    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 215.7k Views 6 Watching
    • evroomE Offline
      evroom
      @AxLed
      With “apiBase: ‘http://192.168.178.28’”, I get “http:8001”.
      pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ ps -eaf | grep omxplayer | grep -v grep
      pi       30691 30252  2 23:09 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http:8001/1:0:1:2F08:441:1:C00000:0:0:0:
      pi       30692 30691  0 23:09 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http:8001/1:0:1:2F08:441:1:C00000:0:0:0:
      BUT …
      With “apiBase: ‘http://192.168.178.28:80’”, I get “http://192.168.178.28:8001” and streaming works.
      pi       31023 30795  0 23:14 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
      pi       31024 31023  0 23:14 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
      pi       31047 31024  7 23:14 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.28:8001/1:0:1:2EF4:441:1:C00000:0:0:0:
      Observations:
      Streaming is working.
      The first time DB-PLAY: one service only.
      Changing services is not possible using DB-SERVICE-NEXT.
      Stopping with DB-STOP, then DB-SERVICE-NEXT and then DB-PLAY: two streams again.
      Got into a situation where DB-PLAY caused my second tuner (what I was seeing on my regular TV) changed channel to the selected service.
      The “now playing” line still shows the service from the other tuner, but if you have a single tuner, then it will be difficult to change this.
      Perhaps I will find something on this topic.
      So, I guess that for a single Dreambox tuner everything works fine, but that there are odd behaviours when you have a multiple tuner (a dual tuner in my case).
      I would concentrate now on getting it to work for VU+ devices.
      If I could, I would help you, but I still fail to see where and how the parsing of the xml data is done.
      MagicMirror version: 2.37.0
        AxLed Module Developer
        @evroom
        1. I can fix the “http:8001” problem, if i find some time, so the module works for single tuner dreamboxes again.
        2. If you use the module (dev branch) with VU+, what happens?
          AxLED
        • Cr4z33C Offline
          Cr4z33
          @AxLed sorry for not being so much available lately, but apart from work and mirror assembly (the ‘baby’ is going to born into the next days if everything goes well… :crossed_fingers_medium-light_skin_tone: ) I see that @evroom is much more skilled and suitable for the debugging. :grimacing_face:
          I hope that everything will be sorted soon and thanks @AxLed for taking care into it.
          • evroomE Offline
            evroom @AxLed
            @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            I still see ‘Error’ on the Mirror.
            No errors in the pm2 logs.
            • evroomE Offline
              evroom
              @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
              Testing is no problem.
              It is a pity I cannot help with real debugging.
              Oddly enough I do programming for REST api’s on a professional level, but for that I use Perl.
              Also puts me off a bit in going deeper into the MMM modules stuff, but I think that applies to more persons (8 hours a day behind the computer at work and sitting being that thing again in you spare time is sometimes too much :-) ).
              Hope that the ‘baby’ will be a real baby and I wish you and your partner all the best.
              • evroomE Offline
                evroom
                @AxLed
                I noticed that after ‘Error’ there was a short other message.
                I had to set the refresh time to 1 second and to capture numerous time before I could capture 1 error message:
                Error: null in http://192.168.178.47/web/about
                It can be that there are more errors or just this one.
                I will send you some xml files by mail.
                • Cr4z33C Offline
                  Cr4z33 @evroom
                  @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                  Lol no it’s actually my first MM mirror. :face_with_stuck-out_tongue_winking_eye:
                  If there will be any improvement into getting Vu+ devices to work I will be trying it in a Duo² dual DVB-S / DVB-T tuner decoder.
                  • evroomE Offline
                    evroom
                    Hahahaha :-)
                    You got me there !!!
                    I did notice the baby in quotes, but the ‘born’ and ‘if everything goes well’ twisted my mind.
                    Very funny.
                    Well, in fact there are simularities:
                    It takes a while before it can walk.
                    It crashes sometimes, but always recovers.
                    It causes problems on daily basis.
                    It can cause you to sleep bad.
                    But you still love it.
                      @evroom
                      I did some furter bugfixing:
                      • bugfixing the “http:8001” problem
                      Please check the dev branch of my module:
                      Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                      do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                      Now the module should work with dreambox, no matter if the dreambox uses a separat port or not.
