    I am stuck need help
    25 Posts 11 Posters 14.4k Views 10 Watching
      dcarls91
      Hello, very new to coding and the magic mirror platform. I have installed magic mirror and the modules correctly. I then went into the config.js file and edited it to add the modules etc. Every time I try to start magic mirror it tells me that I have no validated config. js file and that there are errors. Could someone please tell me what I am doing wrong.
      Here is the entire config.js file:
      var config = {
      	                      // - "localhost", "127.0.0.1", "::1"
      	                      // - another specific IPv4/6
      	                      // - "", "0.0.0.0", "::"
      	port: 8080,
              language: "en",
      	timeFormat: 24,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar",
      			module: "clock",
      		 	module: "calendar"
      			header: "Calendar"
      						symbol: "calendar-check",
      						symbol: "calendar-plus-o ",
      						url: "https://calendar.google.com/XXXXXXXX/basic.ics"
      						url: "https://calendar.google.com/XXXXXXX/basic.ics"
      			module: "helloworld",
      			         text: "Welcome to the Carls Residence"
                               module: "MMM-DarkSkyForecast",
                               header: "Weather",
                               classes: "default everyone",
                               disabled: false,
                                        apikey: "Xxxxxxxxxxdda4d069a",
                                        latitude: "39.548935",
                                        longitude: "-89.294533",
                                        iconset: "4c",
                                        concise: false,
                                        forecastLayout: "table"
      			 module: "MMM-MyScoreboard",
                               position: "bottom_left",
                               header: "My Scoreboard",
                                        show LeagueSeparators: true,
                                        colored: true,
                                        viewStyle: "mediumLogos",
                                           sports: [
                                                     league: "NHL",
                                                     groups: ["Western"]
                                                     league: "NFL",
                                                     groups: ["NFC North"]
                                                     league: "MLB",
                                                     groups: ["NL Central"]
                                                    league: "NCAAM",
                                                    groups: ["Big Ten"]
                                                    league: "NCAAF",
                                                    groups: ["Big Ten"]
      		       module: 'MMM-iFrame-Ping',
      		       position: 'bottom_left',
      			        url: "https://radar.weather.gov/radar.php?rid=ILX&product=NCR&overlay=11101111&loop=yes",
      			        height:"100%",
      			        width:"100%",
      			        autoRefresh: true,
      			        updateInterval: 10,
      			        displayLastUpdate: true,
      			        width: "100%",
      			        height: "400px",
      			       scrolling: "no"
                      	module: "newsfeed",
      			position: "bottom_bar",
      				 feeds: [
      						title: "Fox News",
      						url: "http://feeds.foxnews.com/foxnews/latest"
      				  showSourceTitle: true,
      				  showPublishDate: true
        You may want to start from scratch, adding one module at a time and running the mirror to confirm your entries are correct. Then add the next module and repeat. There are a bunch of errors which leads me to believe that you added everything at once. Really, that’s the best way to do it and you learn the process at the same time. If an entry fails then you know where the problem is because you’re saving the config after each successful addition.
          dcarls91
          Thank you, I’ll try that. I’m honestly in over my head i believe, but I’m gonna keep working on it.
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @dcarls91
            @dcarls91
            You’ll be fine. :thumbsup:
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
              dcarls91
              Thank you for the help
                @dcarls91
                You’re welcome. If you have trouble adding one module, by all means, come back here and ask for help. Troubleshooting the addition of one module is a whole lot easier than troubleshooting your entire config. So, start with the default config and try adding a single module. Keep me posted
                • cowboysdudeC Offline
                  cowboysdude Module Developer @dcarls91
                  @dcarls91 said in I am stuck need help:
                  We all were in the beginning…hang in there it’ll get easier for you :)
                    robiv8
                    In your config fil are missing a lot of , and ]
                    check this
                    • BKeyportB Offline
                      BKeyport Module Developer
                      One of the best commands to know is
                       npm run config:check
                      Start at the topmost error and work your way down the file - it’s got lots of problems, but is easily fixed. Also, I highly recommend a graphical type editor if possible - Geany is what I use.
