    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.9k Views 6 Watching
    • evroomE
      evroom
      @AxLed
      Did git pull.
      0|mm  | Starting node helper for: MMM-Dreamboxpi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ git status
      On branch dev
      Your branch is up-to-date with 'origin/dev'.
      nothing to commit, working tree clean
      pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ ls -alstr
      total 112
       4 drwxr-xr-x 13 pi pi  4096 Jan 31 21:39 ..
       4 drwxr-xr-x  2 pi pi  4096 Jan 31 21:39 translations
       8 -rw-r--r--  1 pi pi  7330 Jan 31 21:39 README.md
       8 -rw-r--r--  1 pi pi  7185 Jan 31 21:39 MMM-Dreambox-xml2json.js
      48 -rw-r--r--  1 pi pi 45771 Jan 31 21:39 MMM-Dreambox_screenshot1.jpg
      20 -rw-r--r--  1 pi pi 19015 Jan 31 21:39 MMM-Dreambox.js
       4 -rw-r--r--  1 pi pi   821 Jan 31 21:39 MMM-Dreambox.css
       8 -rw-r--r--  1 pi pi  5242 Feb  1 20:10 node_helper.js
       4 drwxr-xr-x  4 pi pi  4096 Feb  1 20:10 .
       4 drwxr-xr-x  8 pi pi  4096 Feb  1 20:19 .git
      Restarted MM.
      No errors in the pm2 logs.
      On the Mirror I see
      Error
      And a white line (in the MMM-Dreambox module area).
      EDIT: Same behaviour for my Dreambox.
      MagicMirror version: 2.37.0
      • evroomE
        evroom @AxLed
        @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        to 2: I dont understand at which point you get multiple streams. If no channel was selected before?
        In fact I get 2 streams always.
        When I send DB-PLAY immediately.
        Or when I send DB-PLAY after selecting a service.
        When I send DB-STOP both streams are stopped.
        Most probably due to my 2 tuner box.
        I have a 1 tuner VU+ solo, but there we are still debugging to get the services visible at all.
        • A
          AxLed Module Developer
          @evroom
          I did some modification to the dev branch.
          Modified/fixed:
          • error if used Dreambox-IP with a port
          • errors showing up in node_helper.js
          Now i can use my dreambox with a different port and the data requests (with defined port) and streaming (with port :8001) works correctly.
          Can you please try with your tuners?
          AxLED
          • evroomE
            evroom
            @AxLed
            With “apiBase: ‘http://192.168.178.28’”, I get “http:8001”.
            pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ ps -eaf | grep omxplayer | grep -v grep
            pi       30691 30252  2 23:09 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http:8001/1:0:1:2F08:441:1:C00000:0:0:0:
            pi       30692 30691  0 23:09 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http:8001/1:0:1:2F08:441:1:C00000:0:0:0:
            BUT …
            With “apiBase: ‘http://192.168.178.28:80’”, I get “http://192.168.178.28:8001” and streaming works.
            pi       31023 30795  0 23:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
            pi       31024 31023  0 23:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
            pi       31047 31024  7 23:14 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
            Observations:
            Streaming is working.
            The first time DB-PLAY: one service only.
            Changing services is not possible using DB-SERVICE-NEXT.
            Stopping with DB-STOP, then DB-SERVICE-NEXT and then DB-PLAY: two streams again.
            Got into a situation where DB-PLAY caused my second tuner (what I was seeing on my regular TV) changed channel to the selected service.
            The “now playing” line still shows the service from the other tuner, but if you have a single tuner, then it will be difficult to change this.
            Perhaps I will find something on this topic.
            So, I guess that for a single Dreambox tuner everything works fine, but that there are odd behaviours when you have a multiple tuner (a dual tuner in my case).
            I would concentrate now on getting it to work for VU+ devices.
            If I could, I would help you, but I still fail to see where and how the parsing of the xml data is done.
            • A
              @evroom
              1. I can fix the “http:8001” problem, if i find some time, so the module works for single tuner dreamboxes again.
              2. If you use the module (dev branch) with VU+, what happens?
                AxLED
              evroomE 1 Reply Last reply
              • Cr4z33C
                Cr4z33
                @AxLed sorry for not being so much available lately, but apart from work and mirror assembly (the ‘baby’ is going to born into the next days if everything goes well… :crossed_fingers_medium-light_skin_tone: ) I see that @evroom is much more skilled and suitable for the debugging. :grimacing_face:
                I hope that everything will be sorted soon and thanks @AxLed for taking care into it.
                • evroomE
                  evroom @AxLed
                  I still see ‘Error’ on the Mirror.
                  • evroomE
                    evroom
                    @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                    Testing is no problem.
