    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 869.4k Views 74 Watching
      Hi folks
      UPDATE 28-FEB-2021
      This module has been replaced with MMM-OpenWeatherForecast. Apple bought Dark Sky and decided to stop allowing free access to their weather API (Thanks Apple). OpenWeatherForecast does everything this module does plus a bunch of improvements you’ve all been asking for.
      UPDATE 9-Dec-2018
      I’ve updated this module to use the Nunjucks HTML templating system, which means as of verison 1.6, this module requires MagicMirror version 2.2.0 or later. If you are running on an older version of MagicMirror, then please use v1.5 of the module, which you can download here:
      https://github.com/jclarke0000/MMM-DarkSkyForecast/releases/tag/v1.5
      Instead of using git clone to get the module code, download the zip file from the link above and extract the contents of the ZIP file to your modules directory. This zip puts all of the files into a folder named MMM-DarkSkyForecast-1.5. I don’t know if it’s necessary to rename this directory to just MMM-DarkSkyForecast or if it will work as-is. Run npm install as normal in the directory to install all of the dependencies.
      END UPDATES
      I had been using my old weather module for quite some time, but now that Weather Underground no longer allows free API access, I’ve needed a replacement.
      The great news is that there are SO many weather modules available now, but given that each of them behaved a little differently, it would have taken a considerable amount of time to go through and evaluate each one to see if it suited my needs.
      I instead decided to use that time to write one that exactly matches my needs. I’ll admit it is quite possible that another weather module does everything mine does and perhaps more, but being the lazy ass that I am, I didn’t take the time to check :)
      If you find it useful, then here it is.
      [card:jclarke0000/MMM-DarkSkyForecast]
      It supports current conditions, hourly and daily forecasts and is highly configurable. It includes a handful of icon sets and even supports Dark Sky’s Skycons animated icon set.
      If you don’t already have one, you’ll need to get a Dark Sky API key from here:
      https://darksky.net/dev
      You’ll also need the latitude and longitude of the region for which you want to display weather conditions. You can find that here:
      https://www.latlong.net/
      Screenshot:
      Included Icon sets
      This does not share any code with my old MMM-MyWeather module. This is a completely new module from scratch that is a bit more organized code-wise and outputs HTML markup better suited for multiple layouts.
      RedNaxR J N 4 Replies Last reply Reply Quote 5
        A Former User
        @j-e-f-f
        What a beautiful module! Thank you always.
        Anyway, is there any feature to broadcast weather via notification? (current weather & forecasts) If so, it will be great.
        I’m making another calendar module, and want to use forecast info.
        And, My another module WeatherBackground also is using current weather info for searching image. Could you add this feature? just periodical simple notifications with payload will be enough.
          Smotx
          Beautifull but…
          On mine, 'Loading"…
          and no error on log:
          Module helper loaded: MMM-DarkSkyForecast
          Connecting socket for: MMM-DarkSkyForecast
          ====================== Starting node_helper for module [MMM-DarkSkyForecast]
            j.e.f.f Project Sponsor Module Developer @Guest
            @sean I think that’s doable. Should be a simple addition to the code. Will take a look this weekend.
            • rudibaraniR Offline
              rudibarani Project Sponsor
              So beautiful - thank you very much!!
              This is more than an adequate replacement for MyWeather. Great job!
              I’d like to bring forward three questions:
              • Does the module support the USER_PRESENCE notification to suspend / resume API calls? If not, it would be nice if you could consider that.
              • Could you please add an option for a"label_timeFormatSuffix"? It would be nice if the time could be displayed like “14h” if one uses the 24h format.
              • Could you please add an option to hide the icons above the table (umbrella and wind) to make it more compact, if needed?
                j.e.f.f Project Sponsor Module Developer @rudibarani
                @rudibarani
                @rudibarani said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                It doesn’t suspend API calls based on user presence. This is intentional. I don’t spend more than about 30 seconds looking at my mirror, so when I do, I want the information that appears to be immediately up to date. By default the module polls every ten minutes for data, so you don’t run the risk of exceeding the 1000 request limit per day, nor are you really burning up a lot of CPU cycles to do so.
                This is already possible. Look at the label_timeFormat parameter
                I’ll add this in at some point, but you can do it now in your custom CSS. Just hide the div with the .header-row class, like so:
                .MMM-DarkSkyForecast .header-row {
                  display: none;
                rudibaraniR 1 Reply Last reply Reply Quote 0
                  rudibarani Project Sponsor @j.e.f.f
                  Dear @j-e-f-f,
                  thanks for the quick reply. Today, I tried to get my toes wet with JS coding and added an option to hide the column header icons from the forecast table or optionally show a header above the forecast table. It seems to work as expected and I have created a pull-request to give others access to the feature as well and maybe safe you some time.
                  I also found a way to hide the vertical lines from the table via the custom.css file and now the module looks even better, if a fullscreen background image is used.
                    j.e.f.f Project Sponsor Module Developer @Smotx
                    @smotx I fixed a bug with the summary display last night. Try doing a git pull in the MMM-DarkSkyForecast directory, then restart MagicMirror. See if that fixes it.
