    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 753.3k Views 27 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Xclasher 0
      @xclasher-0
      If you want to use MMM-Pages and MMM-voice then there doesn’t seem to be a need for the Hello-Lucy enhancement. I don’t think using MMM-Pages and MMM-voice will allow you to do individual modules. I think you can only go back a page or forward a page rather than from any page to any other page.
      Note: You will have to use @cowboysdude’s fork of MMM-voice with MMM-Pages
        mdhenriksen @Mykle1
        @mykle1 said in Hello-Lucy:
        @xclasher-0
        You can make MMM-pages and MMM-voice switch between specific pages with very minors tweaks. 😀
          dazza120
          Do you have to install both forks?
            mdhenriksen @dazza120
            @dazza120 said in Hello-Lucy:
            You need to install the original one and then copy cowboydudes fork (his folders) into the original and overwrite the files that come up.
              @dazza120 Just let me know if it doesn’t work for you.
                dazza120 @mdhenriksen
                @mdhenriksen works a treat but I don’t know how to make a third page. Not sure what I’ll put on it? But I’m sure I’ll find something to install if I figure out how to add more pages it’s stuck on two at the mo 😢
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @mdhenriksen
                  @mdhenriksen said in Hello-Lucy:
                  Well, sure you can, but he didn’t mention wanting, or being able to do any modifications
                  M X 2 Replies Last reply Reply Quote 1
                    mdhenriksen @Mykle1
                    @mykle1 You’re right, guess I was too fast ;-)
                      @mdhenriksen this is my config file so far for pages not sure how I add a third page any ideas
                      module: ‘MMM-pages’,
                      modules:
                      [[ “MMM-NOAA3”, “clock”, “MMM-NetworkConnection”, “mmm-hue-lights”, “mmm-nest-status”, “calendar”, “mmm-systemtemperature”, “compliments”, “newsfeed”],
                      [ “MMM-GoogleMapsTraffic” ]],
                      excludes: [“MMM-page-indicator”],
                        Hey Dazza!
                        It’s pretty easy actually. Now first you should install MMM-page-indicator as well. That makes it easier to see what page you are on.
                        Making several pages:
                               module: 'MMM-pages',
                               modules:
                                           	[[ "weatherforecast", "newsfeed", "compliments"],
                                             	[ "calendar", "compliments", "calendar2"], ["MMM-CalendarWeek"]],
                                        	excludes: ["clock", "currentweather", "MMM-page-indicator", "MMM-voice"],
                        The pages are made in an 2D-array, which is basically a line of elements separated by the brackets “[” and “]”.
                        Your array starts at the double bracket, “[[” right before “weatherforecast” and ends at the “]]” right after “MMM-CalendarWeek”. Inside the array the pages are separated by one bracket.
                        So this is a page: (remember the comma at the end)
                        And this is a page:
                        And lastly this is a page as well:
                        Remember that the array is zero-based which means that the first page will be number 0. The second will be number 1 and the third will be number 2.
                        Hope it helps! :grinning_face_with_smiling_eyes:
                          @mdhenriksen had the page indicator already but I was being a muppet, I didn’t recognise ]] as a closing part for that module, Thank you very much three pages now lol
                            @dazza120 It’s the small things that make the difference :grinning_face_with_smiling_eyes:
                            • X
                              Xclasher 0 @Mykle1
                              @mykle1 Thanks :D I have tested out the integration of both modules. However, I have modified the MMM-voice to have pages in it as stated in the Hello-Lucy documentation. The modules I have included in the MMM-voice pages does not hide when I go to the specific page of the MMM-pages where the MMM-voice is. Any idea how i can hide the modules?
                              Mykle1M M 2 Replies Last reply Reply Quote 0
                                bhepler Module Developer @dazza120
                                @dazza120 - Please use the Markdown features of the forum when posting code.
                                • Mykle1M
                                  @xclasher-0 said in Hello-Lucy:
                                  This is a bit confusing. You’re using MMM- voice with Hello-Lucy AND MMM-pages? My guide on the Hello-Lucy repo is quite easy to follow but I can still help with that. If you’re trying to integrate MMM-pages with that as well then I can’t help you. MMM-pages is not my module. I’ve never used it. You would likely have to modify MMM-voice and MMM-pages
                                    mdhenriksen @Xclasher 0
                                    Hey there! I’m not 100% what you mean, but you can easily hide modules in MMM-pages. The ones that keep showing up might be in your “exclude” section of MMM-pages in your config.js. Anything in “exclude” will show up on every page you have, so you have to remove the modules from that.
                                    X 1 Reply Last reply Reply Quote 0
                                    • Mykle1M
                                      I started thinking, "Why am I using page names like Page One, Page Two? Why not “Weather” for a page of weather modules? Or “Sports” for a page of sports modules? You get the idea. I hope. :-)
                                      https://www.youtube.com/watch?v=Zsm_hi7XvM4&feature=youtu.be
                                      • X
                                        Xclasher 0 @mdhenriksen
                                        @mdhenriksen Hi sorry for the late reply. Let me rephrase my question a bit. What I would like to do is just to have MMM-voice (With Lucy) work on one of the pages (From MMM-pages).
                                        I got that to work however, the pages I created from MMM-voice(With Lucy) aren’t working. And when I included the specific modules, it shows up all the time and does not hide. Though it still response with MMM-voice (With Lucy)
                                        So the problem is, how do I hide the specified modules at the start when magic mirror boot up?.
                                        • Mykle1M
                                          I’m still not sure why you want to use some pages with MMM-pages and others with Hello-Lucy. However, unless there is some conflict with MMM-pages then we can assume you haven’t created your pages correctly in Hello-Lucy. The readme is explicit and should be followed precisely. When you have done it correctly, the only modules displayed at start up will be MMM-voice (and MMM-EasyPix if you are using the face.gif or another image)
                                          • A
                                            Anthony Project Sponsor
                                            I have some problems with Hello Lucy. Firstly sometimes when the MM reloads after Say"Hello, Lucy" I get an ERROR in mic’s icon place. Secondly when I don’t get the ERROR and I say : “MAGIC MIRROR” (my keyword) tha mic icon start flashing (not saying VOICE) but after that anything I say nothing is shown. And i don’t get any errors in pm2 logs or when I start MM with npm start dev . Any suggestions?
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
