    How do all of you controle (/interact with) your MagicMirror modules?
    18 Posts 8 Posters 8.5k Views 8 Watching
      MWel1977
      I just have added Lucy to my “modules to add” list!:grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:
      I’ll try to figure it out myself first (that’s the most fun) If not… @Mykle1 Is it okay to send you a message?
        dazza120 @Mykle1
        @mykle1 does it sound good it sounds great! The farthest that I got was install the three new files in the MMM-voice folder. The other stuff like adding the pages and modules blow my tiny mind. Help would be much appreciated
          Mykle1 Project Sponsor Module Developer @MWel1977
          @mwel1977 said in How do all of you controle (/interact with) your MagicMirror modules?:
          Sure, you can message me, but why not create a topic (ex Hello-Lucy Help) where I can post the help for you. Then, everyone else can see and use the examples posted there. Yeah, I like that idea. You create the topic, explain your needs, and we’ll get you up and running.
            Mykle1 Project Sponsor Module Developer @dazza120
            @dazza120
            Read the post above this one. Same goes for you. One of you create the topic and explain what you’ve done so far and we’ll go from there
              MWel1977 @Mykle1
              @mykle1 When the time comes I will do that!
              First I want the “normal” modules I want to be added to my mirror config and have them working.
                dazza120 @Mykle1
                @mykle1 done thanks I’ve added it to here I’m in the UK and it’s getting late so I’ll have to do what ever you tell me tomorrow after work lol the link is https://forum.magicmirror.builders/topic/9249/help-me-to-get-lucy-working thanks in advance for your help
                  @dazza120
                  Ok, I’ll take a look at your post right now. I’m in NYC, for the record.
                  • F Offline
                    fhansa
                    IM using MQTT to hook up my mirror to HomeAssistant and apples HomeKit-app. This way I automize screen shut-down every evening but also makes it available to the rest of the family.
                    I’ve created a simple module to interact with already existing modules using the notification system
                    An early version here: https://github.com/fhansa/MMM-mqttCommand
                      shbatm Module Developer
                      A couple of shameless plugs for my own modules:
                      Title Description
                      MMM-KeyBindings A module for getting bluetooth remote control and keyboard inputs
                      MMM-OnScreenMenu Simple On-Screen Menu for controlling the MagicMirror²
                      MMM-AlexaOnOff Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)
                      In addition, I’m currently working on a new version of MMM-Remote-Control with a RESTful API – Which is an extension/combination of the original MMM-Remote-Control and MMM-Api modules. See details on the API here. It will allow you to control the mirror with simple URL calls like: http://magicmirror:8080/api/monitor/off to turn off the screen.
                      The end goal is to get rid of duplicate functionality in all of my modules (like exposing external routes, turning on/off the monitor, showing/hiding modules, etc.) and use API calls or Module Notifications for controlling everything, plus allow other modules to customize and integrate their own API.
                      This part is still an active work in progress, but if anyone is interested in testing, please let me know.
                        [[global:former-user]]
                        Here comes an unashamed developer. :D
                        • MMM-AssistantMk2 : Embedded Google Assistant, you can make custom voice command to control MM, it’s module and your system.
                        • MMM-Hotword : Simple voice hotword detection engine - snowboy implements.
                        • MMM-GroveGestures : 3D sensor for gesture recognition.
                        • MMM-TelegramBot : You can interact with your MM via Telegram.
                        • MMM-NotificationTrigger : It has a webhook gateway to request from external Web API(e.g; IFTTT) to deliver MM notification (You need Static IP/domain or DDNS or at least SSH tunnel)
