    Save performance when rotating screen e.g. on Raspberry Pi
    Scheduled Pinned Locked Moved Showcase
    19 Posts 11 Posters 24.0k Views 14 Watching
    • K Offline
      keyun21 @ptrk95
      @ptrk95 Thanks for sharing your code, so if i understood correctly (newbie here with CSS) I can just copy your code and plug it in my CUSTOM.CSS file and I should good to go (I understand i need to change “90deg” or so based on my monitor setup. TIA.
      • justjim1220J Offline
        justjim1220 Module Developer @ptrk95
        @ptrk95
        this code also works with a 42" TV!
        Thanks!!!
        :smiling_face:
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          ptrk95 Module Developer
          @keyun21 Correct, just give it a go and see what happens ;) Just delete the lines if something strange occours.
          @justjim1220 Thanks for sharing! :)
          Only disadvantage here is that you may have to change the styles of other modules, for example the Snow module doesn’t work right of the bat I think.
          Also note that there might be a better way to code it, since I just googled how to rotate with CSS :D
          • evroomE Offline
            evroom
            @ptrk95 said in Save performance when rotating screen e.g. on Raspberry Pi:
            and want to rotate the screen you can rotate
            Did you counter clockwise rotated you screen ?
            And therefore did ``transform: rotate(90deg);```??
            I originally rotated my screen clock wise (so the top now is on the right hand side) using /boot/config.txt and display_hdmi_rotate=3.
            This works fine.
            When I use your css example and take out the /boot/config.txt line, it does not work right.
            I figured I need rotate(270deg), but then I do not see anything.
            Besides that, the omxplayer modules need to be adjusted too (–orientation parameter), so I reverted back to my old method.
            My question: can you setup your screen so that it rotates this way that you see everything upside down (to simulate a clockwise rotation in your case) ??
            And then share the css code.
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
              ptrk95 Module Developer @evroom
              @evroom Yes, I did rotate it counter clockwise.
              I found a solution that worked for my setup, rotating the screen 270:
               body {
              	margin: 0;
              	position: absolute;
               	transform: rotate(-90deg);
               	transform-origin: top left;
              	width: 100vh;
              	height: 100vw;
              	object-fit: cover;
              	top: 100vh;
                      visibility: visible;
              Tell me if that worked for you. Then I`ll update the post :)
              Adjusting the omxplayer orientation is one of the drawbacks.
              • evroomE Offline
                evroom
                Almost, but not quite.
                It does rotate clock wise, but it is centered.
                In Excel analogy: vertical alignment: center.
                I would need ‘top’.
                This is my custom.css, probably the other settings interfere:
                body {
                  margin: 0;
                  position: absolute;
                  width: 100vh;
                  height: 100vw;
                  object-fit: cover;
                  top: 100vh;
                .region.top.left {
                  width: 60%;
                .region.middle.center {
                  width: 60%;
                .region.bottom.left {
                  width: 60%;
                .MMM-HTMLBox {
                  font-size: 18px;
                  line-height: 22px;
                .MMM-RTSPStream header {
                  text-align: left;
                .MMM-RTSPStream .innerWrapper {
                  border-style: none;
                  //border: 1px solid red;
                I want the left side modules to occupy 60% and the right side modules 40%.
                Maybe I have to interpret top, middle and bottom different now ?
                Test environment:
                • evroomE Offline
                  evroom
                  Okay, found it.
                  In my /boot/config.txt I had the width and height set to 900 and 1600 and this has to be now 1600 and 900.
                  This is working:
                  display_hdmi_rotate=0
                  framebuffer_width=1600
                  framebuffer_height=900
                  Works now.
                  Only need to modify the omxplayer lines to have those streams rotated too.
                  Test environment:
                  • T Offline
                    thedk
                    Didnt work that easy for me.
                    1. You have to take the resolution of your display/monitor in the config.txt, not just 1600,900.
                    2. I had to enable overscan, cause the picture was to big.
                    3. If you’re using the MMM-Remote_Control the picture is rotated when you have a look at your MagicMirror.
                    I switched back to the fake KMS driver.
                      Great hack!! I’m going to add this to my CSS 101 guide if that’s OK. I think this is incredibly useful.
                        ptrk95 Module Developer @j.e.f.f
                        @j-e-f-f thank you! Of course you can :)
