    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • Cr4z33C
      Cr4z33 @evroom
      @evroom can you please let me chat with you?
      Need to ask you something about this module. :)
      evroomE 1 Reply Last reply
      • evroomE
        evroom @Cr4z33
        @cr4z33
        Yes, you can chat with me.
        MagicMirror version: 2.37.0
        Cr4z33C 1 Reply Last reply
        • Cr4z33C
          Cr4z33 @evroom
          @evroom nope the forum keeps saying you have restricted the chats only to people you are following.
          • evroomE
            evroom @Cr4z33
            @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            Okay, now I understand your request better.
            Unchecked it, should be working now.
            • evroomE
              evroom
              Looks like it does not work VU+ boxes.
              I used the latest master branch (installed the complete module new).
              All api paths have been checked and return xml data.
              Dreambox DM7020HD:
              $ pm2 restart mm
              0|mm  | Starting node helper for: MMM-Dreambox
              On the Mirror a list of channels is seen.
              VU+ zero:
              0|mm  | Whoops! There was an uncaught exception...
              0|mm  | TypeError: Cannot read property 'code' of null
              0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:37)
              0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
              0|mm  |     at emitTwo (events.js:126:13)
              0|mm  |     at Request.emit (events.js:214:7)
              0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
              0|mm  |     at emitOne (events.js:116:13)
              0|mm  |     at Request.emit (events.js:211:7)
              0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
              0|mm  |     at Object.onceWrapper (events.js:313:30)
              0|mm  |     at emitNone (events.js:111:20)
              0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              121		//5.Request - Servicelistplayable
              122		request({url: myUrl+this.config.apiServicelistplayable }, function (error, response, body) {
              123			if (!error && response.statusCode == 200) {
              124				self.sendSocketNotification("DATA",['DB-SLP',body]);
              125			} else {
              126				if (!error && response.statusCode == 404){
              127					Errormessage = 'Error: '+response.statusCode+' in '+myUrl+self.config.apiServicelistplayable;
              128				} else {
              129					Errormessage = 'Error: '+error.code+' in '+myUrl+self.config.apiServicelistplayable;
              130				}
              131				self.sendSocketNotification("DATA",['ERROR',Errormessage]);
              132			}
              133		});
              apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
              http://192.168.178.47/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet
              <e2servicelistplayable>
              Nothing is seen on the Mirror.
              • Cr4z33C
                Cr4z33 @evroom
                @evroom that’s EXACTLY what happens on my mirror as an owner of a Vu+ product.
                @AxLed can you please look into this? :)
                • A
                  AxLed Module Developer
                  @Cr4z33
                  Can you please post your config for MMM-Dreambox (as i guess there are two problems):
                  1. at least one of your links are wrong or VU+ uses different syntax (for the xml links)
                  2. i think node_helper.js line 129 is wrong in my code, i cant correct it without testing (error.code is null and my code expects an value)
                  apiBase:
                  omxargs:
                  refreshInterval:
                  apiabout:
                  apiservices:
                  apiepgnow:
                  apizap:
                  apiTimerlist:
                  apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
                  listmax:
                  AxLED
                  • evroomE
                    evroom
                    Hi AxLed,
                    Here is my VU+ config:
                    module: 'MMM-Dreambox',
                    disabled: false,
                    position:"top_left",
                    header: 'Dreambox',
                      apiBase: 'http://192.168.178.47:80',
                      omxargs: ' --win 0,625,590,957 -o both ',
                      refreshInterval: 1000 * 30, //refresh every 30 seconds
                      apiabout: '/web/about',
                      apiservices: '/web/getallservices',
                      apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                      apizap: '/web/zap?sRef=',
                      apiTimerlist: '/web/timerlist',
                      apibouquet: 0,
                      listmax: 10,
                    To be honest, I do not see any difference between a Dreambox and a VU Plus, in fact the bRef and sRef are exactly the same and even the same as in the README.
                    But if you say there is a difference …
                    If the line 129 needs modifying, I can do so by hand.
                    Perhaps will save you some time.
                    And could you tell us if you tested on a VU+ or on a Dreambox (or both) ?
                    • A
                      @evroom
                      To answer your questions:
                      • i tested on a dreambox (dm800se) with a single dvb-c tuner
                      • modifying line 129 could help, i need the output of ‘error’ and ‘response’, as i only check for ‘error’ (true/false) and only for response.Statuscode 200 and 404.
                      I have some questions too:
                      • if you enter http://192.168.178.47:80/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet in you browser, is there xml showing up?
