    602 Posts 67 Posters 2.3m Views 68 Watching
      A Former User @Cr4z33
      @cr4z33
      Frankly said, it might not be due to my config modifying suggestion. (Because IT SHOULD PAUSE AND RESUME, but you said NEVER STOP)
      I think it is due to use HDMI as output. I don’t know about it, but it might be able to mix from multi-sources.
      • Cr4z33C Offline
        Cr4z33 @Guest
        @sean yeah I actually forgot to mention that the RTSP outputs to HDMI while Google Assistant outputs to a RPI Voice HAT speaker. :grimacing_face:
          @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          That’s how it works. not by my code. :D
          • Cr4z33C Offline
            Cr4z33 @Guest
            @sean of course. :winking_face:
            To everybody else: I removed the white frame and forgot to ask how to move the streaming windows.
            It is now offset compared to its module position. :confused_face:
            I guess I need to edit something in
            .MMM-RTSPStream .canvas {
              position: absolute;
              z-index: 1;
              left: 50%;
              top: 50%;
              /*width: 352px;
              height: 240px;*/
              -webkit-transform: translate(-50%, -50%);
                width: 100%;
            height: 100%;
            right?
              shbatm Module Developer @Cr4z33
              Play with the moduleOffset and absPosition config options. Search this forum for those and check out the README on GitHub for details of what each one does.
              • cowboysdudeC Offline
                cowboysdude Module Developer @barnosch
                @barnosch Are you getting any console.log errors or PM2 errors?
                • evroomE Offline
                  evroom
                  I tried playing with absPosition, but it does not do what is expected.
                  First of all:
                  absPosition: This overrides the automatic window and moduleOffset settings.
                  Second of all:
                  Format: { top: XX, right: XX, bottom: XX, left: XX } where XX is the pixel position on the screen.
                  This is not quite true.
                  The omxplayer options say: --win ‘x1 y1 x2 y2’
                  This would translate to: { top: XX, left: XX, right: XX, bottom: XX }
                  In principle it is a rectangular with coordinates (x1,y1) - (x2,y2).
                  But most important:
                  Whatever I do, including the module position, the video window is ALWAYS in the center of the screen, for the FULL width of the screen.
                  I will try playing with the other parameters a bit.
                  MagicMirror version: 2.37.0
                  • evroomE Offline
                    evroom
                    You can move the streaming window using
                    moduleOffset: { left: XX, top: YY },
                    left: plus value shifts right, minus value shifts left
                    top: plus value shifts down, minus value shifts up
                    The width and height value in the stream config determines the streaming window size.
                    The name moduleOffset is IMHO a bit misleading, as it does not move the module window.
                    I still fail to see the connection between the module position (e.g. “top_left”, “top_right”, “bottom_left”, etc) and the position of the streaming window.
                    The streaming window always appears in the middle.
                    Except when I use “top_bar” or “bottom_bar”.
                    • evroomE Offline
                      evroom
                      My MMM-RTSPStream module comes last.
                      So the first modules may shift this module down and therefore my streaming window appears to be always located in the middle.
                      In principle I want to have it in the middle, so I leave it there.
                      I made sure that MMM-RTSPStream is the only one using “middle_center”.
                      The module position will determine where the module window is being placed.
                      Exactly where is determined by the main.css and perhaps changes in the custom.css.
                      This is what the main.css does to “middle_center”, as example:
                      .region.middle.center {
                        width: 100%;
                        text-align: center;
                        -moz-transform: translateY(-50%);
                        -o-transform: translateY(-50%);
                        -webkit-transform: translateY(-50%);
                        -ms-transform: translateY(-50%);
                      For “middle_center” I changed my custom.css like this, for example:
                        width: 60%;
                      This overrules the width in the main.css.
                      [I have my monitor in portrait mode (900x1600) and have 2 columns of 60% + 40%]
                      The moduleWidth and moduleHeight determine the size of your module and how other module will wrap around it.
                      The moduleOffset will move the streaming window relative to the module window.
                      The stream1 width and hight determine the streaming window size.
                      When sized bigger than the module window, it will simply use this bigger size.
                      It will even will cover other modules when too big, those modules will not wrap around it.
                      This config works for me:
                        module: "MMM-RTSPStream",
                        disabled: false,
                        position: "middle_center",
                        header: "Axis Security Monitor",
                          autoStart: true,
                          rotateStreams: false,
                          moduleWidth: 590,
                          moduleHeight: 332,.
