    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.7k Views 74 Watching
      cyberphox @michael5r
        Smotx
        hello,
        how to reduce space between lines ?
        alt text
        J 1 Reply Last reply
          j.e.f.f Project Sponsor Module Developer @Smotx
          @smotx said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          hello,
          alt text
          I’m assuming you mean the lines in the forecast when using the table layout. Here’s how:
          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item > span,
          .MMM-DarkSkyForecast .wrapper.table .forecast-container .header-row > span {
            height: 40px;  /* Adjust this to taste */
          At some point you will be limited by the size of the icons, in which case if you want to go smaller, you can do this:
          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .forecast-icon {
            width: 30px;
            height: 30px; /* adjust these to taste */
          Finally, if it’s still not small enough for you, make the font size smaller like so:
            font-size: 17px;  /* Adjust this to taste */
            Messel
            Hi all, I love this module, but I updated to the latest version today, and my main icon disappeared. It just shows the temperature, no animated sun or (most likely) rain icon.
            Can anyone see what is wrong?
            This is my config:
            module: “MMM-DarkSkyForecast”,
            header: “Værmeldingen”,
            position: “top_right”,
            classes: “default everyone”,
            disabled: false,
            apikey: “XXXX”,
            latitude: “62.737709”,
            longitude: “7.160910”,
            maxDailiesToShow: “2”,
            showHourlyForecast: false,
            label_days: [“Søndag”, “Mandag”, “Tirsdag”, “Onsdag”, “Torsdag”, “Fredag”, “Lørdag”],
            label_high: “Høy”,
            label_low: “Lav”,
            iconset: “3c”,
            concise: false,
            forecastLayout: “tiled”
              Smotx @j.e.f.f
              @j-e-f-f
              Thx but, i have changed 3 settings on /home/pi/MagicMirror/modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
              after reboot nothing has changed :(
              it’s not MMM-DarkSkyForecast.css ?
                dan-o
                @j-e-f-f
                Same issue as @Messel - main icon has disappeared since updating just now. I’m on the latest version of MM, using icon set 4c.
                  @smotx Put the CSS into MagicMirror/css/custom.css
                    j.e.f.f Project Sponsor Module Developer @Messel
                    @messel I just tried your exact config, and it worked for me just fine. What version of MM are you running?
                    M 1 Reply Last reply
                      Messel @j.e.f.f
                      @j-e-f-f
                      Sorry for the late answer, I was sleeping :) and that probably did the trick, because the main icon is back. I don’t know what happened. Doesn’t matter, I’m happy. Thanks
                        Smotx @j.e.f.f
                        @j-e-f-f
                        Ok but nothing change^^.
                        thanks anyway
                          @messel I’ve since been able to replicate your problem. Has to do with the animated icon dray command. In some cases it gets executed before the DOM is updated. I’m working on a fix.
                            j.e.f.f Project Sponsor Module Developer @j.e.f.f
                            @messel @dan-o I think I’ve fixed your issue. Do a git pull in the MMM-DarkSkyForecast directory and restart MM.
                              @j-e-f-f
                              thanks anyway
                              Can you post a screenshot of what you’re trying to change? I think I might be giving you incorrect instructions.
                                Smotx @j.e.f.f
                                @j-e-f-f
                                I want to reduce free space identified by “red areas” on this screen :
                                alt text
                                J 2 Replies Last reply
                                  @smotx screenshot didn’t come through. You don’t need to host the image on Imagur. You can upload it directly when editing your post. Just drag it in, or hit the cloud/upload icon.
                                  • BKeyportB
                                    BKeyport Module Developer
                                    It’s showing for me, @j-e-f-f
                                      @smotx Yeah coming through for me now too. Weird.
                                      OK from the top down:
                                      • The first two regions are actually spacing that accommodates the icon when it appears (It’s currently not appearing due to a bug I fixed today. Do a git pull to update the module and restart MM. You’ll see once the icon is in place, that the vertical space is better used. Keep in mind that the icons are square, and some of them only use a portion of the square. Nonetheless the square still takes up that amount of space. Here’s what it should look like:
                                      You can decrease the space under the header a bit with this:
                                      .MMM-DarkSkyForecast .module-header {
                                        margin-bottom: 5px; /* adjust to taste */
                                      Keep in mind this will also affect the header above the forecast if you have configured it to be there. That can be controlled independently as follows:
                                      .MMM-DarkSkyForecast .module-header.forecast-header {
                                        margin-bottom: 10px; /* adjust to taste */
                                      * the next one below the extra current conditions is margin above the summary.  Adjust it as follows:
                                      .MMM-DarkSkyForecast .summary {
                                      margin-top: 10px; /* adjust to taste */
                                      You can also affect the margin underneath the summary in a similar way:
                                      * The following four below are controlled by the line-height of the time and day displays:
                                      .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .time,
                                      .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
                                      line-height: 20px; /* adjust to taste */
                                      Put all of the CSS changes in your `custom.css` file.  Don't make changes to `MMM-DarkSkyForecast.css` as they will be overwritten if you update the module to a newer version.
                                        Smotx @j.e.f.f
                                        @j-e-f-f
                                        Thx a lot
                                        it’s good now, it remains 2 spaces a little wide, but it does not exceed more on the next module, thank you again.
                                          dan-o
                                          @j-e-f-f came home to see the icon working, which was strange. anyway, grabbed your recent update and it works great. thank you SO MUCH for your time on this :)
                                          D 1 Reply Last reply
                                            dan-o @dan-o
                                            @dan-o said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            Looks like I spoke too soon :(. Was working after a restart. Walked by the mirror just now and no icon present.
                                            • 16
                                            • 17
                                            • 3 / 17
