    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • evroomE
      evroom @Cr4z33
      @cr4z33
      @evroom can you please let me chat with you?
      Need to ask you something about this module. :)
      Yes, you can chat with me.
      MagicMirror version: 2.37.0
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @evroom
        @evroom nope the forum keeps saying you have restricted the chats only to people you are following.
        evroomE 1 Reply Last reply
        • evroomE
          evroom @Cr4z33
          @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          Okay, now I understand your request better.
          Unchecked it, should be working now.
          • evroomE
            evroom
            Looks like it does not work VU+ boxes.
            I used the latest master branch (installed the complete module new).
            All api paths have been checked and return xml data.
            Dreambox DM7020HD:
            $ pm2 restart mm
            0|mm  | Starting node helper for: MMM-Dreambox
            On the Mirror a list of channels is seen.
            VU+ zero:
            0|mm  | Whoops! There was an uncaught exception...
            0|mm  | TypeError: Cannot read property 'code' of null
            0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:37)
            0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
            0|mm  |     at emitTwo (events.js:126:13)
            0|mm  |     at Request.emit (events.js:214:7)
            0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
            0|mm  |     at emitOne (events.js:116:13)
            0|mm  |     at Request.emit (events.js:211:7)
            0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
            0|mm  |     at Object.onceWrapper (events.js:313:30)
            0|mm  |     at emitNone (events.js:111:20)
            0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            121		//5.Request - Servicelistplayable
            122		request({url: myUrl+this.config.apiServicelistplayable }, function (error, response, body) {
            123			if (!error && response.statusCode == 200) {
            124				self.sendSocketNotification("DATA",['DB-SLP',body]);
            125			} else {
            126				if (!error && response.statusCode == 404){
            127					Errormessage = 'Error: '+response.statusCode+' in '+myUrl+self.config.apiServicelistplayable;
            128				} else {
            129					Errormessage = 'Error: '+error.code+' in '+myUrl+self.config.apiServicelistplayable;
            130				}
            131				self.sendSocketNotification("DATA",['ERROR',Errormessage]);
            132			}
            133		});
            apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
            http://192.168.178.47/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet
            <e2servicelistplayable>
            Nothing is seen on the Mirror.
            • Cr4z33C
              Cr4z33 @evroom
              @evroom that’s EXACTLY what happens on my mirror as an owner of a Vu+ product.
              @AxLed can you please look into this? :)
              • A
                AxLed Module Developer
                @Cr4z33
                Can you please post your config for MMM-Dreambox (as i guess there are two problems):
                1. at least one of your links are wrong or VU+ uses different syntax (for the xml links)
                2. i think node_helper.js line 129 is wrong in my code, i cant correct it without testing (error.code is null and my code expects an value)
                apiBase:
                omxargs:
                refreshInterval:
                apiabout:
                apiservices:
                apiepgnow:
                apizap:
                apiTimerlist:
                apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
                listmax:
                AxLED
                • evroomE
                  evroom
                  Hi AxLed,
                  Here is my VU+ config:
                  module: 'MMM-Dreambox',
                  disabled: false,
                  position:"top_left",
                  header: 'Dreambox',
                    apiBase: 'http://192.168.178.47:80',
                    omxargs: ' --win 0,625,590,957 -o both ',
                    refreshInterval: 1000 * 30, //refresh every 30 seconds
                    apiabout: '/web/about',
                    apiservices: '/web/getallservices',
                    apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                    apizap: '/web/zap?sRef=',
                    apiTimerlist: '/web/timerlist',
                    apibouquet: 0,
                    listmax: 10,
                  To be honest, I do not see any difference between a Dreambox and a VU Plus, in fact the bRef and sRef are exactly the same and even the same as in the README.
                  But if you say there is a difference …
                  If the line 129 needs modifying, I can do so by hand.
                  Perhaps will save you some time.
                  And could you tell us if you tested on a VU+ or on a Dreambox (or both) ?
                  • A
                    @evroom
                    To answer your questions:
                    • i tested on a dreambox (dm800se) with a single dvb-c tuner
                    • modifying line 129 could help, i need the output of ‘error’ and ‘response’, as i only check for ‘error’ (true/false) and only for response.Statuscode 200 and 404.
                    I have some questions too:
                    • if you enter http://192.168.178.47:80/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet in you browser, is there xml showing up?
                    • if not, what else is shown?
                    • the xml files you send me on 29th of december, where they from your dreambox or from VU+?
                    • if the were from the dreambox, can you please send me the following file from your VU+ by email ak10zeichen-xy@yahoo.de :
                    • http://192.168.178.47:80/web/getallservices
                    So i can check what is going wrong.
                    AxLED
                    • evroomE
                      evroom
                      @AxLed
                      Yes, now I remember that you used a dm800se.
                      And then it was you who explained me how to post xml data in this forum (which I forgot again).
