    Config.fs
    troubleshootconfigconfig.jsconfiguration
    22 Posts 4 Posters 10.5k Views 4 Watching
      scoller @Guest
      @sean thank’s for the help will try that
        A Former User @scoller
        @scoller
        You have two locationID: "2726470" in your code. both should be modified.
          scoller @Guest
          @sean Specific for my code can you point it out cause I can’t find it, may be because of my lack of knowledge :)
            scoller @Guest
            @sean my code goes like this is this an error?
            Hdhdhdhdu
            Hhdhdhfhdujd.
            Hdhdhhdh
            And the bracket never closes, is that an error?
            ? 1 Reply Last reply
              @scoller
                module: "currentweather",
                  locationID: "2726470", // < - I think here comma missed.
                  appid: "c17305e68b5d2b54d3f2c8b5e2cc4002"
                module: "weatherforecast",
                header: "Vädret i Framtiden",
                  locationID: "2726470", // < - Here also.
                scoller @Guest
                @sean What is that? I see its the code but what?
                  @scoller
                  Exchange those with your current currentweather and weatherforecast in config.js
                    scoller @Guest
                    @sean Thank you again. Is that the problem?
                    Mykle1M ? 2 Replies Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @scoller
                      @scoller
                      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                        @scoller
                        You’ve missed comma after locationID: "2726470" so, just adding it would be enough, but you’d said you couldn’t find where they are, so I told you to exchange whole section.