                      @rudibarani I merged your pull request, but then I did a bit of refactoring. I renamed the the parameter forecastTableHeaderText to forecastHeaderText, as it can be used in both the table and tiled views.
                      I also fixed up how the header is formatted. I’m now using an HTML5 header element and it has two classes: module-header so that it is formatted the same as all of the other module headers, and forecast-header if you want to target it specifically with CSS.
                      Lastly, this update enables notifications for other modules. The notification is called DARK_SKY_FORECAST_WEATHER_UPDATE and the payload is Dark Sky’s weather JSON object. For details see https://darksky.net/dev/docs.
                      rudibaraniR Cr4z33C 2 Replies Last reply Reply Quote 0
                      • RedNaxR Offline
                        RedNax Module Developer @j.e.f.f
                        @j-e-f-f :) This looks familiar… well done!
                        • BKeyportB Offline
                          BKeyport Module Developer
                          Does it handle midnight properly in 12 hour mode? So darned tired of the 0am stuff the other DarkSky one has. ;)
                            @j-e-f-f said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                            Thanks for accepting my pull request and your improvements. They help me learn how this all works.
                            I have some trouble with the animated current conditions icons. Sometimes they do not show up, although configured - and reappear on a restart. Sometimes they are shown only for one instance of MMM-DarkSkyForecast. Do you have any idea, what might be the cause?
                            A second question: I have limited the max-width of MMM-DarkSkyForecast to 250px as I would like to have my mirror with cascading module widths with in creasing width the lower a module is. This works fine on the left side. If I send MMM-DarkSkyForecast to the right side and the module below is wider, it is aligned on the left side of the right region. Do you have any advice how to right align all modules in the right region?
                            • Hein-JanH Offline
                              Hein-Jan
                              @j-e-f-f ,
                              I am also stuck at “Loading” actually it says “Bezig met laden…” which is Dutch for “Loading”.
                              I ran the “git clone…”, switched to the “MMM-DarkSkyForecast” directory, and ran the NPM Install.
                              I do get this warning: “npm WARN mmm-darkskyforecast@1.0.0 No repository field.”, but I do not know how to act upon it.
                              The module is making calls to DarkSky, I see that in the Api usage.
                              The logs show no error.
                              This is the config:
                                			module: "MMM-DarkSkyForecast",
                                			header: "Weersverwachting",
                              //  			classes: "default everyone",
                                			disabled: false,
                                  				apikey: "XXXXXXXXXXXXX",
                                  				latitude: "51.5096192",
                                  				longitude: "5.6364183",
                                  				iconset: "1c",
                              //				maxHourliesToShow: 4,
                              //				maxDailiesToShow: 4,
                              //				useAnimatedIcons: true,
                                  				concise: false,
                              //				label_timeFormat: "k[h]",
                                  				forecastLayout: "table"
                              I am not sure were I went wrong. Can you provide help?
                              Kind Regards,
                              Hein-Jan
                              • karsten13K Offline
                                karsten13
                                Same here with “Loading” and nothing happens.
                                Seems to be a problem with lon/lat.
                                If i provide the example lon/lat it works.
                                  baschke
                                  looks awesome but doesn’t work with the coordinates of Berlin. It says “loading” but nothing happens.
                                    header: "Weather",
                                    disabled: false,
                                      apikey: "db7derpderpderp214eae3b0f6e",
                                      latitude: "52.520008",
                                      longitude: "13.404954",
                                      iconset: "2m",
                                      concise: false,
                                      forecastLayout: "table",
                                      language: "de"
                                  • K Offline
                                    krouton
                                    I posted this on the GitHub page;
                                    When I use the default Long and Lat, the module loads. London works as does Vancouver and New York however when trying Hawaii, Sydney, Paris, Cape Town, Moscow, Melbourne, and Wellington, the module will not load. Using https://www.latlong.net/ for Long and Lat.
                                    When I use the same Long and Lat in this module that works with the Forecast.io module, the module won’t load. At first, I thought it was southern hemisphere’s (given the Lat is a ‘negative’ number) but that doesn’t appear to be the cause.
                                      @baschke, @karsten13, @Hein-Jan
                                      @j-e-f-f has updated the module on GitHub. Go to the module folder and update it via git pull.
                                      If the error still persists, leave out line
                                      concise: false,
                                      from the config file. That solved it for me in the prior version.
                                        cyberphox
                                        I had the same loading issue after just installing it…but leaving out the concise line worked for me too
                                        • lavolp3L Offline
                                          lavolp3 Module Developer
                                          Beautiful module!
                                          A bit too beautiful in my opinion since I’m currently putting a lot of work into MMM-forecast-io :-D
                                          How to troubleshoot modules
                                          MMM-soccer v2, MMM-AVStock
                                            A Former User
                                            MMM-WeatherBackground supports MMM-DarkSkyForecast now. (Just set source as "MMM-DarkSkyForecast")
                                            Thanks @j-e-f-f again.
                                            • 16
                                            • 17
                                            • 1 / 17
