    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 217.6k Views 6 Watching
    • Cr4z33C Offline
      Cr4z33 @evroom
      @evroom nope the forum keeps saying you have restricted the chats only to people you are following.
      • evroomE Offline
        evroom @Cr4z33
        @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        Okay, now I understand your request better.
        Unchecked it, should be working now.
        MagicMirror version: 2.37.0
        • evroomE Offline
          evroom
          Looks like it does not work VU+ boxes.
          I used the latest master branch (installed the complete module new).
          All api paths have been checked and return xml data.
          Dreambox DM7020HD:
          $ pm2 restart mm
          0|mm  | Starting node helper for: MMM-Dreambox
          On the Mirror a list of channels is seen.
          VU+ zero:
          0|mm  | Whoops! There was an uncaught exception...
          0|mm  | TypeError: Cannot read property 'code' of null
          0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:37)
          0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
          0|mm  |     at emitTwo (events.js:126:13)
          0|mm  |     at Request.emit (events.js:214:7)
          0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
          0|mm  |     at emitOne (events.js:116:13)
          0|mm  |     at Request.emit (events.js:211:7)
          0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
          0|mm  |     at Object.onceWrapper (events.js:313:30)
          0|mm  |     at emitNone (events.js:111:20)
          0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          121		//5.Request - Servicelistplayable
          122		request({url: myUrl+this.config.apiServicelistplayable }, function (error, response, body) {
          123			if (!error && response.statusCode == 200) {
          124				self.sendSocketNotification("DATA",['DB-SLP',body]);
          125			} else {
          126				if (!error && response.statusCode == 404){
          127					Errormessage = 'Error: '+response.statusCode+' in '+myUrl+self.config.apiServicelistplayable;
          128				} else {
          129					Errormessage = 'Error: '+error.code+' in '+myUrl+self.config.apiServicelistplayable;
          130				}
          131				self.sendSocketNotification("DATA",['ERROR',Errormessage]);
          132			}
          133		});
          apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
          http://192.168.178.47/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet
          <e2servicelistplayable>
          Nothing is seen on the Mirror.
          • Cr4z33C Offline
            Cr4z33 @evroom
            @evroom that’s EXACTLY what happens on my mirror as an owner of a Vu+ product.
            @AxLed can you please look into this? :)
              AxLed Module Developer
              @Cr4z33
              Can you please post your config for MMM-Dreambox (as i guess there are two problems):
              1. at least one of your links are wrong or VU+ uses different syntax (for the xml links)
              2. i think node_helper.js line 129 is wrong in my code, i cant correct it without testing (error.code is null and my code expects an value)
              apiBase:
              omxargs:
              refreshInterval:
              apiabout:
              apiservices:
              apiepgnow:
              apizap:
              apiTimerlist:
              apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
              listmax:
              AxLED
              • evroomE Offline
                evroom
                Hi AxLed,
                Here is my VU+ config:
                module: 'MMM-Dreambox',
                disabled: false,
                position:"top_left",
                header: 'Dreambox',
                  apiBase: 'http://192.168.178.47:80',
                  omxargs: ' --win 0,625,590,957 -o both ',
                  refreshInterval: 1000 * 30, //refresh every 30 seconds
                  apiabout: '/web/about',
                  apiservices: '/web/getallservices',
                  apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                  apizap: '/web/zap?sRef=',
                  apiTimerlist: '/web/timerlist',
                  apibouquet: 0,
                  listmax: 10,
                To be honest, I do not see any difference between a Dreambox and a VU Plus, in fact the bRef and sRef are exactly the same and even the same as in the README.
                But if you say there is a difference …
                If the line 129 needs modifying, I can do so by hand.
                Perhaps will save you some time.
                And could you tell us if you tested on a VU+ or on a Dreambox (or both) ?
                  @evroom
                  To answer your questions:
                  • i tested on a dreambox (dm800se) with a single dvb-c tuner
                  • modifying line 129 could help, i need the output of ‘error’ and ‘response’, as i only check for ‘error’ (true/false) and only for response.Statuscode 200 and 404.
                  I have some questions too:
                  • if you enter http://192.168.178.47:80/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet in you browser, is there xml showing up?
                  • if not, what else is shown?
                  • the xml files you send me on 29th of december, where they from your dreambox or from VU+?
                  • if the were from the dreambox, can you please send me the following file from your VU+ by email ak10zeichen-xy@yahoo.de :
                  • http://192.168.178.47:80/web/getallservices
                  So i can check what is going wrong.
                  AxLED
                  • evroomE Offline
                    evroom
                    @AxLed
                    Yes, now I remember that you used a dm800se.
                    And then it was you who explained me how to post xml data in this forum (which I forgot again).
                    The xml files from December were from a Dreambox.
                    Perhaps you mean that the syntax of the xml data is different, not the syntax in the config file.
                    Then I understand.
