    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • evroomE
      evroom
      Looks like it does not work VU+ boxes.
      I used the latest master branch (installed the complete module new).
      All api paths have been checked and return xml data.
      Dreambox DM7020HD:
      $ pm2 restart mm
      0|mm  | Starting node helper for: MMM-Dreambox
      On the Mirror a list of channels is seen.
      VU+ zero:
      0|mm  | Whoops! There was an uncaught exception...
      0|mm  | TypeError: Cannot read property 'code' of null
      0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:37)
      0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
      0|mm  |     at emitTwo (events.js:126:13)
      0|mm  |     at Request.emit (events.js:214:7)
      0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
      0|mm  |     at emitOne (events.js:116:13)
      0|mm  |     at Request.emit (events.js:211:7)
      0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
      0|mm  |     at Object.onceWrapper (events.js:313:30)
      0|mm  |     at emitNone (events.js:111:20)
      0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      121		//5.Request - Servicelistplayable
      122		request({url: myUrl+this.config.apiServicelistplayable }, function (error, response, body) {
      123			if (!error && response.statusCode == 200) {
      124				self.sendSocketNotification("DATA",['DB-SLP',body]);
      125			} else {
      126				if (!error && response.statusCode == 404){
      127					Errormessage = 'Error: '+response.statusCode+' in '+myUrl+self.config.apiServicelistplayable;
      128				} else {
      129					Errormessage = 'Error: '+error.code+' in '+myUrl+self.config.apiServicelistplayable;
      130				}
      131				self.sendSocketNotification("DATA",['ERROR',Errormessage]);
      132			}
      133		});
      apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
      http://192.168.178.47/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet
      <e2servicelistplayable>
      Nothing is seen on the Mirror.
      MagicMirror version: 2.37.0
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @evroom
        @evroom that’s EXACTLY what happens on my mirror as an owner of a Vu+ product.
        @AxLed can you please look into this? :)
        • A
          AxLed Module Developer
          @Cr4z33
          Can you please post your config for MMM-Dreambox (as i guess there are two problems):
          1. at least one of your links are wrong or VU+ uses different syntax (for the xml links)
          2. i think node_helper.js line 129 is wrong in my code, i cant correct it without testing (error.code is null and my code expects an value)
          apiBase:
          omxargs:
          refreshInterval:
          apiabout:
          apiservices:
          apiepgnow:
          apizap:
          apiTimerlist:
          apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
          listmax:
          AxLED
          • evroomE
            evroom
            Hi AxLed,
            Here is my VU+ config:
            module: 'MMM-Dreambox',
            disabled: false,
            position:"top_left",
            header: 'Dreambox',
              apiBase: 'http://192.168.178.47:80',
              omxargs: ' --win 0,625,590,957 -o both ',
              refreshInterval: 1000 * 30, //refresh every 30 seconds
              apiabout: '/web/about',
              apiservices: '/web/getallservices',
              apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
              apizap: '/web/zap?sRef=',
              apiTimerlist: '/web/timerlist',
              apibouquet: 0,
              listmax: 10,
            To be honest, I do not see any difference between a Dreambox and a VU Plus, in fact the bRef and sRef are exactly the same and even the same as in the README.
            But if you say there is a difference …
            If the line 129 needs modifying, I can do so by hand.
            Perhaps will save you some time.
            And could you tell us if you tested on a VU+ or on a Dreambox (or both) ?
            • A
              @evroom
              To answer your questions:
              • i tested on a dreambox (dm800se) with a single dvb-c tuner
              • modifying line 129 could help, i need the output of ‘error’ and ‘response’, as i only check for ‘error’ (true/false) and only for response.Statuscode 200 and 404.
              I have some questions too:
              • if you enter http://192.168.178.47:80/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet in you browser, is there xml showing up?
              • if not, what else is shown?
              • the xml files you send me on 29th of december, where they from your dreambox or from VU+?
              • if the were from the dreambox, can you please send me the following file from your VU+ by email ak10zeichen-xy@yahoo.de :
              • http://192.168.178.47:80/web/getallservices
              So i can check what is going wrong.
              AxLED
              • evroomE
                evroom
                @AxLed
                Yes, now I remember that you used a dm800se.
                And then it was you who explained me how to post xml data in this forum (which I forgot again).
                The xml files from December were from a Dreambox.
                Perhaps you mean that the syntax of the xml data is different, not the syntax in the config file.
                Then I understand.
                The servicelistplayable URL return xml data, as do all /web/ calls.
                The getallservices xml data will arrive by mail in a minute.
                • A
                  @evroom
                  Thanks for the files, i tested with your files, but i am getting a different error:
                  Your error (some topics above): Problem at servicelistplayable
                  My error (with your VU xml files): Problem in MMM-Dreambox.js at line 387, where the timerlist expects a value. I can fix this error, somehow my code expects at least one timer.
                  Can you please tell me, at which point/line of code you get an error?
                  If your error is in MMM-Dreambox.js at line 387 can you try to add one timer in the future an test again?
                  AxLED
                  • evroomE
                    evroom
                    @AxLed
                    Sent you a timer list.
                    The last time I checked, the error pointed to line 129.
                    Unfortunately my DLAN adaptor died where my MagicMirror and other devices are connected.
                    When it works again, I can answer the other questions.
                    • A
                      @evroom
                      So i can fix the handling of an “empty” timerlist meanwhile, but this will take until the end of the week.