                      • if not, what else is shown?
                      • the xml files you send me on 29th of december, where they from your dreambox or from VU+?
                      • if the were from the dreambox, can you please send me the following file from your VU+ by email ak10zeichen-xy@yahoo.de :
                      • http://192.168.178.47:80/web/getallservices
                      So i can check what is going wrong.
                      AxLED
                      • evroomE
                        evroom
                        @AxLed
                        Yes, now I remember that you used a dm800se.
                        And then it was you who explained me how to post xml data in this forum (which I forgot again).
                        The xml files from December were from a Dreambox.
                        Perhaps you mean that the syntax of the xml data is different, not the syntax in the config file.
                        Then I understand.
                        The servicelistplayable URL return xml data, as do all /web/ calls.
                        The getallservices xml data will arrive by mail in a minute.
                        • A
                          @evroom
                          Thanks for the files, i tested with your files, but i am getting a different error:
                          Your error (some topics above): Problem at servicelistplayable
                          My error (with your VU xml files): Problem in MMM-Dreambox.js at line 387, where the timerlist expects a value. I can fix this error, somehow my code expects at least one timer.
                          Can you please tell me, at which point/line of code you get an error?
                          If your error is in MMM-Dreambox.js at line 387 can you try to add one timer in the future an test again?
                          AxLED
                          • evroomE
                            evroom
                            @AxLed
                            Sent you a timer list.
                            The last time I checked, the error pointed to line 129.
                            Unfortunately my DLAN adaptor died where my MagicMirror and other devices are connected.
                            When it works again, I can answer the other questions.
                            • A
                              @evroom
                              So i can fix the handling of an “empty” timerlist meanwhile, but this will take until the end of the week.
                              I am looking forward to hear from you if your DLAN adoptor is back online.
                              AxLED
                              • evroomE
                                evroom
                                @AxLed
                                Just sent you pm2 logs output.
                                There is a lot more than I initialy placed on the forum.
                                I thought all errors were the same, but the node_helper.js line differ.
                                • Cr4z33C
                                  Cr4z33 @AxLed
                                  @axled sorry for replaying late again, but I always work at night. :winking_face:
                                  Do you still need my config or are you already done?
                                  • A
                                    @Cr4z33
                                    I got some testfiles for VU+ from Evroom and i have to do some modification and testing to the module within the next days.
                                    AxLED
                                    • Cr4z33C
                                      Cr4z33 @AxLed
                                      @axled alright. :thumbs_up_medium-light_skin_tone:
                                      • A
                                        @evroom
                                        I did some bugfixing:
                                        • bugfixing in error response (node_helper.js)
                                        • bugfix in handling timerlist if empty (MMM-Dreambox.js)
                                        Please check the dev branch of my module:
                                        • Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                        • do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                        Tell me what happens now, if you try to connect to VU+ receiver.
                                        Regards
                                        AxLED
                                        • evroomE
                                          evroom
                                          @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                          Unfortunately still (the same?) errors:
                                          0|mm  | TypeError: Cannot read property 'statusCode' of undefined
                                          0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:75:42)
                                          0|mm  |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                          0|mm  |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:877:8)
                                          0|mm  |     at ClientRequest.emit (events.js:211:7)
                                          0|mm  |     at Socket.socketErrorListener (_http_client.js:387:9)
                                          0|mm  |     at Socket.emit (events.js:211:7)
                                          pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ git status
                                          On branch dev
                                          Your branch is up-to-date with 'origin/dev'.
                                          nothing to commit, working tree clean
                                          pi@MagicPi:~/MagicMirror/modules $ grep 'at Request._callback' /home/pi/.pm2/logs/mm-error.log | sort -u
                                              at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:103:42)
                                              at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:116:42)
                                              at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:42)
                                              at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:89:42)
                                          A 1 Reply Last reply
                                          • evroomE
                                            evroom
                                            @AxLed
                                            I also tried the Dreambox.
                                            There are no errors and the play list is shown on the Mirror.
                                            However, there is a problem when you put the port in the config.js:
                                            pi@MagicPi:~ $ ps -eaf | grep omxplayer | grep -v grep
                                            pi       20618 20445  1 22:07 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20619 20618  1 22:07 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20642 20619  0 22:07 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            You see that streaming uses port 8001, so you get 80:8001 as port.
                                            In my case, I use the standard port 80, so I can leave it out, but for example @Cr4z33 uses a different port, so he will not be able to stream.
                                            So, my suggestion is to set the port as a separate variable in the config and only use it where necessary.
                                            • 4 / 8
