    I am stuck need help
    25 Posts 11 Posters 12.5k Views 10 Watching
      dcarls91
      Hello, very new to coding and the magic mirror platform. I have installed magic mirror and the modules correctly. I then went into the config.js file and edited it to add the modules etc. Every time I try to start magic mirror it tells me that I have no validated config. js file and that there are errors. Could someone please tell me what I am doing wrong.
      Here is the entire config.js file:
      var config = {
      	                      // - "localhost", "127.0.0.1", "::1"
      	                      // - another specific IPv4/6
      	                      // - "", "0.0.0.0", "::"
      	port: 8080,
              language: "en",
      	timeFormat: 24,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar",
      			module: "clock",
      		 	module: "calendar"
      			header: "Calendar"
      						symbol: "calendar-check",
      						symbol: "calendar-plus-o ",
      						url: "https://calendar.google.com/XXXXXXXX/basic.ics"
      						url: "https://calendar.google.com/XXXXXXX/basic.ics"
      			module: "helloworld",
      			         text: "Welcome to the Carls Residence"
                               module: "MMM-DarkSkyForecast",
                               header: "Weather",
                               classes: "default everyone",
                               disabled: false,
                                        apikey: "Xxxxxxxxxxdda4d069a",
                                        latitude: "39.548935",
                                        longitude: "-89.294533",
                                        iconset: "4c",
                                        concise: false,
                                        forecastLayout: "table"
      			 module: "MMM-MyScoreboard",
                               position: "bottom_left",
                               header: "My Scoreboard",
                                        show LeagueSeparators: true,
                                        colored: true,
                                        viewStyle: "mediumLogos",
                                           sports: [
                                                     league: "NHL",
                                                     groups: ["Western"]
                                                     league: "NFL",
                                                     groups: ["NFC North"]
                                                     league: "MLB",
                                                     groups: ["NL Central"]
                                                    league: "NCAAM",
                                                    groups: ["Big Ten"]
                                                    league: "NCAAF",
                                                    groups: ["Big Ten"]
      		       module: 'MMM-iFrame-Ping',
      		       position: 'bottom_left',
      			        url: "https://radar.weather.gov/radar.php?rid=ILX&product=NCR&overlay=11101111&loop=yes",
      			        height:"100%",
      			        width:"100%",
      			        autoRefresh: true,
      			        updateInterval: 10,
      			        displayLastUpdate: true,
      			        width: "100%",
      			        height: "400px",
      			       scrolling: "no"
                      	module: "newsfeed",
      			position: "bottom_bar",
      				 feeds: [
      						title: "Fox News",
      						url: "http://feeds.foxnews.com/foxnews/latest"
      				  showSourceTitle: true,
      				  showPublishDate: true
        You may want to start from scratch, adding one module at a time and running the mirror to confirm your entries are correct. Then add the next module and repeat. There are a bunch of errors which leads me to believe that you added everything at once. Really, that’s the best way to do it and you learn the process at the same time. If an entry fails then you know where the problem is because you’re saving the config after each successful addition.
          dcarls91
          Thank you, I’ll try that. I’m honestly in over my head i believe, but I’m gonna keep working on it.
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @dcarls91
            @dcarls91
            You’ll be fine. :thumbsup:
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
              dcarls91
              Thank you for the help
                @dcarls91
                You’re welcome. If you have trouble adding one module, by all means, come back here and ask for help. Troubleshooting the addition of one module is a whole lot easier than troubleshooting your entire config. So, start with the default config and try adding a single module. Keep me posted
                • cowboysdudeC Offline
                  cowboysdude Module Developer @dcarls91
                  @dcarls91 said in I am stuck need help:
                  We all were in the beginning…hang in there it’ll get easier for you :)
                    robiv8
                    In your config fil are missing a lot of , and ]
                    check this
                    • BKeyportB Offline
                      BKeyport Module Developer
                      One of the best commands to know is
                       npm run config:check
                      Start at the topmost error and work your way down the file - it’s got lots of problems, but is easily fixed. Also, I highly recommend a graphical type editor if possible - Geany is what I use.
                      I installed samba on my magic mirror so I can edit with the PC version of Geany and save it right to the Pi. It’s great.
                      • yawnsY Offline
                        yawns Moderator
                        var config = {
                        	port: 8080,
                                language: "en",
                        	timeFormat: 24,
                        	units: "imperial",
                        			module: "alert",
                        			module: "clock",
                        			header: "Calendar",
                        						url: "https://calendar.google.com/XXXXXXXXX/basic.ics"
                                                 header: "Weather",
                                                 disabled: false,
                                                          iconset: "4c",
                                                          concise: false,
                                                          showLeagueSeparators: true,
                                                          colored: true,
                                                             sports: [
        league: "NHL",
        groups: ["Western"]
        league: "NFL",
        league: "MLB",
        league: "NCAAM",
        groups: ["Big Ten"]
        league: "NCAAF",
        groups: ["Big Ten"]
                        			        autoRefresh: true,
                        			        updateInterval: 10,
                        			        width: "100%",
                        			        height: "400px",
                        			       scrolling: "no"
                                        	module: "newsfeed",
                        				 feeds: [
                        						title: "Fox News",
                        You missed some ,, some ] and some }
                        Oh, and you should never post your apikeys or links to personal calendars. I truncated both for you
                        D N 2 Replies Last reply Reply Quote 3
