    602 Posts 67 Posters 2.2m Views 68 Watching
      shbatm Module Developer @evroom
      @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      after every mm restart
      There was a problem with the steams not stopping on a restart, so the module sends a stop command first whenever it starts, do you have autoStart: true in your config?
        shbatm Module Developer @Cr4z33
        @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        With omxplayer (and autoStart: false) I see stream labels changing when giving a voice command, but then no stream is starting.
        OK. I’ll check this later today, the notification RTSP-PLAY should switch and start the stream so that’s an issue.
          shbatm Module Developer @shbatm
          @Cr4z33 try inserting this.playing = true; at Line 574 as the first line in the if statement and see if that works. I’ll test later today.
          EDIT: Just pushed an update. Please try the latest release in develop
          • evroomE Offline
            evroom @shbatm
            @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            Yes, I have.
            Just to understand, when you start fresh, there is no omx_stream1 under pm2 list.
            When you start your first stream, it is first visible under pm2 list, right?
            Till now I was able to start the stream with pm2 start, but after removing the stream (pm2 remove omx_stream1), I cannot get it to work anymore.
            MM restart, reboot, nothing helps.
            And pm2 start now says:
            pi@MagicPi:~ $ pm2 start omx_stream1
            [PM2][ERROR] script not found : /home/pi/omx_stream1
            │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
            │ mm       │ 0  │ 2.5.0   │ fork │ 811 │ online │ 0       │ 4m     │ 0%  │ 2.5 MB   │ pi   │ disabled │
            Which makes sort of sense.
            After MM restart, pm2 logs shows:
            0|mm  | Connecting socket for: MMM-RTSPStream
            0|mm  | PM2: Stopping all OMXPlayer Streams...
            0|mm  | Sockets connected & modules started ...
            0|mm  | Launching application.
            Will revert back to the master branch and try again.
            MagicMirror version: 2.36.0
              Yes, the omx_stream1 is created the first time you play a stream with the module.
              Please use the develop branch with omxplayer. It was working on my machine the last time I started.
              • Cr4z33C Offline
                Cr4z33 @shbatm
                @shbatm things are doing waaaay better now! :grinning_face_with_smiling_eyes:
                With omxplayer stream switching is almost OK if it wasn’t that it doesn’t select the wanted stream.
                Ie. I want stream3 therefore I give the voice command, but then it starts playing the wrong stream (and always random).
                Voice recognition is 100% correct as I always have a textual confirmation of command on screen.
                With vlc it’s a mess as multiple streams ALWAYS start at the same time after a voice command.
                At this point I don’t care who will be the chosen player as long as we get everything working so omxplayer would be fair enough if running properly. :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_cold_sweat:
                • evroomE Offline
                  evroom @shbatm
                  Back on develop branch again.
                  No change.
                  Now the “pm2 remove omx_stream1” looks to be a major mistake, as I cannot get the stream running again.
                  I do not see the module trying to start a new stream anymore.
                  What would be the command line for starting the stream and having it appear under “pm2 list” ?
                  In other words, what does the module do in order to achieve this ?
                    Please send me your config in a chat.
                      I can’t replicate this issue. Directly sending notifications: of the form notification: "RTSP-PLAY", payload: "streamX" works as expected and switches to the correct stream when using autoStart: false, rotateStreams: true, rotateStreamTimeout: 0.
                      How many streams do you have again? Is it less than 10?
                      I think this is related to the fact that VLC doesn’t close the streams automatically when switching, it puts the window in the background until it times out, then it closes. Try adding a shutdownDelay: 0 to your module config to make the VLC stream close immediately on hiding. Same thing with omxplayer though, switching appears to work as expected on my end.
                      Please also make sure you have the latest version of PM2: sudo npm install -g pm2
                        djuscha
                        @shbatm
                        did develop update now, both streams are on stop and error messages :(
                        PM2            | App [omx_stream2:1] online
                        0|mm           | Initializing new module helper ...
