    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 91.3k Views 14 Watching
    • idoodlerI Offline
      idoodler Module Developer @bobbythemoh
      @bobbythemoh If you use the the observingUuids you need to add the module position.
      The alert module config looks good, what notifications do you want to display?
      The mmm-openhabfloorplan module looks cool. I will definetly look into it :thumbs_up:
      You can create a python periodicaly fetches the statistic files from your Miniserver (http://192.168.0.200/stats) and creates an image from it, saves in the directory the MMM-ImagePhotos module listens to.
        Meininger
        Hi idoodler,
        i have the same problem with the presence option. when i enable the option the display switches off with the light controller in the room. wenn the light in the room is going on, the display is also going on, but only the cursor in the left top is blinking, no MagicMirror information is shown. Ich have updated the MMM-Loxone Modul und the MMM installation, the command in previus postings don´t bring back the screen…
        idoodlerI 1 Reply Last reply Reply Quote 0
        • T Offline
          teddy
          how can I make the table smaller? can someone help me?
          alt text
          • elmatttE Offline
            elmattt
            hi, loxone here too :)
            i use mmm-remotecontrol with loxone to switch on and off the mirror, really easy to set-up :)
            i give a try to your module and come back :)
            • idoodlerI Offline
              idoodler Module Developer @Meininger
              @meininger Hey, I just published an update of MMM-Loxone. Please update your MagicMirror, it fixes some connection issues.
                Meininger @idoodler
                @idoodler thank´s for your help. I have test the changes and the problem with the restart of the Mirror Display is the same as bevor. But the connection to ne new version of the Loxone Room Controller (v2) is now possible to get the room temperature.
                idoodlerI 2 Replies Last reply Reply Quote 1
                • idoodlerI Offline
                  @meininger Thanks for the update. May I ask you to show me your MagicMirrors log via pm2 log mm. Also, what Version do you have installed on your Loxone Miniserver?
                  • idoodlerI Offline
                    @meininger I am asking this, because I noticed, that I have some occasional crashes in some other modules like Calendar and Weather which lead to a crashed MagicMirror, so the presence detection feature isn’t working.
                      Meininger
                      @idoodler so i have an idea how it not works for me. I dont use pm2 to start magicmirror. My mirror is in the badroom also for playing music, so i startet the setup with a max2play distribution for easy Audio Set up. Then i installed the magicmirror Script, its runs perfekt. Only starting the mirror with pm2 dosent work for me. So i looked for an other way to Start, i have found that with the crontap file, it starts the mirror at reboot.
                      At the Moment the mmm-Loxone Script runs ok for me, room Temperature, notifications and virtual Status values are publisched on the mirror. Thank you for this god Job!
                      My Loxone is on the acutal Software Version 10.0.9. 24.
                      • idoodlerI Offline
                        @meininger Ok, there may be some unexpected reconnects due to some changes in the authentication behavior on the Loxone side. But you shouldn’t see an issues because the Module will automatically reconnect to the Miniserver. I will update the module as soon as I can.
                        Thanks for keeping me up-to-date 👍
                        • 10
                        • 5 / 10