                      Regards
                      AxLED
                      • evroomE Offline
                        evroom
                        I found 1 ‘issue’ in the /web/about on my 1 tuner VU+zero:
                        (had to put spaces after and before < and > ; forum issue)
                        < e2servicename >< /e2servicename >
                        On the OpenWebif is shows “Nothing running …”.
                        As if it is on standby.
                        This is what I get on my 2 tuner VU+ solo2, when on:
                        < e2servicename >Das Erste HD< /e2servicename >< e2servicename >
                        And when it is in standby:
                        Did not look at the other xml output in detail yet.
                        So, when /web/about does not find a service, hence null, it should be replaced by “Nothing running …”.
                          @evroom
                          I never tried my module in dreambox standby, as i dont use it. My dreambox is on or in deep standby.
                          Can you please try with your receivers (Dreambox or VU) on?
                          AxLED
                          • evroomE Offline
                            evroom
                            I can confirm that with or without port, streaming works.
                              AxLed Module Developer @evroom
                              I checked with some of the files you send me (all different 3 VU+ about xmls), the work in my environment. Is your VU+ maybe also in standby mode?
                              AxLED
                              • evroomE Offline
                                evroom
                                VU+ Solo2:
                                When on /web/about shows the service name.
                                When in standby it shows no service name.
                                Dreambox dm7020hd:
                                So, the same.
                                When I use the Dreambox for the module, there are NO errors.
                                The service list is shown.
                                When I use the VU+ for the module, there are errors.
                                The service list is NOT shown.
                                The errors are different when in standby (/web/about) and when on (/web/epgnow).
                                Could you please also print the errors in the pm2 log ?
                                Now on the Mirror I see Error for 30 seconds and then Error: for 2 seconds.
                                • evroomE Offline
                                  evroom
                                  Btw,
                                  VU+ Solo2:
                                  http://192.168.178.46/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
                                  Works. Both when on or in soft-standby.
                                  • evroomE Offline
                                    evroom
                                    When in deep standby I would expect that you will see
                                    for /web/about.
                                    And as you do not see an error, I fail to see the difference with the VU+ in soft-standby.
                                    But in deep standby, you cannot stream, can you ?
                                    Will the playable services then be none ?
                                    Cannot test this now without being killed by the family :-)
                                      @evroom said in [MMM-Dreambox]:
                                      @evroom
                                      Welcome to my world :-)
                                      I have another idea:
                                      Did you check/compare the settings on your tuners (dreambox vs. VU+).
                                      I case of my dreambox (DM800SE) they are under:
                                      • Erweiterungen -> Webinterface
                                      • Extensions -> Webinterface (maybe the spelling is different, as i translated them into english)
                                      This is a screenshot of my actual setting (i only played around with the HTTP Port to fix some earlier bugs):
                                      AxLED
                                      • evroomE Offline
                                        evroom
                                        For VU+ Solo2:
                                        Port is 80 and HTTP authentication on yes.
                                        Will set HTTP authentication to no and try again.
                                        I see now, there is also a separate OpenWebif config:
                                        This uses port 81 and indeed works.
                                        Looks totally different from the Webif.
                                        Interesting.
                                        For the Dreambox I cannot find a menu item like this.
                                        I still use the original Dreambox OE2.0 image.
                                        • evroomE Offline
                                          evroom
                                          Excellent idea on a Sunday !!!
                                          Changed Enable HTTP Authentication to no and see, it works !!!
                                          The services list is shown and streaming works.
                                          The same issues occur though for the dual tuner VU+:
                                          After the first DB-PLAY all is well, but then DB-STOP, DB-SERVICE-NEXT and DB-PLAY causes 2 streams.
                                          Will try now on the single tuner VU+.
                                          Perhaps you try setting it to yes for the Dreambox and see what happens ?
                                          If the same errors appear then it is confirmed.
                                            @evroom
                                            I will try the authentication thing if i find some time, maybe i can catch the error and handle it, so the module user know what to do.
                                            AxLED
                                            • 5 / 8
