    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.7k Views 74 Watching
    • K
      kwabenalexx @michael5r
      @michael5r i added that to the config file and i get ‘‘Please create a config File’’ page
      • K
        kwabenalexx
        it’s fixed. thanks for all your help. i had to add a comma (,)
          j.e.f.f Project Sponsor Module Developer @michael5r
          @michael5r said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          Add:
          units: ‘us’
          to the DarkSkyForecast config to switch to imperial units. It’s the default for darksky, but not the default for this module.
          Yeah I did that intentionally because I’m Canadian and Imperial units make no sense to me ;)
            Hi folks
            Just wanted to let you know that with the latest update of this module, I’ve modified it to use the Nunjucks HTML templating system. This means as of version 1.6 of MMM-DarkSkyForecast, you’ll need to run it on MagicMirror 2.2.0 or later. It won’t run at all on older versions.
            If you’re running an older version of MagicMirror and you still want to use my module, then please download the source for version 1.5 from here:
            https://github.com/jclarke0000/MMM-DarkSkyForecast/releases/tag/v1.5
            Note that I will not update v1.5 with any new features or bug fixes. All future development work will be done against v1.6 and above. If you want the latest and greatest, then you’ll need to update MagicMirror.
              cyberphox @michael5r
                Smotx
                hello,
                how to reduce space between lines ?
                alt text
                J 1 Reply Last reply
                  j.e.f.f Project Sponsor Module Developer @Smotx
                  @smotx said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                  hello,
                  alt text
                  I’m assuming you mean the lines in the forecast when using the table layout. Here’s how:
                  .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item > span,
                  .MMM-DarkSkyForecast .wrapper.table .forecast-container .header-row > span {
                    height: 40px;  /* Adjust this to taste */
                  At some point you will be limited by the size of the icons, in which case if you want to go smaller, you can do this:
                  .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .forecast-icon {
                    width: 30px;
                    height: 30px; /* adjust these to taste */
                  Finally, if it’s still not small enough for you, make the font size smaller like so:
                    font-size: 17px;  /* Adjust this to taste */
                    Messel
                    Hi all, I love this module, but I updated to the latest version today, and my main icon disappeared. It just shows the temperature, no animated sun or (most likely) rain icon.
                    Can anyone see what is wrong?
                    This is my config:
                    module: “MMM-DarkSkyForecast”,
                    header: “Værmeldingen”,
                    position: “top_right”,
                    classes: “default everyone”,
                    disabled: false,
                    apikey: “XXXX”,
                    latitude: “62.737709”,
                    longitude: “7.160910”,
                    maxDailiesToShow: “2”,
                    showHourlyForecast: false,
                    label_days: [“Søndag”, “Mandag”, “Tirsdag”, “Onsdag”, “Torsdag”, “Fredag”, “Lørdag”],
                    label_high: “Høy”,
                    label_low: “Lav”,
                    iconset: “3c”,
                    concise: false,
                    forecastLayout: “tiled”
                      Smotx @j.e.f.f
                      @j-e-f-f
                      Thx but, i have changed 3 settings on /home/pi/MagicMirror/modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
                      after reboot nothing has changed :(
                      it’s not MMM-DarkSkyForecast.css ?
                        dan-o
                        @j-e-f-f
                        Same issue as @Messel - main icon has disappeared since updating just now. I’m on the latest version of MM, using icon set 4c.
                          @smotx Put the CSS into MagicMirror/css/custom.css
                            j.e.f.f Project Sponsor Module Developer @Messel
                            @messel I just tried your exact config, and it worked for me just fine. What version of MM are you running?
                            M 1 Reply Last reply
                              Messel @j.e.f.f
                              @j-e-f-f
                              Sorry for the late answer, I was sleeping :) and that probably did the trick, because the main icon is back. I don’t know what happened. Doesn’t matter, I’m happy. Thanks
                                Smotx @j.e.f.f
                                @j-e-f-f
                                Ok but nothing change^^.
                                thanks anyway
                                  @messel I’ve since been able to replicate your problem. Has to do with the animated icon dray command. In some cases it gets executed before the DOM is updated. I’m working on a fix.
                                    j.e.f.f Project Sponsor Module Developer @j.e.f.f
                                    @messel @dan-o I think I’ve fixed your issue. Do a git pull in the MMM-DarkSkyForecast directory and restart MM.
                                      @j-e-f-f
                                      thanks anyway
                                      Can you post a screenshot of what you’re trying to change? I think I might be giving you incorrect instructions.
                                        Smotx @j.e.f.f
                                        @j-e-f-f
                                        I want to reduce free space identified by “red areas” on this screen :
                                        alt text
                                        J 2 Replies Last reply
                                          @smotx screenshot didn’t come through. You don’t need to host the image on Imagur. You can upload it directly when editing your post. Just drag it in, or hit the cloud/upload icon.
                                          • BKeyportB
                                            BKeyport Module Developer
                                            It’s showing for me, @j-e-f-f
                                            • 16
                                            • 17
                                            • 3 / 17