                        0|mm           | Module helper loaded: newsfeed
                        2|omx_stream1  | * failed to add service - already in use?
                        2|omx_stream1  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
                        2|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
                        2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1221 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        PM2            | App [omx_stream1:2] exited with code [134] via signal [SIGINT]
                        PM2            | App [omx_stream1:2] starting in -fork mode-
                        PM2            | App [omx_stream1:2] online
                        1|omx_stream2  | * failed to add service - already in use?
                        1|omx_stream2  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
                        1|omx_stream2  | Subtitle count: 0, state: off, index: 1, delay: 0
                        1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1244 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        PM2            | App [omx_stream2:1] exited with code [134] via signal [SIGINT]
                        PM2            | App [omx_stream2:1] starting in -fork mode-
                        2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1287 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        0|mm           | Module helper loaded: MMM-RTSPStream
                        0|mm           | All module helpers loaded.
                        0|mm           | Starting server on port 8080 ...
                        0|mm           | Server started ...
                        0|mm           | Connecting socket for: updatenotification
                        0|mm           | Connecting socket for: MMM-Fuel
                        0|mm           | Starting module helper: MMM-Fuel
                        0|mm           | Connecting socket for: newsfeed
                        0|mm           | Starting module: newsfeed
                        1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1320 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1349 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1399 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1422 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                        0|mm           | libGL error: MESA-LOADER: failed to retrieve device information
                        ^C
                        pi@raspberrypi:~ $ pm2 status
                        │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                        │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.5 MB   │
                        │ omx_stream1 │ 2  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
                        │ omx_stream2 │ 1  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
                         Use `pm2 show <id|name>` to get more details about an app
                        pi@raspberrypi:~ $
                        can you undo that somehow?
                          shbatm Module Developer @djuscha
                          @djuscha said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          This looks like the same error I got when I tried to use omxplayer with the OpenGL driver enabled in raspi-config. You’ll have to use the legacy driver if you want to use omxplayer on the most recent version of Raspbian.
                          EDIT 10-Jan-19: Use the latest develop branch version. omxplayer requires the --no-osd flag to work properly with the OpenGL (Fake KMS) driver.
                          • Cr4z33C Offline
                            Cr4z33 @shbatm
                            @shbatm I can confirm that I followed the whole instructions properly and I am using notification: "RTSP-PLAY", payload: "streamX" indeed for my 7 different streams (so yes less than 10).
                            All I can say is that it is NOT working as intended. :winking_face:
                            Anyway I always forgot to post the (latest version) PM2 log so here it is if you can find anything helpful?
                            I wish I could do more, but again I am not skilled enough sorry… :smiling_face_with_open_mouth_cold_sweat:
                            PM2 Log
                              @cr4z33 @evroom the last things I can suggest to try:
                              1. @Cr4z33 Make sure you have autoStart: false in your config. @evroom yours should be true.
                              2. Update the module one more time:
                              cd ~/MagicMirror/modules/MMM-RTSPStream
                              git fetch --al && git pull
                              rm -R node_modules/
                              npm install
                              1. Nuke and update your pm2:
                              pm2 kill
                              rm ~/.pm2/dump.pm2
                              sudo npm i -g pm2
                              1. Restart the MM script (you’ll have to redo pm2 save BEFORE you run any streams if you want the MM to start on boot).
                              Cr4z33C evroomE 2 Replies Last reply Reply Quote 0
                              • Cr4z33C Offline
                                Cr4z33 @shbatm
                                @shbatm I feel sorry, but nothing has improved. :disappointed_face:
                                • evroomE Offline
                                  evroom @shbatm
                                  @shbatm
                                  Performed all steps.
                                  No change: no stream is started (nothing in the pm2 logs).
                                  Then deleted the MMM-RTSPStream module completely.
                                  Rebooted.
                                  Installed the module again.
                                  Then performed all steps to get in the develop branch.
                                  I ended up disabling the module and running a script under pm2 control.
