    Little voice testing.....
    25 Posts 8 Posters 15.6k Views 8 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @CyruS1337
      @cyrus1337 said in Little voice testing.....:
      is it also possible to turn off the monitor?
      Yes, it is.
      https://www.youtube.com/watch?v=3ldlUPkw2nM&feature=youtu.be
      • BKeyportB
        BKeyport Module Developer
        Pretty slick. What’s changing the pages?
        • cowboysdudeC
          cowboysdude Module Developer @CyruS1337
          @cyrus1337 I just say ‘hide modules’… I could tell it to ‘go to sleep’ but haven’t gotten that far yet :)
          • cowboysdudeC
            cowboysdude Module Developer @BKeyport
            @bkeyport MMM-voice and MMM-pages
              mdhenriksen
              Hey mate! Awesome work! Trying to do the same myself! How do you run MM natively on Linux? I can only seem to run it as a server. Are you using Docker or something? Thanks and merry Christmas!
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @mdhenriksen
                @mdhenriksen said in Little voice testing.....:
                Are you asking about something other than a Pi? ubuntu and MM run very happily together. Install ubuntu (I use 16.04 exclusively) and update. Install the latest stable version of node and npm. Install MM and its dependencies. Live a happy life. :)
                  mdhenriksen @Mykle1
                  @mykle1 said in Little voice testing.....:
                  I’ll try with 16.04 then! Currently on 18.10. Do you just run the npm start and then it opens in a new window or how does it work?
                  • Mykle1M
                    Just to be clear, 16.04 LTS. Never had a problem on several machines.
                    Now, everything is exactly the same as if it were running on a Pi. So, yes, all commands are exactly the same, including npm start in the MagicMirror directory
                      mdhenriksen @Mykle1
                      Great. I really appreciate you taking the time to answer me. I’ve tried looking for answers every first and checked the guides as well, but just kept running into some problems.
                      Could you refer me to somewhere that shows how to install dependencies maybe?
                      Merry xmas!
                      • Mykle1M
                        In the case of the installation of MM, after you clone the MM repo, you would navigate to the MagicMirror directory in your terminal and run npm install. That will install the dependencies for MagicMirror. In the case of adding modules, you would navigate to that module folder in your terminal and run npm install. Simple as that. :-)
                          mdhenriksen @Mykle1
                          Awesome, got it working finally! Thanks a lot! Great to see people like you helping out here. It’s much appreciated! :smiling_face_with_open_mouth:
                          • Mykle1M
                            That’s good news! Now enjoy yourself. :thumbsup:
                              dazza120
                              @cowboysdude the modded module works well for something still in development, but I’ve come into an issue where the mic errors when mmm remote connection opens up the browser to view the actual mirror modules like you would see them on the mirror, I have looked of VNC and the mic works but as soon as you use mmm remote control to view the mirror it errors the mic. Any ideas why
                              cowboysdudeC M 2 Replies Last reply
                              • cowboysdudeC
                                cowboysdude Module Developer @dazza120
                                @dazza120 No because I didn’t write MMM-voice I just modified it to work with MMM-Pages.
                                I would create a new topic under the troubleshooting section and see if anyone can help, because for this I really have no idea.
                                Reply Quote 2
                                  mdhenriksen @dazza120
                                  @dazza120 Hey Dazza! I’ve encountered the “ERROR” message with MMM-voice a couple of times as well. I’m not sure what’s going on in your case, but I’ve noticed two things:
                                  1. The voice recognition still works (at least for me). You just have to say your keyword (Magic Mirror) and the ERROR message will disappear and you will be able to use it as normal.
                                  2. For me it happens when I close down the window for Magic Mirror without closing the terminal connected to it. Then it will re-open with the error - Probably because it doesn’t get to load in properly.
                                  D 1 Reply Last reply
                                    dazza120
                                    @cowboysdude thank you for your response I’ll start a new thread on the voice module thanks
                                      dazza120 @mdhenriksen
                                      @mdhenriksen as you said that’s exactly how it behaves, so yes you are right it works as it should but that error is so annoying lol thanks
                                        @dazza120 Then it’s probably because it doesn’t load in properly. Why don’t you just let it be active on all pages? You can just make the module invisible if you don’t like the icon and text being there.
                                          @mdhenriksen yeah that’s not it I’ve made it visible in all, I changed it a while ago :) that’s how I noticed but if I go through it with VNC no errors at all, it’s got to be how the web page is handling it, I’ve got the mmm-Hue-Lights erroring as well only when I view it from that but most of the time I’m using the VNC to view it anyway so no real big deal just annoying when I do 😂
