    I am stuck need help
    25 Posts 11 Posters 16.0k Views 10 Watching
    • N
      n21brown @yawns
      @yawns might also want to consider removing lat/long too
      • BKeyportB
        BKeyport Module Developer
        @dcarls91 Don’t give up.
        Keep at it, you’re so close to having a working MM - a little self study and work and it’s done.
          dcarls91
          Thank you all for your help, after a long day yesterday i was able to get it up and running.
          • evroomE
            evroom
            @dcarls91 said in I am stuck need help:
            You see, we knew you could do it !! :-)
            Congratulations.
            MagicMirror version: 2.37.0
              sdetweil @dcarls91
              @dcarls91 congratulations!!.. could you summarize what the problem was? config, system, ? something else?
              I am looking for how to help others that express the same problem…
              thanks for any insight…
              D 1 Reply Last reply
              • BKeyportB
                in his case, it was simply horrible config.js layout. Missing syntax all over the place.
                npm run config:check
                cd ~
                Best script ever right there. I can’t express how important that is.
                  dcarls91 @sdetweil
                  the issues honestly are having little to no coding experience, and not knowing where commas and brackets go. Luckily, someone helped fixed my config file.
                  I also ran into an issue with installing the modules. I did not realize at first that after you git clone the module you have to go into the module directory and run npm install command. After reading into it, it was a very simple fix.
                  Most of my issues were from inexperience and being overwhelmed.
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @dcarls91
                    Dude, do your victory dance now! :clap:
                    • lavolp3L
                      lavolp3 Module Developer @yawns
                      @yawns said in I am stuck need help:
                      https://www.diffchecker.com/QQhBPpNO
                      You’re full of valuable links!!! :-)
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • evroomE
                        evroom
                        I posted this in another thread too.
                        For beginners, the catchphrase is “JSON syntax”.
                        There are many articles to be found, both short and lengthy.
                        A small article would be:
                        https://restfulapi.net/json-syntax/
                        The main things to look for in your config.js file are:
                        • does every [ have a matching ]
                        • are all arrays separated by a , (the last array does not need a ,)
                        • does every { have a matching }
                        • are all objects separated by a , (the last object does not need a ,)
                        • is every name value pair separated by a ,
                        The syntax checker will try to find out if this syntax is correct and tries to predict where the error could be.
                        So, when it says it saw a [ and it cannot find a matching ] it tells you what was expected and what it saw.
                        Try to format you config.js to make it more visible.
                        For example this:
                        is better written like this:
                        Pairs of [ ]and { } are better visible like this.
                        Good luck :-)