                                  Pity, it worked just fine till I started to test the changes.
                                  The ‘pm2 delete omx_stream1’ was the final blow, but should not be the reason for a stream not to appear again.
                                  Perhaps a complete re-install of MM is necessary, but that is too much work for now.
                                  Should I be forced to do so in the future, I will give MMM-RTSPStream a try again.
                                    @cr4z33 Can you please post (or send in chats) your current config. I’m curious if we’re missing something obvious.
                                    @evroom I’m sorry you can’t get it working again. I’m at a loss as to why it’s not starting the streams properly. Everything in your config you sent looks like it should be working from the module’s end. The only thing I can think of is something else is interfering and preventing the module from starting. (Would show up as a “MMM-RTSPStream is suspended…” in the DevTools (web browser) console logs.
                                      anthony6608 @evroom
                                      @evroom I’m sorry but I haven’t read too far back in the posts but have you tried disabling your other modules to determine if there’s a conflict somewhere?
                                      The reason I ask is because shbatm helped me recently with everything setup correctly but stream not displaying. One of the issues turned out to be the GoogleMapsTraffic module. Just wanted to mention that just in case. Good luck!
                                      • Cr4z33C Offline
                                        Cr4z33 @shbatm
                                        @shbatm here you go. :slightly_smiling_face:
                                        config.js
                                          costascontis
                                          hi ,trying to use this module to watch an ip cam.After i start MM i get in the log:
                                          Starting stream stream1 with args: [
                                              "--avdict",
                                              "rtsp_transport:tcp",
                                              "--win",
                                              "738, 63, 1090, 305",
                                              "--live",
                                              "--video_queue",
                                              "4",
                                              "--fps",
                                              "30",
                                              "rtsp://admin:@192.168.1.108:554/12?"
                                          error: object file .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259 is empty
                                          fatal: loose object 0a340d5d575f5675a19c2108bb1acc9f20576259 (stored in .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259) is corrupt
                                          fatal: The remote end hung up unexpectedly
                                          Starting PM2 for omx_stream1
                                          PM2 started for omx_stream1
                                          when i press pause and play again i get:
                                          Stopping stream stream1
                                          Stopping PM2 process: omx_stream1
                                              "--avdict",
                                              "--win",
                                              "--live",
                                              "--video_queue",
                                              "4",
                                              "--fps",
                                              "30",
                                          I just get a blank screen.Steam is working nice with vlc,its the second low res stream of this camera.
                                          config:
                                              module: "MMM-RTSPStream",
                                              position: "top_center",
                                                  autoStart: true,
                                                  rotateStreamTimeout: 10,
                                                  moduleWidth: 354,
                                                  moduleHeight: 240,
                                                  localPlayer: 'omxplayer',
                                                  remotePlayer: 'none',
                                                  showSnapWhenPaused: false,
                                                  remoteSnaps: false,
                                                  stream1: {
                                                      url: 'rtsp://admin:@192.168.1.108:554/12?',
                                                      frameRate: undefined,
                                                      width: undefined,
                                                      height: undefined,
                                          any ideas?
                                            shbatm Module Developer @costascontis
                                            For the first one:
                                            @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                            That’s a new one by me… maybe time for Google on that one.
                                            For the blank screen: watch all of the PM2 logs (pm2 logs command) and see if you see something like this:
                                            1|omx_stre | * failed to add service - already in use?
                                            1|omx_stre | /usr/bin/omxplayer: line 67: 15281 Aborted (core dumped)
                                            If you do, you probably have the latest version of Raspbian with the OpenGL driver enabled in raspi-config– omxplayer isn’t working properly with the OpenGL driver enabled, if you want to use omxplayer, you’ll have to enable the legacy driver: https://www.raspberrypi.org/forums/viewtopic.php?t=204794
                                            If you see anything else in the PM2 logs, let me know.
                                            • 10
                                            • 11
                                            • 12
                                            • 30
                                            • 31
                                            • 10 / 31