                      //      moduleOffset: { left: 0, top: 0},
                          localPlayer: 'omxplayer',
                          remotePlayer: 'none',
                          showSnapWhenPaused: false,
                          remoteSnaps: false,
                          stream1: {
                            url: 'rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360',
                            width: 590,
                            height: 332
                      With
                      $ pm2 logs mm
                      you can check the streaming window parameters:
                      0|mm  | Starting stream stream1 with args: [
                      0|mm  |     "--avdict",
                      0|mm  |     "rtsp_transport:tcp",
                      0|mm  |     "--win",
                      0|mm  |     "-2, 656, 588, 988",
                      0|mm  |     "--no-osd",
                      0|mm  |     "--live",
                      0|mm  |     "--video_queue",
                      0|mm  |     "4",
                      0|mm  |     "--fps",
                      0|mm  |     "30",
                      0|mm  |     "rtsp://user:password@192.168.178.56/axis-media/media.amp?resolution=640x360"
                      0|mm  | ]
                      I have changed my custom config like this:
                      .MMM-RTSPStream header {
                          text-align: left;
                      .MMM-RTSPStream .innerWrapper {
                        border-style: none;
                        //border: 1px solid red;
                      I used solid red in order to see the position of the module window more clear.
                      Be sure to use
                      cd ~/MagicMirror; npm run config:check
                      to check the config for errors before restarting mm, it will save you from obvious mistakes.
                      Those are my findings, for me the settings work, perhaps it will help other users.
                      • Cr4z33C Offline
                        Cr4z33 @shbatm
                        @shbatm OK thanks.
                        • citizendevpiC Offline
                          citizendevpi
                          Have you got the wayze cam to feed to your mirror?
                          • Cr4z33C Offline
                            Cr4z33
                            @shbatm what if I want to use VLC instead of omxplayer?
                            I am going to move to a different SBC called Rock Pi 4B and we know that omxplayer is for the Raspberry Pi family only.
                            Would it be quite simple to edit the scripts or does it need a good programming knowledge? :smiling_face_with_smiling_eyes:
                            Right now I am using a VLC window in my VMware Debian 8.x based MagicMirror testing session, but it’s not really what I want… :confused_face:
                              @citizendevpi I started looking at VLC as an alternative to OMXPlayer but didn’t make it very far (honestly, just not enough time).
                              The most promising looked to be webchimera.js with VLC built for hardware acceleration, but the original repo for webchimera.js is marked abandoned. It looks like at least 1 fork is still active, but I didn’t get as far as testing anything.
                              If you have the capability to pursue it, I’d love some help. From what I have looked at, it should be a close-to-drop-in replacement for the FFMPEG version of this Module, and if that works, I could eliminate all of the OMXPlayer references (read: headaches).
                              References I’ve found:
                              https://thepi.io/how-to-compile-vlc-media-player-with-hardware-acceleration-for-the-raspberry-pi/
                              https://github.com/limoragni/WebChimera.js
                              Cr4z33C 2 Replies Last reply Reply Quote 0
                              • Cr4z33C Offline
                                Cr4z33 @shbatm
                                @shbatm unfortunately I am not skilled enough for that sorry. :slightly_frowning_face:
                                Anyway it came out that VLC was not a good idea when using a Rockchip based SBC.
                                Its VPU can be used only if using gst-launch-1.0 like ie.:
                                gst-launch-1.0 uridecodebin uri=file:///usr/local/test.mp4  ! rkximagesink
                                That way 4K streaming/playing looks good too.
                                • Cr4z33C Offline
                                  Cr4z33 @shbatm
                                  @shbatm I’ve encountered a new issue.
                                  While using a profile switching solution when I get to the profile that uses MMM-RTSPStream omxplayer displays the video at full screen! :face_screaming_in_fear:
                                  The major problem is that no keyboard or mouse control can be used until I switch to a different profile that is not using your module.
                                  Can you please fix this?
                                  • BKeyportB Offline
                                    BKeyport Module Developer
                                    That’s sounding more like the profile switcher’s issue - unless you’ve config’d this player to be full screen.
                                    • Cr4z33C Offline
                                      Cr4z33 @BKeyport
                                      @bkeyport nope I didn’t set omxplayer anywhere but in this module. ;)
                                      Also profile switching is only ‘telling’ modules to show or hide.
                                      Nothing else.
                                      It’s done by voice command through MMM-AssistankMk2:
                                            "CHANGE_PROFILE_1": {
                                              moduleExec: {
                                                module:[],
                                                exec: (module, params, key) => {
                                                  var modules = ["YOUR", "MODULES", "TO", "SHOW", "FOR", "PROFILE1"]
                                                  if (modules.indexOf(module.name) >= 0) {
                                                    module.show()
                                                  } else {
                                                    module.hide()
                                            "CHANGE_PROFILE_2": {
                                              moduleExec: {
                                                module:[],
                                                  var modules = ["YOUR", "MODULES", "TO", "SHOW", "FOR", "PROFILE2"]
                                                    module.show()
                                                  } else {
                                                    module.hide()
                                        Please post your PM2 logs when this happens so I can try and troubleshoot. (Run pm2 logs in an SSH terminal, or post the excerpt from the files in ~/.pm2/logs/).
                                        • Cr4z33C Offline
                                          Cr4z33 @shbatm
                                          @shbatm here you go. ;)
                                          • Cr4z33C Offline
                                            Cr4z33 @shbatm
                                            @shbatm you there mate? :hushed_face:
                                            • 30
                                            • 31
                                            • 7 / 31
