    I am stuck need help
    25 Posts 11 Posters 15.6k Views 10 Watching
      antkaf @dcarls91
      Give this a try. A handy tool
      pi@raspberrypi:~/MagicMirror $ npm run config:check
      hope its sorted
        dcarls91
        Just wanted to say thanks again for all of the help. I have spent the last couple of days trying to figure this out to no avail. I have decided to scrap the project for now until I can figure out what I am doing because I clearly do not have a clue.
        • evroomE Offline
          evroom
          @dcarls91
          I understand that in the beginning the amount information can be overwhelming, but how are you going to find out what you are doing when you scrape your project?
          Especially when you are so close in getting the ‘Mirror’ started; just a few characters are missing in the config file.
          The community here is very active and very helpful and can step down a nodge when it is getting too technical.
          Of course it is expected that you have a certain level of knowledge or that you are willing to obtain that level.
          Besides spending several hours, did you spend any money on equipment, etc?
          If you decide to give it a last effort, then it would help to tell us on what platform your Mirror is running (Raspberry, PC, Ubuntu, etc) and it would help to report back with a bit more details (other than I tried and it did not work).
          And if someone tells you to perform action XYZ and you have no idea what the heck XYZ is or how to execute, then don’t be afraid to say so.
          The suggestions given, like try it module by module and the config check are very useful (I guess everyone was in this position, I know I was) and will solve your issues.
          If you decide to move away from Magic Mirror, then I respect that, but perhaps you will reconsider.
          Disclaimer: I do not have any shares in the project and am by no means an expert. Just reaching out. :-)
          MagicMirror version: 2.37.0
          • Y Offline
            yawns Moderator @dcarls91
            @dcarls91 said in I am stuck need help:
            @yawns thank you for doing that, I’m very new to this, what else do i need to do to the above config file you posted
            Sorry, I did not see your reply. Copy the config I posted, save it as config.js and add your API keys and links to calendars again. Or, to clearly see the changes I made, use this:
            https://www.diffchecker.com/QQhBPpNO
            Left is your config, right is my fixed config.
            lavolp3L 1 Reply Last reply Reply Quote 1
            • N Offline
              n21brown @yawns
              @yawns might also want to consider removing lat/long too
              • BKeyportB Offline
                BKeyport Module Developer
                @dcarls91 Don’t give up.
                Keep at it, you’re so close to having a working MM - a little self study and work and it’s done.
                  dcarls91
                  Thank you all for your help, after a long day yesterday i was able to get it up and running.
                  • evroomE Offline
                    evroom
                    You see, we knew you could do it !! :-)
                    Congratulations.
                      sdetweil @dcarls91
                      @dcarls91 congratulations!!.. could you summarize what the problem was? config, system, ? something else?
                      I am looking for how to help others that express the same problem…
                      thanks for any insight…
                      • BKeyportB Offline
                        in his case, it was simply horrible config.js layout. Missing syntax all over the place.
                        cd ~
                        Best script ever right there. I can’t express how important that is.
                          dcarls91 @sdetweil
                          the issues honestly are having little to no coding experience, and not knowing where commas and brackets go. Luckily, someone helped fixed my config file.
                          I also ran into an issue with installing the modules. I did not realize at first that after you git clone the module you have to go into the module directory and run npm install command. After reading into it, it was a very simple fix.
                          Most of my issues were from inexperience and being overwhelmed.
                            Mykle1 Project Sponsor Module Developer @dcarls91
                            Dude, do your victory dance now! :clap:
                            • lavolp3L Offline
                              lavolp3 Module Developer @yawns
                              @yawns said in I am stuck need help:
                              You’re full of valuable links!!! :-)
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • evroomE Offline
                                evroom
                                I posted this in another thread too.
                                For beginners, the catchphrase is “JSON syntax”.
                                There are many articles to be found, both short and lengthy.
                                A small article would be:
                                https://restfulapi.net/json-syntax/
                                The main things to look for in your config.js file are:
                                • does every [ have a matching ]
                                • are all arrays separated by a , (the last array does not need a ,)
                                • does every { have a matching }
                                • are all objects separated by a , (the last object does not need a ,)
                                • is every name value pair separated by a ,
                                The syntax checker will try to find out if this syntax is correct and tries to predict where the error could be.
                                So, when it says it saw a [ and it cannot find a matching ] it tells you what was expected and what it saw.
                                Try to format you config.js to make it more visible.
                                For example this:
                                is better written like this:
                                Pairs of [ ]and { } are better visible like this.
                                Good luck :-)