                      I am looking forward to hear from you if your DLAN adoptor is back online.
                      AxLED
                      • evroomE
                        evroom
                        @AxLed
                        Just sent you pm2 logs output.
                        There is a lot more than I initialy placed on the forum.
                        I thought all errors were the same, but the node_helper.js line differ.
                        • Cr4z33C
                          Cr4z33 @AxLed
                          @axled sorry for replaying late again, but I always work at night. :winking_face:
                          Do you still need my config or are you already done?
                          • A
                            @Cr4z33
                            I got some testfiles for VU+ from Evroom and i have to do some modification and testing to the module within the next days.
                            AxLED
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled alright. :thumbs_up_medium-light_skin_tone:
                              • A
                                @evroom
                                I did some bugfixing:
                                • bugfixing in error response (node_helper.js)
                                • bugfix in handling timerlist if empty (MMM-Dreambox.js)
                                Please check the dev branch of my module:
                                • Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                • do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                Tell me what happens now, if you try to connect to VU+ receiver.
                                Regards
                                AxLED
                                • evroomE
                                  evroom
                                  @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                  Unfortunately still (the same?) errors:
                                  0|mm  | TypeError: Cannot read property 'statusCode' of undefined
                                  0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:75:42)
                                  0|mm  |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                  0|mm  |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:877:8)
                                  0|mm  |     at ClientRequest.emit (events.js:211:7)
                                  0|mm  |     at Socket.socketErrorListener (_http_client.js:387:9)
                                  0|mm  |     at Socket.emit (events.js:211:7)
                                  pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ git status
                                  On branch dev
                                  Your branch is up-to-date with 'origin/dev'.
                                  nothing to commit, working tree clean
                                  pi@MagicPi:~/MagicMirror/modules $ grep 'at Request._callback' /home/pi/.pm2/logs/mm-error.log | sort -u
                                      at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:103:42)
                                      at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:116:42)
                                      at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:42)
                                      at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:89:42)
                                  A 1 Reply Last reply
                                  • evroomE
                                    evroom
                                    @AxLed
                                    I also tried the Dreambox.
                                    There are no errors and the play list is shown on the Mirror.
                                    However, there is a problem when you put the port in the config.js:
                                    pi@MagicPi:~ $ ps -eaf | grep omxplayer | grep -v grep
                                    pi       20618 20445  1 22:07 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                    pi       20619 20618  1 22:07 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                    pi       20642 20619  0 22:07 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:80:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                    You see that streaming uses port 8001, so you get 80:8001 as port.
                                    In my case, I use the standard port 80, so I can leave it out, but for example @Cr4z33 uses a different port, so he will not be able to stream.
                                    So, my suggestion is to set the port as a separate variable in the config and only use it where necessary.
                                    • evroomE
                                      evroom
                                      @AxLed
                                      Other observations (tested with Dreambox dm7020hd).
                                      1/
                                      When I start the Mirror, I no channel is selected.
                                      Then when you do DB-PLAY as first remote command, the list on the Mirror will have a grey background (as if everything is selected) and nothing is streamed.
                                      2/
                                      When you do DB-PLAY, I get multiple streams.
                                      I reported this before.
                                      pi       20862 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      pi       20863 20862  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      pi       20886 20863  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      pi       20894 20720  0 22:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      pi       20895 20894  0 22:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      pi       20921 20895  7 22:14 ?        00:00:17 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EE3:441:1:C00000:0:0:0:
                                      3/ After a while the selection of a channel disappears.
                                      The selection sometimes is just a grey background and sometimes a grey background with a play button.
                                      4/ My Dreambox has 2 tuners.
                                      I probably see the “now playing” from tuner A, whilst tuner B is streaming.
                                      As the selection disappears, I do not know which channel is streaming.
                                      • A
                                        AxLed Module Developer @evroom
                                        @evroom
                                        Answer to the 5 errors in node_helper.js:
                                        I comment the lines out, please try again with the dev branch.
                                        AxLED
                                        • A
                                          @evroom
                                          About the error for following usage: Dreambox and Dreambox-IP with a port.
                                          I will have to do some testing and come back to you if i have the solution.
                                          AxLED
                                          • A
                                            @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                            1/
                                            2/
                                            Here are some answers:
                                            to 1: Thats true, if module is loaded no channel is selected. Normally you should select a channel first an then start streaming (by DB-PLAY)
                                            to 2: I dont understand at which point you get multiple streams. If no channel was selected before?
                                            to 3: Thats true, if a channel is selected, the background of the selection should be grey. The grey selection will be reseted (to black background), if a refresh of datas is done (duration depends on your refresh interval in config.js). The refresh is hardly to see on the mirror, as i dont do a update.dom, i am updating the relevant dom datas directly. The play symbol is shown if you send a DB-PLAY after selection, so you can see that streaming will start within the next seconds. Because after start of streaming the datas are updatet, the grey selection and the play symbols dissapear.
                                            to 4: On my dreambox, if a start a stream on MM, the first line of the module now playing shows the channel i am streaming (if you dont defined the size of stream to full screen). I have no idea, what would be shown on now playing on a 2 tuner box.
                                            Most of the issues can be fixed, but i would like to get the some other issues (see this thread) fixed first.
                                            AxLED
                                            evroomE 1 Reply Last reply
                                            • 4 / 8