                    It is a pity I cannot help with real debugging.
                    Oddly enough I do programming for REST api’s on a professional level, but for that I use Perl.
                    Also puts me off a bit in going deeper into the MMM modules stuff, but I think that applies to more persons (8 hours a day behind the computer at work and sitting being that thing again in you spare time is sometimes too much :-) ).
                    Hope that the ‘baby’ will be a real baby and I wish you and your partner all the best.
                    Cr4z33C 1 Reply Last reply
                    • evroomE
                      evroom
                      @AxLed
                      I noticed that after ‘Error’ there was a short other message.
                      I had to set the refresh time to 1 second and to capture numerous time before I could capture 1 error message:
                      Error: null in http://192.168.178.47/web/about
                      It can be that there are more errors or just this one.
                      I will send you some xml files by mail.
                      A 1 Reply Last reply
                      • Cr4z33C
                        Cr4z33 @evroom
                        @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                        Lol no it’s actually my first MM mirror. :face_with_stuck-out_tongue_winking_eye:
                        If there will be any improvement into getting Vu+ devices to work I will be trying it in a Duo² dual DVB-S / DVB-T tuner decoder.
                        • evroomE
                          evroom
                          Hahahaha :-)
                          You got me there !!!
                          I did notice the baby in quotes, but the ‘born’ and ‘if everything goes well’ twisted my mind.
                          Very funny.
                          Well, in fact there are simularities:
                          It takes a while before it can walk.
                          It crashes sometimes, but always recovers.
                          It causes problems on daily basis.
                          It can cause you to sleep bad.
                          But you still love it.
                          • A
                            @evroom
                            I did some furter bugfixing:
                            • bugfixing the “http:8001” problem
                            Please check the dev branch of my module:
                            Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                            do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                            Now the module should work with dreambox, no matter if the dreambox uses a separat port or not.
                            Regards
                            AxLED
                            • evroomE
                              evroom
                              I found 1 ‘issue’ in the /web/about on my 1 tuner VU+zero:
                              (had to put spaces after and before < and > ; forum issue)
                              < e2servicename >< /e2servicename >
                              On the OpenWebif is shows “Nothing running …”.
                              As if it is on standby.
                              This is what I get on my 2 tuner VU+ solo2, when on:
                              < e2servicename >Das Erste HD< /e2servicename >< e2servicename >
                              And when it is in standby:
                              Did not look at the other xml output in detail yet.
                              So, when /web/about does not find a service, hence null, it should be replaced by “Nothing running …”.
                              • A
                                @evroom
                                I never tried my module in dreambox standby, as i dont use it. My dreambox is on or in deep standby.
                                Can you please try with your receivers (Dreambox or VU) on?
                                AxLED
                                • evroomE
                                  evroom
                                  I can confirm that with or without port, streaming works.
                                  • A
                                    AxLed Module Developer @evroom
                                    I checked with some of the files you send me (all different 3 VU+ about xmls), the work in my environment. Is your VU+ maybe also in standby mode?
                                    AxLED
                                    • evroomE
                                      evroom
                                      VU+ Solo2:
                                      When on /web/about shows the service name.
                                      When in standby it shows no service name.
                                      Dreambox dm7020hd:
                                      So, the same.
                                      When I use the Dreambox for the module, there are NO errors.
                                      The service list is shown.
                                      When I use the VU+ for the module, there are errors.
                                      The service list is NOT shown.
                                      The errors are different when in standby (/web/about) and when on (/web/epgnow).
                                      Could you please also print the errors in the pm2 log ?
                                      Now on the Mirror I see Error for 30 seconds and then Error: for 2 seconds.
                                      • evroomE
                                        evroom
                                        Btw,
                                        VU+ Solo2:
                                        http://192.168.178.46/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
                                        Works. Both when on or in soft-standby.
                                        • evroomE
                                          evroom
                                          When in deep standby I would expect that you will see
                                          for /web/about.
                                          And as you do not see an error, I fail to see the difference with the VU+ in soft-standby.
                                          But in deep standby, you cannot stream, can you ?
                                          Will the playable services then be none ?
                                          Cannot test this now without being killed by the family :-)
                                          • A
                                            @evroom said in [MMM-Dreambox]:
                                            @evroom
                                            Welcome to my world :-)
                                            I have another idea:
                                            Did you check/compare the settings on your tuners (dreambox vs. VU+).
                                            I case of my dreambox (DM800SE) they are under:
                                            • Erweiterungen -> Webinterface
                                            • Extensions -> Webinterface (maybe the spelling is different, as i translated them into english)
                                            This is a screenshot of my actual setting (i only played around with the HTTP Port to fix some earlier bugs):
                                            AxLED
                                            • 5 / 8