                      I installed samba on my magic mirror so I can edit with the PC version of Geany and save it right to the Pi. It’s great.
                      • Y Offline
                        yawns Moderator
                        var config = {
                        	port: 8080,
                                language: "en",
                        	timeFormat: 24,
                        	units: "imperial",
                        			module: "alert",
                        			module: "clock",
                        			header: "Calendar",
                        						url: "https://calendar.google.com/XXXXXXXXX/basic.ics"
                                                 header: "Weather",
                                                 disabled: false,
                                                          iconset: "4c",
                                                          concise: false,
                                                          showLeagueSeparators: true,
                                                          colored: true,
                                                             sports: [
        league: "NHL",
        groups: ["Western"]
        league: "NFL",
        league: "MLB",
        league: "NCAAM",
        groups: ["Big Ten"]
        league: "NCAAF",
        groups: ["Big Ten"]
                        			        autoRefresh: true,
                        			        updateInterval: 10,
                        			        width: "100%",
                        			        height: "400px",
                        			       scrolling: "no"
                                        	module: "newsfeed",
                        				 feeds: [
                        						title: "Fox News",
                        You missed some ,, some ] and some }
                        Oh, and you should never post your apikeys or links to personal calendars. I truncated both for you
                        D N 2 Replies Last reply Reply Quote 3
                          dcarls91 @yawns
                          @yawns thank you for doing that, I’m very new to this, what else do i need to do to the above config file you posted
                            antkaf @dcarls91
                            Give this a try. A handy tool
                            pi@raspberrypi:~/MagicMirror $ npm run config:check
                            hope its sorted
                              dcarls91
                              Just wanted to say thanks again for all of the help. I have spent the last couple of days trying to figure this out to no avail. I have decided to scrap the project for now until I can figure out what I am doing because I clearly do not have a clue.
                              • evroomE Offline
                                evroom
                                @dcarls91
                                I understand that in the beginning the amount information can be overwhelming, but how are you going to find out what you are doing when you scrape your project?
                                Especially when you are so close in getting the ‘Mirror’ started; just a few characters are missing in the config file.
                                The community here is very active and very helpful and can step down a nodge when it is getting too technical.
                                Of course it is expected that you have a certain level of knowledge or that you are willing to obtain that level.
                                Besides spending several hours, did you spend any money on equipment, etc?
                                If you decide to give it a last effort, then it would help to tell us on what platform your Mirror is running (Raspberry, PC, Ubuntu, etc) and it would help to report back with a bit more details (other than I tried and it did not work).
                                And if someone tells you to perform action XYZ and you have no idea what the heck XYZ is or how to execute, then don’t be afraid to say so.
                                The suggestions given, like try it module by module and the config check are very useful (I guess everyone was in this position, I know I was) and will solve your issues.
                                If you decide to move away from Magic Mirror, then I respect that, but perhaps you will reconsider.
                                Disclaimer: I do not have any shares in the project and am by no means an expert. Just reaching out. :-)
                                MagicMirror version: 2.36.0
                                • Y Offline
                                  yawns Moderator @dcarls91
                                  Sorry, I did not see your reply. Copy the config I posted, save it as config.js and add your API keys and links to calendars again. Or, to clearly see the changes I made, use this:
                                  https://www.diffchecker.com/QQhBPpNO
                                  Left is your config, right is my fixed config.
                                  lavolp3L 1 Reply Last reply Reply Quote 1
                                  • N Offline
                                    n21brown @yawns
                                    @yawns might also want to consider removing lat/long too
                                    • BKeyportB Offline
                                      @dcarls91 Don’t give up.
                                      Keep at it, you’re so close to having a working MM - a little self study and work and it’s done.
                                        dcarls91
                                        Thank you all for your help, after a long day yesterday i was able to get it up and running.
                                        • evroomE Offline
                                          evroom
                                          You see, we knew you could do it !! :-)
                                          Congratulations.
                                            sdetweil @dcarls91
                                            @dcarls91 congratulations!!.. could you summarize what the problem was? config, system, ? something else?
                                            I am looking for how to help others that express the same problem…
                                            thanks for any insight…
