    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 887.1k Views 74 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor @j.e.f.f
      Dear @j-e-f-f,
      thanks for the quick reply. Today, I tried to get my toes wet with JS coding and added an option to hide the column header icons from the forecast table or optionally show a header above the forecast table. It seems to work as expected and I have created a pull-request to give others access to the feature as well and maybe safe you some time.
      I also found a way to hide the vertical lines from the table via the custom.css file and now the module looks even better, if a fullscreen background image is used.
        j.e.f.f Project Sponsor Module Developer @Smotx
        @smotx I fixed a bug with the summary display last night. Try doing a git pull in the MMM-DarkSkyForecast directory, then restart MagicMirror. See if that fixes it.
          j.e.f.f Project Sponsor Module Developer @rudibarani
          @rudibarani I merged your pull request, but then I did a bit of refactoring. I renamed the the parameter forecastTableHeaderText to forecastHeaderText, as it can be used in both the table and tiled views.
          I also fixed up how the header is formatted. I’m now using an HTML5 header element and it has two classes: module-header so that it is formatted the same as all of the other module headers, and forecast-header if you want to target it specifically with CSS.
          Lastly, this update enables notifications for other modules. The notification is called DARK_SKY_FORECAST_WEATHER_UPDATE and the payload is Dark Sky’s weather JSON object. For details see https://darksky.net/dev/docs.
          rudibaraniR Cr4z33C 2 Replies Last reply Reply Quote 0
            RedNax Module Developer @j.e.f.f
            @j-e-f-f :) This looks familiar… well done!
            • BKeyportB Offline
              BKeyport Module Developer
              Does it handle midnight properly in 12 hour mode? So darned tired of the 0am stuff the other DarkSky one has. ;)
                @j-e-f-f said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                Thanks for accepting my pull request and your improvements. They help me learn how this all works.
                I have some trouble with the animated current conditions icons. Sometimes they do not show up, although configured - and reappear on a restart. Sometimes they are shown only for one instance of MMM-DarkSkyForecast. Do you have any idea, what might be the cause?
                A second question: I have limited the max-width of MMM-DarkSkyForecast to 250px as I would like to have my mirror with cascading module widths with in creasing width the lower a module is. This works fine on the left side. If I send MMM-DarkSkyForecast to the right side and the module below is wider, it is aligned on the left side of the right region. Do you have any advice how to right align all modules in the right region?
                • H Offline
                  Hein-Jan
                  @j-e-f-f ,
                  I am also stuck at “Loading” actually it says “Bezig met laden…” which is Dutch for “Loading”.
                  I ran the “git clone…”, switched to the “MMM-DarkSkyForecast” directory, and ran the NPM Install.
                  I do get this warning: “npm WARN mmm-darkskyforecast@1.0.0 No repository field.”, but I do not know how to act upon it.
                  The module is making calls to DarkSky, I see that in the Api usage.
                  The logs show no error.
                  This is the config:
                    			module: "MMM-DarkSkyForecast",
                    			header: "Weersverwachting",
                  //  			classes: "default everyone",
                    			disabled: false,
                      				apikey: "XXXXXXXXXXXXX",
                      				latitude: "51.5096192",
                      				longitude: "5.6364183",
                      				iconset: "1c",
                  //				maxHourliesToShow: 4,
                  //				maxDailiesToShow: 4,
                  //				useAnimatedIcons: true,
                      				concise: false,
                  //				label_timeFormat: "k[h]",
                      				forecastLayout: "table"
                  I am not sure were I went wrong. Can you provide help?
                  Kind Regards,
                  Hein-Jan
                  • karsten13K Offline
                    karsten13
                    Same here with “Loading” and nothing happens.
                    Seems to be a problem with lon/lat.
                    If i provide the example lon/lat it works.
                      baschke
                      looks awesome but doesn’t work with the coordinates of Berlin. It says “loading” but nothing happens.
                        header: "Weather",
                        disabled: false,
                          apikey: "db7derpderpderp214eae3b0f6e",
                          latitude: "52.520008",
                          longitude: "13.404954",
                          iconset: "2m",
                          concise: false,
                          forecastLayout: "table",
                          language: "de"
                      • K Offline
                        krouton
                        I posted this on the GitHub page;
                        When I use the default Long and Lat, the module loads. London works as does Vancouver and New York however when trying Hawaii, Sydney, Paris, Cape Town, Moscow, Melbourne, and Wellington, the module will not load. Using https://www.latlong.net/ for Long and Lat.
                        When I use the same Long and Lat in this module that works with the Forecast.io module, the module won’t load. At first, I thought it was southern hemisphere’s (given the Lat is a ‘negative’ number) but that doesn’t appear to be the cause.
                          @baschke, @karsten13, @Hein-Jan
                          @j-e-f-f has updated the module on GitHub. Go to the module folder and update it via git pull.
                          If the error still persists, leave out line
                          concise: false,
                          from the config file. That solved it for me in the prior version.
                            cyberphox
                            I had the same loading issue after just installing it…but leaving out the concise line worked for me too
                            • lavolp3L Offline
                              lavolp3 Module Developer
                              Beautiful module!
                              A bit too beautiful in my opinion since I’m currently putting a lot of work into MMM-forecast-io :-D
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                                A Former User
                                MMM-WeatherBackground supports MMM-DarkSkyForecast now. (Just set source as "MMM-DarkSkyForecast")
                                Thanks @j-e-f-f again.
                                  jasondreher
                                  Awesome!!! Just want I want after WeatherUndergrown stops its free api.
                                  I have it working but it takes up my entire screen even thought its set to top_right. And I cant get it to take any config changes, like table vs tiled.
                                    header: "Weather",
                                    disabled: false,
                                      apikey: "xxxx",
                                      latitude: "xxxx",
                                      longitude: "-xxxx",
                                      iconset: "4c",
                                      concise: false,
                                  Any idea why this would happen?
                                    karsten13 @rudibarani
                                    @rudibarani
                                        concise: false,
                                    Had already the newest version, but leaving out concise: false did the trick. Thanks!
                                      j.e.f.f Project Sponsor Module Developer @jasondreher
                                      @jasondreher said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                      @rudibarani said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                      concise: false,
                                      Both of the above issues are now fixed. Do a git pull for the latest version and restart Magic Mirror.
                                      By default the width is fixed to 300px. If you wish to override this, you can do so in your custom.css file as follows:
                                      .MMM-DarkSkyForecast .module-content {
                                        width: 500px; /* adjust this to taste */
                                        j.e.f.f Project Sponsor Module Developer @BKeyport
                                        @bkeyport said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                        I’m using moment.js to format the time display, and midnight gets displayed properly by default. You can also override the default display style for time with the parameter label_timeFormat. Provide any valid formatting string you can find from the moment.js docs: https://momentjs.com/docs/#/displaying/
                                          jasondreher @j.e.f.f
                                          @j-e-f-f
                                          All works great!! Love the module! Thanks
                                            colel83
                                            I was using your MyWeather module and was really bummed that weather underground was shutting down their free API. I just found your new module last night and I am ecstatic to be able to switch over to this one. Everything seems to be working well except that I have a couple of Moon icons for the forecast table. 3 of the 7 days are showing moon/clouds instead of sun/clouds. Is that something I can fix or is it on Dark Sky’s end?
                                            • 16
                                            • 17
                                            • 1 / 17
