    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 110.8k Views 14 Watching
    • idoodlerI
      idoodler Module Developer @bobbythemoh
      @bobbythemoh I just pushed some changes, please update. Don’t forget to execute npm install after updating MMM-Loxone.
        bobbythemoh
        David, you are my hero, it works!!!
        Energy Consumption of RPI + 24" Monitor Powered ON = 56W; 3.4W if no one is present in the room. AWESOME!
        Thank you for the efforts!
        May I also ask you for the feature request with displaying variables from the Miniserver? Id like to see things like the PV production or an analog value like the level in a tank.
        Thank you so much!
        idoodlerI 2 Replies Last reply
        • idoodlerI
          @bobbythemoh please create a separate Issue in Github for the power consumption thing.
          • idoodlerI
            @bobbythemoh Please check the latest version of MMM-Loxone. It’s not possible to display custom states:)
              bobbythemoh
              Hi @idoodler ,
              I have just tried to get the “observingUuids” working.
              I dont get anything on the MM. My question: Is there a way to test if I did something wrong with “ALERT” or with “MMM-Loxone”
                                  module: "alert",
                                          //display_time: "3500",
                                          //alert_effect: "jelly",
                                          //effect: "slide",
                                          //position: "center"
              MMM-Loxone:
                                  module: "MMM-Loxone",
                                  //position: "top_right", //macht keinen Sinn, ga kein GUI
                                          host: "192.168.0.200",
                                          user: "XXX",
                                          pwd: "XXX",
                                          presence: "true",
                                          //roomUuid: "0ea3ebd1-00eb-0517-ffff390cde3b9b45", //Arbeitszimmer
                                          roomUuid: "0ea3ebd1-00eb-04ef-ffff390cde3b9b45", //Badezimmer
                                          showInfoNotifications: "true",
                                          showErrorNotifications: "true",
                                          showSystemNotifications: "true",
                                          observingUuids:[
                                                          "103d9aaf-0037-597e-ffff390cde3b9b45",//Bad Luftfeuchte
                                                          "11aee03b-01ea-a7bb-ffff390cde3b9b45"
              Furthermore, i found and interesting module called “mmm-openhabfloorplan”. I have seen it is using a HTTP server on the MagicMirror, would it be possible to adapt it for Loxone aswell?
              Regading displaying Charts: I found an extension called “MMM-ImagePhotos” Do you have any Idea, how the “Energy-Monitor” data can be exported on regular basis, like every minute? I was thinking of making a python skript that creates a picture every X Minutes and puts it to the display with the MMM-ImagePhotos. Do you have any suggestions?
              Thank you in advance.
              Robert
              idoodlerI 1 Reply Last reply
              • idoodlerI
                @bobbythemoh If you use the the observingUuids you need to add the module position.
                The alert module config looks good, what notifications do you want to display?
                The mmm-openhabfloorplan module looks cool. I will definetly look into it :thumbs_up:
                You can create a python periodicaly fetches the statistic files from your Miniserver (http://192.168.0.200/stats) and creates an image from it, saves in the directory the MMM-ImagePhotos module listens to.
                  Meininger
                  Hi idoodler,
                  i have the same problem with the presence option. when i enable the option the display switches off with the light controller in the room. wenn the light in the room is going on, the display is also going on, but only the cursor in the left top is blinking, no MagicMirror information is shown. Ich have updated the MMM-Loxone Modul und the MMM installation, the command in previus postings don´t bring back the screen…
                  • T
                    teddy
                    how can I make the table smaller? can someone help me?
                    alt text
                    • elmatttE
                      elmattt
                      hi, loxone here too :)
                      i use mmm-remotecontrol with loxone to switch on and off the mirror, really easy to set-up :)
                      i give a try to your module and come back :)
                      • idoodlerI
                        idoodler Module Developer @Meininger
                        @meininger Hey, I just published an update of MMM-Loxone. Please update your MagicMirror, it fixes some connection issues.
                        M 1 Reply Last reply
                          Meininger @idoodler
                          @idoodler thank´s for your help. I have test the changes and the problem with the restart of the Mirror Display is the same as bevor. But the connection to ne new version of the Loxone Room Controller (v2) is now possible to get the room temperature.
                          • idoodlerI
                            @meininger Thanks for the update. May I ask you to show me your MagicMirrors log via pm2 log mm. Also, what Version do you have installed on your Loxone Miniserver?
                            • idoodlerI
                              @meininger I am asking this, because I noticed, that I have some occasional crashes in some other modules like Calendar and Weather which lead to a crashed MagicMirror, so the presence detection feature isn’t working.
                                Meininger
                                @idoodler so i have an idea how it not works for me. I dont use pm2 to start magicmirror. My mirror is in the badroom also for playing music, so i startet the setup with a max2play distribution for easy Audio Set up. Then i installed the magicmirror Script, its runs perfekt. Only starting the mirror with pm2 dosent work for me. So i looked for an other way to Start, i have found that with the crontap file, it starts the mirror at reboot.
                                At the Moment the mmm-Loxone Script runs ok for me, room Temperature, notifications and virtual Status values are publisched on the mirror. Thank you for this god Job!
                                My Loxone is on the acutal Software Version 10.0.9. 24.
                                • idoodlerI
                                  @meininger Ok, there may be some unexpected reconnects due to some changes in the authentication behavior on the Loxone side. But you shouldn’t see an issues because the Module will automatically reconnect to the Miniserver. I will update the module as soon as I can.
                                  Thanks for keeping me up-to-date 👍
                                    Meininger
                                    @idoodler keeping up to Date is the only way to make Things better… 😉
                                      Meininger
                                      @idoodler at the Moment it is an new error, the mirror dosn´t start. Its an error at boot “detect-rpi” module can not load. So i deactivate the complete Loxone Module in Mirror config file, than start´s the mirror like before, but without the cool Loxone feature. :-(
                                        DO86
                                        Hello everyone,
                                        I also have some trouble configuring the Loxone module. The MM itself and the calender, traffic, weather an News modules are running without any problem.
                                        BUT: The Loxone modules does not want to run at all. Attached you’ll find the required parts of my config.
                                        Maybe some of you can find the wrong passage.
                                        Thanks in advance
                                        B 1 Reply Last reply
                                          bobbythemoh @DO86
                                          @DO86 I think “position” is wrong.
                                          See my config:
        position: "bottom_left",
        host: "Loxone IP",
        user: "Username",
        pwd: "Password",
        presence: "true", //if you want to use the light controller V2 to toggle the display
        roomUuid: "0ea3ebd1-00eb-04ef-ffff390cde3b9b45", //Room ID where MM is located
        observingUuids:[
        "103d9aaf-0037-597e-ffff390cde3b9b45",//Variable you want to observe
                                            bobbythemoh
                                            @idoodler : Today i updated my RPI and i add 2 Modules “MMM-RPI-LED” and “MMM-Moon-Phase” (Just a side info, maybe this is the reason for my issue).
                                            “MMM-Loxone” was working perfect for a long time. Now i am having issues with the Monitor coming alive again.
                                            Test-Scenario:
                                            Light in the Room is ON; in the config I changed Presence: “false” -->MM Starts and works
                                            now i am switching presence: “true”; light is still on -->MM Starts and works
                                            now i am switching off the light --> MM gets dark
                                            now I am switching on the light -->MM stays dark
                                            in the PM2 LOG i can see the status of the light controller changing.
                                            I think there was something changed in the OS. Does anyone experience a similar behaviour?
                                            Thank you.
                                            • 3 / 5