                      The xml files from December were from a Dreambox.
                      Perhaps you mean that the syntax of the xml data is different, not the syntax in the config file.
                      Then I understand.
                      The servicelistplayable URL return xml data, as do all /web/ calls.
                      The getallservices xml data will arrive by mail in a minute.
                      • A
                        @evroom
                        Thanks for the files, i tested with your files, but i am getting a different error:
                        Your error (some topics above): Problem at servicelistplayable
                        My error (with your VU xml files): Problem in MMM-Dreambox.js at line 387, where the timerlist expects a value. I can fix this error, somehow my code expects at least one timer.
                        Can you please tell me, at which point/line of code you get an error?
                        If your error is in MMM-Dreambox.js at line 387 can you try to add one timer in the future an test again?
                        AxLED
                        • evroomE
                          evroom
                          @AxLed
                          Sent you a timer list.
                          The last time I checked, the error pointed to line 129.
                          Unfortunately my DLAN adaptor died where my MagicMirror and other devices are connected.
                          When it works again, I can answer the other questions.
                          • A
                            @evroom
                            So i can fix the handling of an “empty” timerlist meanwhile, but this will take until the end of the week.
                            I am looking forward to hear from you if your DLAN adoptor is back online.
                            AxLED
                            • evroomE
                              evroom
                              @AxLed
                              Just sent you pm2 logs output.
                              There is a lot more than I initialy placed on the forum.
                              I thought all errors were the same, but the node_helper.js line differ.
                              • Cr4z33C
                                Cr4z33 @AxLed
                                @axled sorry for replaying late again, but I always work at night. :winking_face:
                                Do you still need my config or are you already done?
                                • A
                                  @Cr4z33
                                  I got some testfiles for VU+ from Evroom and i have to do some modification and testing to the module within the next days.
                                  AxLED
                                  • Cr4z33C
                                    Cr4z33 @AxLed
                                    @axled alright. :thumbs_up_medium-light_skin_tone:
                                    • A
                                      @evroom
                                      I did some bugfixing:
                                      • bugfixing in error response (node_helper.js)
                                      • bugfix in handling timerlist if empty (MMM-Dreambox.js)
                                      Please check the dev branch of my module:
                                      • Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                      • do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                      Tell me what happens now, if you try to connect to VU+ receiver.
                                      Regards
                                      AxLED
                                      • evroomE
                                        evroom
                                        @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                        Unfortunately still (the same?) errors:
                                        0|mm  | TypeError: Cannot read property 'statusCode' of undefined
                                        0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:75:42)
                                        0|mm  |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                        0|mm  |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:877:8)
                                        0|mm  |     at ClientRequest.emit (events.js:211:7)
                                        0|mm  |     at Socket.socketErrorListener (_http_client.js:387:9)
                                        0|mm  |     at Socket.emit (events.js:211:7)
                                        pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ git status
                                        On branch dev
                                        Your branch is up-to-date with 'origin/dev'.
                                        nothing to commit, working tree clean
                                        pi@MagicPi:~/MagicMirror/modules $ grep 'at Request._callback' /home/pi/.pm2/logs/mm-error.log | sort -u
                                            at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:103:42)
                                            at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:116:42)
                                            at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:42)
                                            at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:89:42)
                                        A 1 Reply Last reply
                                        • evroomE
                                          evroom
                                          @AxLed
                                          I also tried the Dreambox.
                                          There are no errors and the play list is shown on the Mirror.
                                          However, there is a problem when you put the port in the config.js:
                                          pi@MagicPi:~ $ ps -eaf | grep omxplayer | grep -v grep
                                          pi       20618 20445  1 22:07 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20619 20618  1 22:07 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20642 20619  0 22:07 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          You see that streaming uses port 8001, so you get 80:8001 as port.
                                          In my case, I use the standard port 80, so I can leave it out, but for example @Cr4z33 uses a different port, so he will not be able to stream.
                                          So, my suggestion is to set the port as a separate variable in the config and only use it where necessary.
                                          • evroomE
                                            evroom
                                            @AxLed
                                            Other observations (tested with Dreambox dm7020hd).
                                            1/
                                            When I start the Mirror, I no channel is selected.
                                            Then when you do DB-PLAY as first remote command, the list on the Mirror will have a grey background (as if everything is selected) and nothing is streamed.
                                            2/
                                            When you do DB-PLAY, I get multiple streams.
                                            I reported this before.
                                            pi       20862 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20863 20862  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20886 20863  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20894 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20895 20894  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            pi       20921 20895  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                            3/ After a while the selection of a channel disappears.
                                            The selection sometimes is just a grey background and sometimes a grey background with a play button.
                                            4/ My Dreambox has 2 tuners.
                                            I probably see the “now playing” from tuner A, whilst tuner B is streaming.
                                            As the selection disappears, I do not know which channel is streaming.
                                            • 4 / 8
