    MMM-MyCalendar
    109 Posts 40 Posters 163.6k Views 38 Watching
      bokifide
      Hi! Love the module :). Just wondering if there’s a way to space out the columns enough so that the titles don’t get cut off:
      Thank you for your work!!
      Boki
        Medo
        Hey there!
        For some time now, i have the following issue:
        My MMM-MyCalendar is showing dates wrongly (one day in the past) although they are correct in the used ics-file.
        I moved my question over to the “troubleshooting” section (as it seems it fits better there):
        https://forum.magicmirror.builders/topic/8963/mmm-mycalendar-showing-wrong-dates-days-one-day-in-the-past
          j.e.f.f Project Sponsor Module Developer @bokifide
          @bokifide You would need to write some custom CSS to adjust the width of the containing column. The module is designed to used all of the space available in its container.
          • V Offline
            VinGroot
            I’d like to have absolute days in my calendar, but all I see is ‘today’, Saturday (without date), etc.
            My config is:
            maximumEntries: 8,
            useRelativeDates: false,
            joiningWord: “om”,
            maxTitleLength: 48,
            dateFormat: “D MMMM YYYY”,
            timeFormat: “HH:mm”,
            urgency: 0,
            getRelative: 0,
            * secret *]
            Am I doing something wrong?
            Some things like timeFormat (HH:mm), maxTitleLength and joiningWord work fine.
            • V Offline
              VinGroot
              • V Offline
                VinGroot
                When I set maximumEntries: 8 I only see items 3 items.
                I did some testing and I think the reason I only see 3 items is because some items are excluded.
                I think the excluded items are counted as well.
                  DolphinScientist
                  Hi @j-e-f-f , thanks for the great module. The config indicates that the icons are customizable using Font Awesome, but the behavior and the code (line ~181) seem to indicate otherwise. Any chance we could get it back? Do you know how you would want it implement with the svg system you have?
                    My module does not have a configurable icon. It wouldn’t work with the calendar icon with the date inside.
                    I based my modyle off the default calendar midule included wth MM. that one has a configurablenicon and perhaps I forgot to remove the instruction in my version.
                    Mine never had a configurable icon. I might enable a few options that would work with the date number inside, but at the moment you just get the one.
                    • H Offline
                      hnsy
                      Hi @j-e-f-f , thanks a lot for your really great modules. I really appreciate the style and convenience of your modules.
                      As I am using MyCalendar now for a while, I was wondering, if there is a possibility to display time-ranges? I mean the start date of a range is displayed, but when an event is taking place for, let’s say three days, currently I can only display the first day (start time).
                      Is there a possibility that all (3) days would appear in the list?
                      Maybe it is already integrated and I just didn’t get it.
                      Once more: Thumbs up for your work!!
                      Cheers, HNSY
                        j.e.f.f Project Sponsor Module Developer @hnsy
                        @hnsy I’m not sure… I’m using the default calendar code to retrieve the calendar data. I’ve only customized the display portion. If multi-day blocks are included in the data then it should be possible. I’ll have to take a look.
                        • bdeelmanB Offline
                          bdeelman @j.e.f.f
                          • N Offline
                            nagaculun
                            • N Offline
                              nagaculun
                              • G Offline
                                ganget
                                • F Offline
                                  Fonfon
                                  is it possible to color text ?
                                  because when i you have a wallpaper sometimes text is not visible.
                                  thanks for your help
                                    j.e.f.f Project Sponsor Module Developer @Fonfon
                                    @Fonfon No, but you can add a background colour to the module to make the text stand out better. try something like this in your custom.css file:
                                    .MMM-MyCalendar .module-content {
                                      background-color: rgba(0,0,0,0.5);
                                    The first three parameters 0,0,0 mean black, and the fourth parameter 0.5 is the level of transparency. Specify a decimal between 0 and 1, where 0 is fully transparent, and 1 is fully opaque.
                                    F 1 Reply Last reply Reply Quote 1
                                    • F Offline
                                      Fonfon @j.e.f.f
                                      @j-e-f-f said in MMM-MyCalendar:
                                      Thanks j.e.f.f for your help !
                                        charp07 @zzaidi148
                                        @zzaidi148 @j-e-f-f
                                        I have this same issue and haven’t had any luck in resolving the issue. I even copied the recommended config from earlier in this forum. Is there something that I am missing?
                                        It will just say, “Loading…”
                                        			module: "MMM-MyCalendar",
                                        			classes: "default everyone",
                                        			header: "Upcoming",
                                        			disabled: false,
                                        				colored: true,
                                        				maximumNumberOfDays: 30,
                                        				maximumEntries: 5,
                                        				fade: false,
                                        				maxTitleLength: 500,
                                        				dayOfWeekFormat: "dddd",
                                        				timeFormat: "h:mm A",
                                        				dateFormat: "MMMM D",
                                        				joiningWord: "at",
                                        				urgency: 1,
                                        					url: "https://calendar.google.com/calendar/ical path",
                                        					color: "#ffb350"
                                        					color: "#ff77d4"
                                          charp07 @charp07
                                          @charp07 figured it out! Sorry!
                                            BRSQUIRRL @j.e.f.f
                                            @j-e-f-f This feature (grouping by day) would be awesome! Have you had a chance to make any progress on this?
                                            • 5 / 6