                    The servicelistplayable URL return xml data, as do all /web/ calls.
                    The getallservices xml data will arrive by mail in a minute.
                      @evroom
                      Thanks for the files, i tested with your files, but i am getting a different error:
                      Your error (some topics above): Problem at servicelistplayable
                      My error (with your VU xml files): Problem in MMM-Dreambox.js at line 387, where the timerlist expects a value. I can fix this error, somehow my code expects at least one timer.
                      Can you please tell me, at which point/line of code you get an error?
                      If your error is in MMM-Dreambox.js at line 387 can you try to add one timer in the future an test again?
                      AxLED
                      • evroomE Offline
                        evroom
                        @AxLed
                        Sent you a timer list.
                        The last time I checked, the error pointed to line 129.
                        Unfortunately my DLAN adaptor died where my MagicMirror and other devices are connected.
                        When it works again, I can answer the other questions.
                          @evroom
                          So i can fix the handling of an “empty” timerlist meanwhile, but this will take until the end of the week.
                          I am looking forward to hear from you if your DLAN adoptor is back online.
                          AxLED
                          • evroomE Offline
                            evroom
                            @AxLed
                            Just sent you pm2 logs output.
                            There is a lot more than I initialy placed on the forum.
                            I thought all errors were the same, but the node_helper.js line differ.
                            • Cr4z33C Offline
                              Cr4z33 @AxLed
                              @axled sorry for replaying late again, but I always work at night. :winking_face:
                              Do you still need my config or are you already done?
                                @Cr4z33
                                I got some testfiles for VU+ from Evroom and i have to do some modification and testing to the module within the next days.
                                AxLED
                                • Cr4z33C Offline
                                  Cr4z33 @AxLed
                                  @axled alright. :thumbs_up_medium-light_skin_tone:
                                    @evroom
                                    I did some bugfixing:
                                    • bugfixing in error response (node_helper.js)
                                    • bugfix in handling timerlist if empty (MMM-Dreambox.js)
                                    Please check the dev branch of my module:
                                    • Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                    • do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                    Tell me what happens now, if you try to connect to VU+ receiver.
                                    Regards
                                    AxLED
                                    • evroomE Offline
                                      evroom
                                      @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                      Unfortunately still (the same?) errors:
                                      0|mm  | TypeError: Cannot read property 'statusCode' of undefined
                                      0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:75:42)
                                      0|mm  |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                      0|mm  |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:877:8)
                                      0|mm  |     at ClientRequest.emit (events.js:211:7)
                                      0|mm  |     at Socket.socketErrorListener (_http_client.js:387:9)
                                      0|mm  |     at Socket.emit (events.js:211:7)
                                      pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ git status
                                      On branch dev
                                      Your branch is up-to-date with 'origin/dev'.
                                      nothing to commit, working tree clean
                                      pi@MagicPi:~/MagicMirror/modules $ grep 'at Request._callback' /home/pi/.pm2/logs/mm-error.log | sort -u
                                          at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:103:42)
                                          at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:116:42)
                                          at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:42)
                                          at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:89:42)
                                      • evroomE Offline
                                        evroom
                                        @AxLed
                                        I also tried the Dreambox.
                                        There are no errors and the play list is shown on the Mirror.
                                        However, there is a problem when you put the port in the config.js:
                                        pi@MagicPi:~ $ ps -eaf | grep omxplayer | grep -v grep
                                        pi       20618 20445  1 22:07 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                        pi       20619 20618  1 22:07 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                        pi       20642 20619  0 22:07 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                        You see that streaming uses port 8001, so you get 80:8001 as port.
                                        In my case, I use the standard port 80, so I can leave it out, but for example @Cr4z33 uses a different port, so he will not be able to stream.
                                        So, my suggestion is to set the port as a separate variable in the config and only use it where necessary.
                                        • evroomE Offline
                                          evroom
                                          @AxLed
                                          Other observations (tested with Dreambox dm7020hd).
                                          1/
                                          When I start the Mirror, I no channel is selected.
                                          Then when you do DB-PLAY as first remote command, the list on the Mirror will have a grey background (as if everything is selected) and nothing is streamed.
                                          2/
                                          When you do DB-PLAY, I get multiple streams.
                                          I reported this before.
                                          pi       20862 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20863 20862  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20886 20863  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20894 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20895 20894  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          pi       20921 20895  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                          3/ After a while the selection of a channel disappears.
                                          The selection sometimes is just a grey background and sometimes a grey background with a play button.
                                          4/ My Dreambox has 2 tuners.
                                          I probably see the “now playing” from tuner A, whilst tuner B is streaming.
                                          As the selection disappears, I do not know which channel is streaming.
                                            AxLed Module Developer @evroom
                                            @evroom
                                            Answer to the 5 errors in node_helper.js:
                                            I comment the lines out, please try again with the dev branch.
                                            AxLED
                                            • 4 / 8
