when “MMM-ImagesPhotos” loads new pictures in slideshow mode. I was able to reduce this stuttering by reducing the size of the images…
                                          What I try to say “the power” does not help. I think the code is sometimes “sloppy”. Not that I could do anything better in terms of coding but just my 2cent…
                                          • G
                                            Giarry88
                                            Hi guys! I know that this topic is quite old, but I am trying to add this module to my magic mirror unsuccesfully.
                                            I added in the “config.js” file the module but it doesn’t show up. Any ideas on what i’ve done wrong?
                                            		module: "alert",
                                            		module: "updatenotification",
                                            		position: "top_bar"
                                            		module: "clock",
                                            		position: "top_left"
                                            		header: "Calendario di Google",
                                            					symbol: "calendar-check",
                                            					url: "MY CALENDAR"					}
                                            		module: "compliments",
                                            		position: "lower_third"
                                            		module: "currentweather",
                                            			locationID: "6542009", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                            			appid: "MYAPPID"
                                            		module: "weatherforecast",
                                            		header: "Previsioni Meteo:",
                                            			appid: "MYAPPID"
                                            		module: "newsfeed",
                                            		position: "bottom_bar",
                                            			feeds: [
                                            					title: "ANSA",
                                            					url: "https://www.ansa.it/sito/ansait_rss.xml"
                                            			showSourceTitle: true,
                                            			showPublishDate: true,
                                            			broadcastNewsFeeds: true,
                                            			broadcastNewsUpdates: true
                                            disabled: false,
                                            module: “MMM-NewsFeedTicker”,
                                            position: “bottom_bar”,
                                            //classes: “day_scheduler”,
                                            feeds: [
                                            title: “New York Times”,
                                            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”,
                                            customLogo: “NYT_logo_rss_250x40.png”
                                            title: “USA Today”,
                                            url: “http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories”,
                                            customLogo: “RSS_Syndication_Logo-USATN.png”
                                            title: “BBC World News”,
                                            url: “http://feeds.bbci.co.uk/news/world/rss.xml#”,
                                            customLogo: “bbc_news_120x60.gif”
                                            Thanks in advance!
                                            • 4 / 5
